First post, by Retronaut
Hey, I bought an AWE64 Value this week, and I was about to install it, and realised I needed to plug my CD-Roms analogue connector into it, for pass through, right?
So on the AWE64 card, it has a CD-Rom plug, but its the same form factor as a floppy drive power connector. NOT, the kind that is smaller, and keyed (which I associate with CD-Rom connectors).
Does anyone know of adapters that would fix this, not sure what the smaller connectors name is, its 4 pin, fits into a square socket, which is keyed on one side.
Cheers
Chris Thomas
aka Retronaut @ https://www.youtube.com/@RetronautTech
Support me @ patreon.com/RetronautTech
Reply 2 of 6, by BitWrangler
You get variances when the card was OEM for Dell or HP etc and they specified a different hookup to match their case hardware.
There were three common styles and you can get them all covered with "Universal CDROM audio" cables like this one...
https://www.cableleader.com/25in-universal-cd … udio-cable.html
Link for illustration purposes, I have no idea whether that store is legit or not.
Reply 4 of 6, by Retronaut
BitWrangler wrote on 2024-02-21, 17:54:
You get variances when the card was OEM for Dell or HP etc and they specified a different hookup to match their case hardware. […]
Thanks for the link. Yep, its the black connector on the card, whilst my cable sports the white connector. Looks like I need to order one of these.
Thanks
Chris Thomas
Reply 5 of 6, by insanitor
Make sure you check the documentation of the sound card to see how the connector is wired up. Look at your CD-ROM to see which are the ground, L and R connections are. There is no standard and the L and R connections can be reversed or worse. If so, you need to get a pin and rearrange the connector pins.
When I go, the smiles and the laughs go with me.
