Windows 95 Build Question
First post, by MetalMilitia
Hey guys. I’m looking to put together a Win 95 build based around a Pentium II 233. I was wondering what a somewhat “period accurate” graphics card might fit with it. I would love to use a voodoo 1 but eBay prices are still crazy on them. If I do go that route, what’s a good pairing for it?Any suggestions would be appreciated!
Reply 1 of 20, by leonardo
There's tons. ATi has the Rage-series (both PCI and AGP). Rage 128 Pro is probably on the faster end of all that. Anything with S3 plastered on it is period correct, if not always completely desirable. Matrox has the Mystique and Millennium series with the G200 likely being the top of what you'd see in a Pentium II-system. The G400 is also good on the higher end, and went up against the TNT and TNT2-based cards from nVidia. All of those are also excellent alternatives to a 3Dfx-card. Matrox tended to have the best analog signal quality, but unless you're using a big CRT with a resolution above 1024x768, you probably wouldn't notice it. TNT2/G400/V3 are roughly comparable in performance for 3D-gaming, each with their own particular strengths and quirks, shall we say.
[Install Win95 like you were born in 1985!] on systems like this or this.
Reply 2 of 20, by Cuttoon
That CPU was introduced in 1997 and surpassed by the "Deschutes" line of P2 in 1998:
https://en.wikipedia.org/wiki/List_of_I ... 2_(350_nm)
Strictly by time period, that would correspond with a Riva 128 card by Nvidia:
https://en.wikipedia.org/wiki/List_of_Nvidia_ … its#Pre-GeForce
But the TNT and TNT2 are much more common and affordable to find.
Else, Matrox G200 - probably better VGA signal for a CRT.
Or ATI Rage 128, S3 savage, but the latter is almost rare, I'd say.
I like jumpers.
Reply 3 of 20, by Con 2 botones
I believe G200 is from 1998 as well as Rage128.
Ati 3D Rage Pro and nVidia Riva128 are 1997 hardware (both still available and inexpensive in AGP form).
Reply 4 of 20, by acl
I have a thing for Intel 740 cards. (I have a thing for weird stuff)
Performances are Ok-ish but iirc some operations are not very well implemented (transparancy ? Filtering ?)
But that's an original/unusual card that you can have for cheap.
Reply 5 of 20, by MetalMilitia
Thanks for the suggestions guys! I think I have a Rage 128 kicking around so I might try that first before buying others
Reply 6 of 20, by MetalMilitia
Alright so I had a Rage 128 Pro. Installed Windows 95 drivers and now I get an error on startup saying "Invalid VxD dynamic link call from ATI2VXAA(01) + 000247EE to device "VMM ", service 1AE. Your Windows configuration is invalid. Run the Windows Setup program again to correct this problem."
Generally when I get past this error it boots fine, but I am having issues running 3D applications. Any ideas on how to fix this? Is it a bad driver?
Reply 7 of 20, by leonardo
MetalMilitia wrote on 2022-05-20, 18:42:
Did you have DirectX 7 or 8 installed before you installed the video drivers? I've found not having an up-to-date version of DirectX sometimes causes video- and sound-card drivers to bug out or not install correctly.
Reply 8 of 20, by flupke11
acl wrote on 2022-05-11, 12:26:
A bit off topic:
Riva 128 or i740 was the staple AGP card with the arrival of the i440LX platform. I also have a lot if i740 cards, some with cooler, some with just a heatsink and some with the chip exposed. The i740 cards I have that were made by Intel were built to last till Kingdom come.
Reply 9 of 20, by MetalMilitia
leonardo wrote on 2022-05-22, 14:56:
It actually wouldn’t let me install the drivers until DX6 was installed. Once I did that it installed then I started getting the error. I used the Catalyst installer. I wonder if I should’ve just tried to point it to a driver instead.
Reply 11 of 20, by leonardo
Seems like it could be a bad driver. I found this support article which seems to detail the particulars of your error. I don't know if it will be helpful or not. Where did you find the driver? Do the errors go away if you uninstall through the Control Panel?
Reply 12 of 20, by MetalMilitia
Ok so I got the error to go away but now I have no Direct3D acceleration. I’ve uninstalled and reinstalled a couple of times to no avail
Reply 13 of 20, by leonardo
MetalMilitia wrote on 2022-05-24, 01:48:
Are you confirming the absence of Direct3D by testing specific games or with DirectX Diagnostics? If the latter, what's it say with regards to the driver?
What's the precise driver and source? ...and which exact Rage-card is this? AGP/PCI?
ATi was slightly confusing as for their drivers in the 90's... which is the reason many people went with other brands then - not necessarily because their cards weren't performant.
Reply 14 of 20, by STX
MetalMilitia, you are using Windows 95B or 95C, right?
Reply 15 of 20, by MetalMilitia
STX wrote on 2022-05-24, 13:56:
Yes I am using OSR 2.5.
I will check on the specs today and post them up from DXDiag
Reply 16 of 20, by Jasin Natael
Probably the wrong driver version. As much as I love ATi cards.....anything previous to Radeon had dodgy drivers and a straight up confusing mess of a product stack. Throw in the various OEM versions and it gets even worse.
Reply 17 of 20, by MetalMilitia
So I pulled the card out. The PN is 109-63100-10. According to the Vogons Wiki, it is a Rage Fury Pro. Could this be the problem? I've been looking for Rage 128 Pro drivers the whole time.
Reply 18 of 20, by leonardo
MetalMilitia wrote on 2022-05-25, 20:16:
Hmm... confusingly those seem to be different monikers for the same card? ...or the Rage Fury uses the Rage 128 Pro-processor or something like that? Good ol' ATi...
See Phil's page for example.
