QX9770 + HD 3850 AGP vs. 3DMark's and Games :)
First post, by agent_x007
If anyone's got results for Phenom II x4 with 4670 AGP or 3850 AGP GPU's... please share.
I need them for comparison 😉
Setup :
CPU : Core 2 Extreme QX9770 (C1) @ 3,84GHz (+VID Mod = 1,3875V) [BOX cooling]
MB : ASRock 4CoreDual-SATA2 R2.0 (BIOS : L2.20) [FSB = 256 MHz]
RAM : DDR2 2x2GB @ 682MHz CL5.5.4.12 CR2T and "High" Vdimm 😉
GPU : HIS HD 3850 512MB AGP IceQ3 (stock = 710/1818 MHz), Catalyst 10.2 driver.
HDD : Samsung F3 500GB (HD502HJ)
SPU : Audigy 2 ZS (w/EAX 4.0 driver)
PSU : OCZ ZS-750 (750W)
OS : Windows XP SP3 Pro (x86)
SuperPI/Cache & Memory test : LINK
Results :
3DMark 03 : LINK (35 521 pkt.)
3DMark 05 : LINK (20 495 pkt.)
3DMark 06 : LINK (11 504 pkt.)
Quake III Arena v1.11 (1024x768@32-bit max. quality) : 909,5 FPS
Doom 3 v1.0 (Preset "Ultra" @ 1024/768) : 238,4FPS
Crysis v.1.2.1 (Crysis Benchmark Tool : "gpu_benchmark") :
Preset "Low" (Full HD) - Avg. 92,96 FPS, Min. 53,06 FPS
Preset "Medium" (1024x768) - Avg. 89,81 FPS, Min. 40,94 FPS
Preset "Medium" (Full HD) - Avg. 46,37 FPS, Min. 34,27 FPS
Reply 1 of 35, by rick6
Not a Phenom II X4 by any means but least it's better than nothing.
Athlon X2 4200+ with DDR1 memory:
And here a few more games and video cards tested
23 video cards VS Quake3 Arena, UT99, UT2k4, Painkiller, Doom3, 3DMark 2000/2001/2003, enjoy!
EDIT: I just noticed you're the last one posting on the thread so it's nothing new to you. Still, maybe someone else could reply to you now 😀
My 2001 gaming beast in all it's "Pentium 4 Williamate" Glory!
Reply 2 of 35, by Jade Falcon
Rank BANNED
BANNED
I seem a voodoo6k get a tick under 1k fps in quake 3 before.....
Zoomed in at a wall.
Reply 3 of 35, by rick6
ah! That's what i did back in the day back in 1999 with unrealtournament while running it in software mode with my AMD-k6 in order to boost my damaged ego. Staring at a wall at 320x200 with low res textures. 45-50 fps oh yes 🙁
Still, i wish i had a QX9770 and a board supporting both this cpu and AGP so that i could redo all my benchmarks that i did with my Athlon X2 4200+.
Reply 4 of 35, by agent_x007
Let me help you with it 😀
I got all 3DMark's from '99 Max till '06 as well.
I added E5700 @ 4GHz and P4EE 3,2GHz @ 3,53GHz for completeness 😉
"E5700" @ 4GHz serttings : LINK
P4EE 3,2GHz @ 3,53GHz settings : LINK
Reply 5 of 35, by shiva2004
I have a 4CoreDual-Sata2 myself, but with a humble Pentium D 920, much more in line with what the chipset was designed originally for, and taking into account that the Asrock 4CoreDual were dubbed as bad motherboards for quad cores, the fact that you can run an overclocked QX9770 in it is amazing. Have you modded the mobo or is it in its original configuration?
Very nice, anyway.
Reply 6 of 35, by Standard Def Steve
I have a few benchmarks from my overclocked Phenom II X6 system. None of these benchmarks use 6 cores, so performance should be identical to a similarly-clocked X4. Oh, and I'm using a GTX 680 GPU. I know it's not exactly what you asked for, but it's the closest I've got. I don't think you'll find many Phenom II rigs out there with AGP graphics. 😀
Phenom II X6 1090T @ 4070MHz
Asus Crosshair IV Formula
16GB DDR3-1760 CL9
GTX 680 at stock
3DMark05:
Doom 3 v1.0 @ 1024x768 Ultra
Phenom II: 351.6 fps (Win7)
Core 2 Quad: 358.9 fps. Keep in mind that the C2Q is running XP and the Phenom is running Win7. The Phenom would definitely come out on top if it were running XP.
