First post, by Azarien
This is D201GLY2A mainboard and 2 GB RAM, removed from a mini-ITX chassis that's gonna get all new modern(ish) guts.
The integrated SiS graphics is not very good and works reasonably well only under Windows XP. It didn't work in Linux with acceleration last time I checked, is buggy in Vista, buggier in Win7, and not supported at all in Win8.
But there is one normal PCI slot, so I though I'll install the mainboard in ATX chassis to make use of that slot. The question is - what card should I look for? Are there any (reasonably priced) PCI cards with drivers compatible with Vista or later? What about x64?
Or should I stick with XP?
