First post, by mikesk8
Hi All,
My Roland is connected via Roland UM-One USB adapter to the iMac, and via headphone/line output to Roland's SC55 Audio inputs. The idea was to mix input sound from iMac with Roland music MIDI together, e.g. play games that enable both music via Roland and effect/speech via Sound Blaster.
However, I don't get any sound from iMac in this setup when using headphones connected to Roland. I am not sure if it's related to the fact that mixed music/input is available only via Roland's audio output and not via headphones? or I am doing something fundamentally wrong.
Do you have any ideas?
Thanks, M.
