Worst fastest early 3D cards
First post, by 386SX
Hello,
I was looking for info about the fastest and better built worst but also awesome video cards of the usual late PCI early AGP accelerators to test the highest factory clocked ones. Specifically I might look for something like the Alliance aT3D and the Cirrus Logic Laguna3D or the (not that bad) i740 and SiS cards. Beside the not interesting lower clocked versions, which were the absolute fastest and possibly better built chips/cards/brands? I know most of these were built by low end manufacturers but I suppose few ones might have had a good layout and components.
Any suggestions? Some specific chip versions to look for or advice to find the later better clocked ones? I remember the Cirrus Logic having a late C revision that I think it was a lower power version but I don't care about power demand, just want the best/fastest design to test these to the limits as supposed to run at best. I don't want to buy an expensive card that run at the lowest clocks.
Thanks
Reply 1 of 249, by agent_x007
Main problem with early cards is image quality under 3D workload.
Some are VERY broken, so comparing them based on performance metric is meaningless (since they can't display the same [correct] image).
Reply 2 of 249, by 386SX
agent_x007 wrote on 2024-03-06, 20:08:
Of course but everytime I watch the YouTube reviews of these cards I am sort of impressed they may have been even worse and I'd like test the fastest ones myself.
At the end honestly they don't look that bad with the right time correct balanced expectations. The Alliance aT3D ok might have been a disaster but probably needed a whole LOT of driver development to even find a low end usage in a early 3D rendering. The Cirrus Logic Laguna looking at games/results even if probably with some serious design/choice problem wasn't really bad too, just late and slow to the competition and still drivers. The Trident 3DImàge975 serie also not really that bad at least in average rendering accuracy I was expecting less and Trident really improved all that with the impressive later low end products still releasing in that complex period.
But I suppose just like the S3 Virge serie, most of these solutions were built in slower cheaper revisions/pcb while maybe (beside the broken graphic) only the best ones should be tested.
Reply 3 of 249, by DrAnthony
Well there certainly were other cards that were far more common but just as slow like the ATI 3D Rage and Rage II. Chromatic Mpact! and Mpact2 are other options if you're looking for really weird stuff.
Reply 4 of 249, by The Serpent Rider
Alliance aT3D - simply does not work properly in any 3D.
Cirrus Logic Laguna3D is usable only in AGP revision and specifically without any bilinear filtering used. This card has a hefty performance penalty for filtering textures.
Reply 5 of 249, by Trashbytes
Some S3 Virge cards and Riva 128 cards come to mind here, cheap Riva 128 cards can be all sorts of terrible for image quality and Virge can be a hit or miss depending on the Vbios used. There are a lot of early ATI cards that are so broken that you need several different driver versions on hand to switch between to get certain 3d functions working with games.
I own the rather infamous ATI Fury MAXX and its one of the most pedantic cards to actually get running due to how fussy it is with AGP and even when it is running its performance can be truly abysmal due to drivers being broken.
Even 3DFX is not immune to terrible image quality, Voodoo Rush anyone with the Alliance 2d chip ..yeah not a great combination, cheap pass through cables can also make for poor image quality.
Reply 6 of 249, by The Serpent Rider
Riva 128 technically had meh rendering quality, but then you remember that there were very loose standards back then and your real gaming options in 1997 were 3Dfx or Nvidia. With everything else being even more terrible or too obscure to even consider.
Reply 7 of 249, by leileilol
The Serpent Rider wrote on 2024-03-07, 02:22:
powervr pcx2 erasure. smh
+ 24-bit always, dithers in post (NO FUNNY OVERDRAWS)
+ image quality as high as your host because it's through the bus
+ Fast enough for Unreal (and supported by Unreal at launch. is SGLDrv a joke to you?)
+ hardware alpha with modulation!!!
+ 1024x768 tomb raider!!!
+ available at US$99!!!
- Need a decent FPU for the drivers (Pentium II's a good match)
- Less blending functions, but in 1997 with early DirectX being barely able to 3D and gamedevs targeting a tech art balance for software rendering and the first gen 3d, it's no big deal for 1997
- No GL ICD but that's ditto for everyone until 1999 anyway.
Reply 8 of 249, by BitWrangler
There is a Diamond version of a SiS-6326 which might be the most sorted version... or it might be relatively early, there were meant to be some tweaks in later revisions that made them faster and more stable. Was glancing through the 6326 data sheet the other day, lots of mostly untapped potential in it seems like. Be great to discover one with ALL the features broken out.
Reply 9 of 249, by Trashbytes
I remember a good quality 128 ZX was about on par with a VooDoo for quality, I mean neither card was what we would consider great now but for the time its was ok when used with a good CRT.
I think we forget that a good CRT could help with poor picture quality.
Reply 10 of 249, by BitWrangler
A bad CRT helped even more, penalty free AA 🤣
Reply 11 of 249, by Jo22
BitWrangler wrote on 2024-03-07, 03:34:
A bad CRT helped even more, penalty free AA lol
For 320x200 resolutions, a small SCART TV might be good, err, bad enough.
These consumer CRTs had a big dot pitch, so all the ugly details were being smoothed out. No aliasing artefacts.. ;)
Reply 12 of 249, by Trashbytes
Jo22 wrote on 2024-03-07, 03:37:
These consumer CRTs had a big dot pitch, so all the ugly details were being smoothed out. No aliasing artefacts.. 😉
Haha very true !
Reply 13 of 249, by Trashbytes
One could say the Riva128 came with that already, its image quality could be uhhh very blurred.
Reply 14 of 249, by BitWrangler
Early noughts I had Battlefield 1942 on a 30" CRT TV out of the video out of my GF3 at 800x600 and that wasn't bad to look at.
Reply 15 of 249, by leileilol
My monitor throughout the 90s was a trinitron-like so I didn't have any of this "blurry dot pitch is the only retro way" crap. I saw all the dithering and jaggies and the scanlines on 70hz+ stuff etc. If there's obviously bad image quality, i'd know. I only knew about what it could look like switching to an nVidia *after* the 90s.
Reply 16 of 249, by 386SX
Not common chips/cards like the Mpact seems very interesting. As far as I remember many of these felt having good specifications and who knows how they could run with a serious driver evolution, like the late Rage II engine drivers that at least gave a good compatibility.
The Riva128 in the Diamond pcb was a nice card with great output signal and the rendering feel cheaper but unique. But some high end pcb with other less known alternative chips are more interesting. It'd great to find reference or prototype cards of those early accelerators.
Reply 17 of 249, by The Serpent Rider
Nope, just too obscure.
Reply 18 of 249, by midicollector
I’m not sure the exact qualification here like it’s a little unclear if we want the worst but also functional or something. Anyway here’s my take:
One of the late S3 cards
Trident blade 3d or another of the late trident cards
Maybe a rendition verite based card
Reply 19 of 249, by ubiq
I was installing Descent 2 a month or so ago, and it specifically prompts to install the S3 ViRGE accelerated version. I happened to have a ViRGE card, and never used one back in the day so decided to check it out. And... holy moley it was bad. Bad to nearly unplayable frame rates, even for the time, and blurry image quality. Then, trying it in 2D mode 640x480 on the same card and got very smooth fps and sharp image quality. This was on a 233MMX system. So, in this case the card was acting as a 3D decelerator and a huge bottleneck. 🥴
