Reply 642 of 648, by cyclone3d
On what page did this change to any hardware instead of period correct hardware?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 643 of 648, by Standard Def Steve
Today I slotted a "new" Quadro FX 4500 in Super G5 and did some benchmarking with Quake 3, Quake 4, Doom 3, UT2004, and Prey.
Here's the Doom 3 result. Keep in mind that, unlike the PC version, Doom3 for Mac only uses a single core. Plus, it's one of the worst ports ever. Aspyr didn't even *try* to optimize this game for PowerPC. To get an idea of just how sloppy it is, consider this: Quake 4 actually runs at a higher frame rate on this machine!
PowerMac G5 Quad: 2x dual-core PowerPC 970MPs at 2.5GHz, 16 GB DDR2-533, Quadro FX 4500 PCIe, OS X 10.5.8
1024x768 Ultra:
1.08 MiB
The G5 is nearly three times faster than the G4, which at 1.5GHz w/ a 7800GS AGP, only manages 27 fps!
Reply 644 of 648, by DosFreak
Built a new living room PC but it temporarily has my old 1080ti in it for now.
Anything goes toplist
828.36, DosFreak, 7950x@4.5 GHz,ASUS ROG Crosshair x670E Gene,32GB DDR5 6000Mhz CAS 30,ASUS ROG GeForce GTX 1080 Ti 517.48, Realtek, 11x64 22H2
Doom 3 v1.0
Won't be too long before we hit 1k!
Make your games work offline
Reply 645 of 648, by flufetor
Hello,
Want to add stats for a single module trinity APU, usinng integrated Terascale 3 graphics:
AMD A6-5400K APU, Gigabyte F2-A55M-HD2, 4GB 2 x2GB GSKILL 2133 DDR3 F31700CL9D-4GBXL CL9-11-9-26 1.6V. SO: Windows XP SP3.
Stock CPU@3.6GHz & GPU@760MHz clocks, 1600MHZ DDR3 speed: 65,7FPS
CPU@4,4GHz, GPU@1024MHz, XMP 2133 DDR3 speed: 83,2FPS
Reply 646 of 648, by Skyscraper
It's nice to see more results added.
I have not given up on this project and the new results will be added to the list sooner or later but not in this instant as I'm on a low res screen.
Reply 647 of 648, by agent_x007
Perfect score 😁
file.php?id=179424&mode=view
^NV build-in audio (since MB one doesn't have drivers for XP)
EDIT : 666.5, agent_x007, 5800X3D@4.55 GHz, Gigabyte B550 Aorus Pro v2, 32GB DDR4 3800MHz CAS 14, ASUS GTX Titan X 368.81, NvIdia (build-in audio), XPx86 SP3, Doom 3 v1.0
Reply 648 of 648, by AntonPC
agent_x007 wrote on 2023-11-26, 02:28:
Perfect score :D https://www.vogons.org/download/file.php?id=179424&mode=view ^NV build-in audio (since MB one doesn't have driv […]
Perfect score 😁
Hahaha, indeed, the perfect score for Doom 😀
Will try to contribute to this thread sometime soon.