SuperPi:
I'm not sure why the Phenom II is so slow in SuperPi, but at least the performance deficiency in SuperPi doesn't translate to any other benchmarks.
Pentium II 300MHz - FSB66 - 192MB EDO: 9m 3.772s
K6-2 500MHz - FSB100, 1MB L2 - 256MB PC100: 8m 34.526s
Athlon 1333MHz - FSB266 - 512MB PC133: 2m 14.914s
Celeron 2600MHz (Northwood) - FSB400 - 1GB DDR266: 1m 42.688s
Pentium III-S 1575MHz - FSB150 - 2GB DDR300: 1m 26.311s
Pentium 4 2400MHz - FSB400 - 1GB DDR266: 1m 14.547s
Pentium 4 3060MHz (Prescott) - FSB533 - 1GB DDR333: 54.438s
Athlon 64 (San Diego) 2640MHz - 2GB DDR440 DC: 32.859s
Core 2 Duo (Merom) 1833MHz - FSB667 - 2GB DDR2-667 DC: 31.356s
Core Duo (Yonah) 2000MHz - FSB667 - 2GB DDR2-667 DC: 30.491s
Pentium M (Dothan) 2700MHz - FSB540 - 2GB DDR2-540 DC: 29.843s
Opteron (Denmark) 3000MHz - Socket939 - 4GB DDR400 DC: 28.750s
Core 2 Duo 2933MHz - FSB1066 - 4GB DDR3-1066 DC: 17.387s
Phenom II X6 4070MHz - 16GB DDR3-1760 DC: 15.063s
Core 2 Quad 4000MHz - FSB1600 - 8GB DDR3-1600 DC: 11.963s
i7-4930k 4500MHz - 32GB DDR3-2400 QC: 7.781s
You can also see how the Phenom does with software video decoding in my Video for CPUs thread.
Reply 7 of 35, by agent_x007
Thank you for all results so far 😀
@up I know. For anyone who doesn't know - Phenom II x4 with AGP capability setup requires one of these :
ALiveDual-eSATA2 (LINK)
AM2NF3-VSTA (LINK)
Very nice, anyway.
First of all don't get the wrong idea : They are BAD MB for almost all Quad Cores.
Why ?
Because maximum stable FSB sucks on them (for Quad Cores it's only 270-290MHz), and those boards can't adjust Vcore from BIOS (which is a real problem when MB has -0,05V difference between VID setting and what acutally goes to CPU in IDLE, and in LOAD you get Vdroop on top of that [think almost -0,1V between BIOS setting and Load Vcore]).
How to get around that limitations (or at least how I did it) ?
FSB limit :
You either go high stock multi (like x10 minimum, and x12-x14 as an optimal value for Core 2 Duo/Core 2 Quad).
Pentium Dual-Core E5600/E5700 are a good example here because they got low 800MHz FSB as start (+are cheap and OC well on stock Vcore).
It may be impossible to get them to post on 1066MHz without Flexibility Option enabled tho (FSB Straps).
OR, you go full extreme mode :
With Core 2 Extreme/Pentium Extreme Edition (and unlocked multipliers for CPU), maximum FSB limit isn't that big of a deal in their case (you will still lose few % of performance because of lower FSB when comparing to OC'ed "locked" chips on P965/P35 based boards).
Other problem for good OC on these boards, is no Vcore control (and it can limit OC quite a lot, even on unlocked Extreme chips).
I knew from my Vannila P5B Quad core tests, that 45nm quad's don't need a lot VRM power to stay stable under 4GHz mark, so higher Vcore should be OK heat wise (it will require some airflow over VRM section, but that's why I used biggest "BOX" Intel cooling I could find 😀).
Then I used a simple VID pin mod to make board think my CPU's default voltage is 1,3875V (instead of standard 1,2875V).
VID Pin Mod uses the same basic method as the other LGA 775 pin mod, the "BSEL Mod", but instead of joining BSEL Pins, you tape/connect VID pins to "Low" and/or "High" pins that are nearby.
