First post, by Xenphor
I bought a new old stock Geforce Quadro 4 380XGL and would like to replace the thermal paste since I assume it's pretty dried out by now. Unfortunately, the push pins on the heatsink are very hard to work with. They don't really depress at all from the front of the card and are nearly impossible to grip from the back of the card. I have a small pair of diagonal pliers, but the pins are too small to grip and I don't want to scratch the PCB. Has anyone worked with this model before? Here are some pictures of what I'm talking about:
Reply 1 of 10, by paradigital
You need to pull the center of the pins out of the top first. A pair of needle-nose pliers should be all you need.
Reply 2 of 10, by pentiumspeed
Pull the center pin slightly and you can now then squeeze the barb and push it through.
Cheers,
Great Northern aka Canada.
Reply 3 of 10, by Warlord
Theyre litterally all like this, after you pull the pin out use some small needle nose plyers and squeeze the bottom barb gently without crushing the plastic and pull it out the otherside with your fingers.
Reply 4 of 10, by Xenphor
I'm just having a very hard time getting a solid grip on them at all with needle nose pliers and I've already scratched the heatsink a bit. They don't really budge at all if I pull from the top.
I noticed the top of the pins seem to have a very small hole in them maybe? So would threading a wire in there and pulling be a good idea? Is that even what I have to pull on? I don't know what I would use.
Other push pins I've used I would push down on the top and then squeeze the barbs at the bottom to release them.
Reply 5 of 10, by paradigital
To clarify, when you are pulling the pin from the top, you are only pulling this bit, right?
The attachment IMG_2070.jpeg is no longer available
You don’t need to pull this bit completely out (though it won’t do any harm to), just enough to allow the part of the pin on the underside of the board to be compressed slightly for pushing through the PCB.
Reply 6 of 10, by Xenphor
paradigital wrote on 2023-06-18, 07:25:
Yes. It is very stiff and hard to grip even with pliers. I also don't want to make too many attempts because of the pliers marring the surface.
Reply 7 of 10, by paradigital
You might be able to use a small jeweller’s screwdriver from the bottom of the pin to push the center part upwards, also you might try a thin lubricating oil on the center part of the pin to free it up.
Finally, there are slotted/u shaped/fork screwdrivers available that might be better to lever with:
https://amzn.eu/d/htJ2Br9
I’m not recommending these as I’ve not measured the sizes, this is just an example of the type of screwdriver!
Reply 8 of 10, by Xenphor
paradigital wrote on 2023-06-18, 07:56:
You might be able to use a small jeweller’s screwdriver from the bottom of the pin to push the center part upwards, also you mig […]
Alright thanks for the suggestions.
Reply 9 of 10, by Xenphor
Upon further inspection, the card doesn't seem to use thermal paste from what I can see:
Would a pad like this need to be replaced?
Reply 10 of 10, by pentiumspeed
Heat up the heatsink with hair dryer, Twist while hot, not prying or pulling.
Cheers,
