First post, by matti157
- Member
Hello,
the pc is a Pentium MMX 233 socket 7. i would like to add a Voodoo2 card
The chipset is a Triton-VX
These are the PCI specifications instead. I had tried other Voodoo2 cards in the past but they had artifacts (it was not to be ruled out that the cards were broken)
PCI Bus The fully synchronous 30/33 MHz PCI bus originates in the chipset. Features of the PCI bus are: Zero wait state microp […]
PCI Bus
Zero wait state microprocessor-to-PCI write interface for high performance graphics
Built-in PCI bus arbiter with support for up to five masters
Microprocessor-to-PCI memory write posting with 5 Dword deep buffers
Converts back-to-back sequential microprocessor-to-PCI memory write to PCI burst write
PCI-to-DRAM posting 18 Dwords
PCI-to-DRAM up to 120 MB/sec bandwidth
Multi-transaction timer to support multiple short PCI transactions within one PCI ARB cycle
PCI 2.1 compliant
In terms of specifications is my pc compatible?
Thanks
