First post, by jesolo
The card pictured below is working perfectly fine. However, I don't quite like the default font that the BIOS chip is using on this particular card.
1.22 MiB
ET4000/W32i card
Refer the screenshot where you can see that the lowercase letter "L" has a curl at the bottom.
447.92 KiB
ET4000/W32i POST screen
I'm hoping that someone out there can perhaps dump the Video BIOS ROM of their ET4000/W32i card that perhaps has a more "standard" font (or point me to a location where I can download an ET4000/ W32i BIOS ROM from).
Reply 1 of 6, by mkarcher
jesolo wrote on 2023-03-08, 18:16:
Well, you can dump your ROM easily using debug or NSSI. Finding the embedded fonts in VGA ROM images isn't that difficult (e.g. by looking for the zero bytes for the NUL character and the zero bytes for the space character 32 characters later). Overwriting the "typical Tseng font" with an IBM font is straightforward, as is fixing the checksum. Patching a new font into the ROM for your card is the better approach compared to trying a foreign ROM on your card, because not all ET4000/W32 are equal, e.g. the clocks provided by the clock chip might differ.
Reply 2 of 6, by jesolo
mkarcher wrote on 2023-03-08, 20:22:
I completely understand what you are suggesting. Unfortunately, my knowledge of how to perform this is a bit limited. But, let me explore a bit more based on your suggestion.
Reply 3 of 6, by Tiido
I actually had the same complaint about lower case L in my ET4000/W32i card and I ended up doing a font hack for it. I don't know if my font is to your liking and if the BIOS will even work but I have attached it to this post.
EDIT: Found photos of how it looks like
There were a few chars that were still original, I found there were several "fixup" chars in other part of the BIOS that also had to be changed, the photos predate this but the attached BIOS has them fixed. I am not sure why char 92 didn't show up on the photos in QB45 charset screen, but it certainly worked elsewhere.
    342.01 KiB
    Font example 1
    279.5 KiB
    Font example 2
    TsengFontHack.zip
    16.51 KiB
    45 downloads
    Tseng ET4000/W32i BIOS with Tiido's custom font
Reply 4 of 6, by jesolo
Tiido wrote on 2023-03-09, 06:24:
Thank you so much. I'm going to give this one a try and report back.
Reply 5 of 6, by jesolo
Thank you for the BIOS ROM - I've attached a screenshot with your BIOS ROM loaded.
678.84 KiB
W32i with updated BIOS
Reply 6 of 6, by Tiido
Nice ~
I just noticed that your BIOS is actually a bit newer than mine is. It would be good to have a dump of it too.
