First post, by marcin_741
Hello,
This is my first post in this group. I would like to say hello to everyone.
I have the following setup: Fujitsu Futro S550-2 (D2963-A1), MS-DOS6.22, and two sound cards, ESSOLO-1 and CMI8738.
With the equipment mentioned above, I am facing the following issue: neither ESSOLO nor CMI want to work, they are detected by the system, but both cards choose IRQ=11, even though 5 and 7 are free.
In the case of ESSOLO, I used drivers found on Vogons, I tried the Hexxit+ESSOLO.ini method as well as the Pciset method. Regardless, the card still uses IRQ=11.
Given that the motherboard does not have the appropriate chipset (mentioned in few posts on Vogon), will I not be able to run these cards? The BIOS, as befits a terminal-type computer, has a very limited number of settings, and I can't force the card to use a specific interrupt through it.
I also tried to swap the IRQ 11 with 5 using SwapIRQ, but without success.
127.01 KiB
Thank you for your help and best regards.
Reply 1 of 2, by elszgensa
> The BIOS has a very limited number of settings
Fujitsu has tools to mess with all kinds of settings by directly writing to flash. I know of BiosSet and EditCMOS, there may be more. Haven't actually used them myself, just glanced over their manuals, so I don't exactly know how helpful they'd be in your case (or even which are applicable tot your specific board), but might be worth looking into.
Reply 2 of 2, by marcin_741
elszgensa wrote on 2024-02-18, 22:46:
Thank you for the suggestions, unfortunately, in the programs you mentioned, it's not possible to change IRQ. I also asked for help on a forum related to BIOS modifications to unlock options related to IRQ settings, but without success. Furthermore, I bought an HP T5720, cards are detected correctly, but in most cases, games freeze, either in settings or in the game itself. I tried different versions of drivers, various solutions, but they don't work. I guess I'll stick to using DOSBox or a virtual machine.
BR
