First post, by Brawndo
I am working on finishing up a few 90s builds and still debating on what components to put in which system. The first one I'm working on finishing up is a Pentium 233 MHz system with 64 MB SDRAM which I plan to use for DOS/Win98, and I'm pretty sure I'm going to use a RIVA 128 as the primary graphics card. My initial thought was to pair it with a single Voodoo2 card for 3dfx games, but given the relatively limited performance of the CPU I wonder if that would be a wasted use case for having a Voodoo2. I also have a Voodoo1 which I am planning to possibly use on a 486 DX/4 in conjunction with a S3 Virge, but wondering now if it would be better to put the V1 in the Pentium computer.
For what it's worth I have quite a few systems so I don't need one or even a few computers to cover all bases. I currently have a V1, 5 V2s, a V3 and a V5 and I plan to build a couple of computers around V2 SLI, so I'll have high performance 3dfx covered. I'm just wondering specifically in this case if a V2 in a Pentium 233 build would be too limited. I only plan to use this system for later DOS and early Windows 95/98 games.
I guess to better help answer my question, can the games which are only compatible with a V1 run well enough on a 486 DX/4 or even a DX/2??
Reply 1 of 13, by leileilol
Not wasted.
There's a lot who always urge to give a P3 1GHz+ so it can "max out" for some forsaken bungholiomark, but no it ain't wasted. There's driver and multitexturing benefits that similar cards of its generation don't do as well (Rage Pro, G200, i740, etc). It'll even do better than a Voodoo Graphics on a 486 due to that.
The Voodoo2 starts showing its age and thrash quite a bit on games from late 1999 that'll be slow on a P233 regardless of video card anyway, and a second in SLI won't overcome that.
Debian's fucked
Reply 2 of 13, by Brawndo
Cool thanks, that helps. For the record my "maxed out" 3dfx system is a P3 1 GHz with a Voodoo 5500 so that'll easily handle all the most demanding 3dfx games.
Reply 3 of 13, by BitWrangler
How I am going to deploy my semi-imaginary (I haven't got them all found yet) Voodoo2 arsenal is, the 8MB goes in a good spec P233MMX system, the pair of 16MBs go in a 400Mhz system, and the odd 16Mb goes as compatibility enhancement/enforcer in the system I can get the best XT to near Ghz range out of. But I also have V3s that may go in 500-800mhz machines.
edit: as imi points out below, 16MB v2s do not normally exist, I would be talking about 12MB cards.
Reply 4 of 13, by maxtherabbit
My dual voodoo2's are in a dual pentium pro 233 system. Happy with it, but 266 would offer a little more headroom
Reply 5 of 13, by rmay635703
maxtherabbit wrote on 2022-07-18, 00:29:
I always had trouble getting beyond 250mhz on ppro (and had to carefully select)
I always thought Intel gave a royal screwing to Socket 4 and Socket 8 by not offering newer / faster clock chips back in the time they were relevant
Reply 6 of 13, by imi
BitWrangler wrote on 2022-07-18, 00:04:
16MB Voodoo 2s?
where do I get myself one of those ^^
Reply 7 of 13, by BitWrangler
You take an 8MB Voodoo 2, and think "derpy derp derp, what's dat one with double the texture memory, derpy derp?" and come up with 16, coz you forgot that double the texture memory is double 4, not double 8... and just like that, 4+8 = 16... brainfart maff.
Reply 8 of 13, by Kruton 9000
In my opinion:
Pentium (models strarting from 1994) , Pentium MMX fits Voodoo 1
Pentium MMX , Pentium II fits Voodoo 2
Pentium II fits Voodoo 2 SLI x2
Reply 9 of 13, by imi
BitWrangler wrote on 2022-07-18, 03:37:
we all have our derp moments 😁
I have a Voodoo 2 with 8MB and 83MHz memory in my 233MMX
Reply 10 of 13, by bloodem
It definitely depends greatly on what games you're playing and the resolution, but according to my tests, a Voodoo 2 can actually bottleneck a 266 MHz PMMX at 640 x 480 in games like GLQuake!
In other games, however (Quake 2, Unreal), the CPU will definitely bottleneck the Voodoo 2 even at 800 x 600.
Anyway, what I do know is that, for the games I play and the resolutions I play them at, more often than not I go with a Voodoo 3 when testing P MMX233 platforms (which I usually overclock at either 266 or 292 MHz).
So, no... IMO, a Voodoo 2 is not wasted on a 233 MHz PMMX. In fact, the card will actually be less stressed and run cooler. 😁
The Voodoo Banshee PCI is also a very good option if you're more into single textured games running @ 640 x 480. There are also some games where the Banshee is actually usable at 1024 x 768 (at period correct framerates, that is). 😀
As for Voodoo 1, I only use it on P166(MMX) or slower, and purely for its historical value. It severely bottlenecks higher speed Pentium MMX CPUs.
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 21 x Slot 1 / 8 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 11 of 13, by 386SX
Last time I tried a Voodoo2 8MB in a P-MMX 233 config it felt like a good balanced choice for a fast MMX machine that needed a last upgrade.
Reply 12 of 13, by Brawndo
OK I'll stick with my original plan and use a Voodoo2. I'm happy about that as the video cards will both be STB, a Velocity 128 and Black Magic 3D, so that will add a little extra "cool" factor to the build.
Reply 13 of 13, by Aebtdom
The current setup I am using is a 233MMX with a vd2 SLI setup.
And my conclusions are:
There is litterally no game that maxes out the card and the reason I use this combination is that it will run games in 1024x768 with no loss in performance.
If your CRT is up for the task you can even run it @ 120Hz.
Also the multi texturing is a great advantage in games like Unreal and Quake2.
It will run most msdos games that supports 3Dfx voodoo1 with the proper patches.
I have made a few video's where you can see it performing in win98SE.
https://youtu.be/-0-fwseSKgk
And a Q2 with Unreal benchmark
https://youtu.be/OdXKTVfvqQo
Warning it has been done really ammateuristic, since I have no capturing hardware at my disposal.
Builds:
Xp3000+ radeon 9600XT + vd2 SLI 12MB + 512MB + SB live @ WinXP & 98 Dualboot.
AMD K6-3+ 600Mhz+ Geforce 3 Ti 500 + 3Dfx Voodoo 2 12MB SLI + Sound Blaster 32 + 128MB SDR @ msdos / win98.
