Reply 20 of 45, by Robhalfordfan
- Oldbie
mbliss11 wrote on 2020-07-09, 10:49:That's awesome! Glad it worked out! I will check out those drivers with my M64 as well and see how they fair. I cannot remember which I used when I installed mine however none of the additional settings worked when I tried to adjust anything in the control panel.
On another note I have decided to go with another upgrade for the socket5 and acquired a powerleap upgrade kit with a few AMD CPU's that i am going to try out (K6-2 400, K6-3 400 and K6-2+ 450). The adapter and some of the chips should be arriving today interested to see the performance gains that this will provide with the M64. Been having a lot of fun hacking this thing up to boost its performance up to the max!
thank you and i can't remember what i did or how i did it to get the additional setting working but i am trying on another clean install of windows 95 and will put how i did it on here because i can't remember if i went to straight to v6.31 or install older or later version and install on top or uninstalled etc
thats good to hear and good luck with upgrade and fingers crossed 😀
i am thinking of upgrading the cpu to p233 mmx and maxing the ram out but will see how this goes first
