First post, by luke7110
Hi all, I'm trying to repair a Monster 3D with storage damage. Some traces were cut and smd components damaged. They may need to be replaced.
Is there a component map for this card ?
Capacitors C43 and C84
742.29 KiB
1.74 MiB
1.93 MiB
1.9 MiB
1.75 MiB
Reply 5 of 17, by sdz
-scrape the soldermask off a bit, apply flux and tin the traces with solder.
-take a small diameter wire, apply flux, tin it.
-apply some more flux on the board and solder the wire in, trim excess wire with a scalpel blade after soldering
-clean with IPA
-optional apply UV curable green soldermask
Reply 6 of 17, by appiah4
luke7110 wrote on 2024-05-07, 13:07:
Yeah, I think I'll need a good technique to fix these traces neatly 😅
Check out Bits und Bolts videos on YT for very good trace repair examples. Necroware also has some very good repairs documented.
Reply 7 of 17, by luke7110
sdz wrote on 2024-05-07, 14:00:
-scrape the soldermask off a bit, apply flux and tin the traces with solder. -take a small diameter wire, apply flux, tin it. -a […]
-clean with IPA
Thanks for the guidelines, what do you advise for the wire ? I saw people using a wire taken from an unsoldering braid.
appiah4 wrote on 2024-05-07, 14:01:
I'll check it out, thanks ! 👍
Reply 10 of 17, by technokater
You might need to get UV light for that as well. The solder masks I used so far needed UV light for curing. If you haven't one already. It is generally written in the spec if you need UV for your particular mask.
Reply 12 of 17, by luke7110
technokater wrote on 2024-05-07, 16:25:
I have an eprom eraser, it should work?! 🤔
Reply 14 of 17, by luke7110
technokater wrote on 2024-05-08, 07:04:
I use an UV flashlight that's not very powerful and consistent in illuminating but it works, so I think yours will work too.
Ok, I'll keep you posted ! Thanks 😉
Reply 15 of 17, by luke7110
Bits und bolts ... a real gold mine!
However, I think I'll begin with some nasty wire bridges in order to see IF the card could be repaired, then I'll do it the fancy way 😎
I read that windows install with previously installed Voodoo2 drivers could make interferences with drivers and prevent a voodoo 1 card from working. Do you agree with that ? I only have Voodoo 2 cards and therefore voodoo 2 configured retro pcs, so I maybe should reinstall a clean windows 98 before trying to do a diagnostic ?
Reply 16 of 17, by Thermalwrong
That's my experience with switching between a Voodoo 1 then a voodoo 2 and back again. The computer would freeze on a turqouise display when trying to switch to 3d mode.
I ended up doing a clean install and now run 2 separate compact flash cards on that test computer to go between V2 -> V1
See my post here: Re: 3Dfx Voodoo 1 - Low level hardware information and diagnostics thread
You can verify by running tomb raider in DOS which isn't tied to the Windows drivers in the same way.
So either clean install or 100% clear out the V2 drivers before putting the V1 back in, as in search the windows folder for every file in the Voodoo 2 driver folder and delete that before proceeding.
