First post, by LubieCipy
I have a few VGA cards that hang on the desktop after installing drivers. What could be the reason for this behavior?
Reply 2 of 8, by Con 2 botones
Hello there.
If you are trying those few cards in the same system, and all of them exhibit the same behaviour, then I would suspect they are not to blame, but the system itself (motherboard, Agp slot, PSU, etc).
Have you tried those same graphic cards in another configuration (mother+ram+cpu+gpu)?
Maybe I misread or there wasn´t enough info included in your post.
Reply 3 of 8, by Standard Def Steve
I had a similar issue with an old Soyo 440BX motherboard ages ago. It would just display a blank screen after loading the display driver, but you could hear Windows load in the background.
That board just didn't provide enough current to run the GeForce2 GTS and GF3 I had initially tested. However, it was absolutely fine with a TNT2, FX5200, and even a Radeon 9800 Pro (thanks to the auxiliary power, no doubt).
"A little sign-in here, a touch of WiFi there..."
Reply 4 of 8, by LubieCipy
This problem occurs with i740 and similar cards. I think I checked them in two boards with the via694 chipset. The power supply is probably ok because all the Geforce cards work fine.
Cards work fine in safe mode at 640x480 and 16 colors but after installing the drivers and rebooting it hangs before entering the desktop.
Thanks for tips. I will check the cards on the boards with the i815 and KT333 chipsets. What could be wrong with the cards?
Reply 5 of 8, by Grzyb
Make sure that chipset drivers are installed.
Reply 6 of 8, by LubieCipy
Grzyb wrote on 2021-12-08, 10:31:
Always 😀
I have other cards with i740 chip that do not cause problems
Reply 7 of 8, by BinaryDemon
On a modern OS, that usually means bad GPU. I thought for Win9x in some cases a bad GPU won’t cause an issue until you actually run something that makes use of 3D acceleration.
Reply 8 of 8, by LubieCipy
I checked two other motherboards, TUSL2-C and GA-7VRXP that behave similarly and cards hang on the desktop after installing drivers. Additionally, I checked the other faulty cards, one of them is not detected and the second freezes freezes the system while loading even before the desktop appears