I did BSEL mod my PDC E5800 to 1066MHz FSB, to make better FSB Strap config possible (ie. with no need for "Flexibility option" to work on 1066MHz FSB). Bit of warning here : Doing BSEL mod on E5800, required VID Mod for CPU to even POST.
You can go lower multi on locked higher multi Core 2 type chips with this boards, but only after changing max. multi in BIOS (just FYI).
Between unlocked/high multi CPU and BSEL/VID Pin mods (that use tin foil and double sided tape's glue 😁), the only thing left was to update BIOS to latest Beta (can be found here : LINK).
And that was it.
No hardcore hardware modding (ie. cutting socket), no cables to join some capacitors and coils to some other stuff, etc.
Just cheap and simple method that does GREAT things for performance.
To sum it all up :
Those ASRock AGP LGA 775 boards, are the only ones I enountered so far that actually NEED a Extreme Edition CPU's to get most out of them (which is curious in itself, since they are usually at least 4x as expensive as boards themselves...).
Reply 8 of 35, by Standard Def Steve
I was doing some GTX 970 benching with the Q6700 @ 4GHz.
Here's a Doom3 run under Win7: 349.1 fps
The Phenom is slightly faster than the C2Q, although this could really be considered a tie.
Reply 9 of 35, by rick6
agent_x007 wrote:
Let me help you with it :) http://i.imgur.com/WEB20Y8.png http://i.imgur.com/YBxspgL.png http://i.imgur.com/pEkeAqH.png I got al […]
Thank you for sharing and sorry for awnsering so late. It's very nice to see the Geforce 6800 Ultra vs newcomers!
I'm about to get a 7950GX2 and test it on a i3 2120 which should be the same as your CPU give or take. I may post some results as soon as i get it.
Reply 10 of 35, by Offordef
I have a ASRock AM2NF3-VSTA, HD4670 AGP and HD3850 AGP (+ a GW 7800GS+ GS 24P),
In the pipeline for a while but stil waiting on a affordable Phenom 2 X4 970 and plan to finish my Dual/Quad K8 AGP project first.
But this should be a very interesting comparison.
Reply 11 of 35, by copados33
What did you do to install the 3850 agp drivers in Windows XP? I have a Sapphire 3850 agp and I couldn't for the life of me figure out how to get it working under WinXP, I ended up installing Windows Vista on my Pentium 4 setup.
Reply 12 of 35, by SPBHM
I'm curious to see how it performs compared to the OPs PC
which one is the ultimate AGP configuration, nforce 3 am2/am3 boards or the VIA 775 ones; probably the 775, but...
Reply 13 of 35, by agent_x007
You can see driver in GPU-z window 😀
I used Catalyst 10.2 XP without "AGP hotfix" and I simply forced installation of the right driver by going to device manager, picking manual installation option with manual .inf file load, and after Windows gave me a list of devices inside .inf - I picked the right card model and confirm to install driver.
After restart, results can be seen in GPU-z window 😉
Oh, I partially installed (or simply let installer unpack) Catalyst drivers package into default folder, and then I manually exit before Catalyst Control Center installation.
You must know the path to driver folder (since it's needed in .inf file search).
@up LGA 775 has support for Windows 7 and later OS'es.
AM2NF3 doesn't (no GART driver for AGP port/GPU).
In case of performance... I simply do not know.
Depends on CPU OC and RAM settings + MB drivers.
Reply 14 of 35, by MrMateczko
Windows 7 has builtin GART driver for nForce 3, specifically the PCI\VEN_10DE&DEV_00D2 and PCI\VEN_10DE&DEV_00E2 ones. I have installed Windows 7 on my K8Upgrade-NF3 and everything was detected and installed out of the box, except the AC97 driver, as ASRock correctly notes.
Reply 15 of 35, by Arctic
Why do you use Catalyst 10.2 ?
Reply 16 of 35, by agent_x007
Because Catalyst 9.9 and older doesn't know what a HD 5870 is 😀
And using first driver released for any given card, is not a good idea.
Reply 17 of 35, by Arctic
🤣 I meant why do you use 10.2 for the 3850 AGP?
Reply 18 of 35, by agent_x007
To be consistent with HD 5870 results 😀
If you compare two GPU's, you should compare it with the same driver if possible (at least that's how I see it).
Also Cat. 10.2 worked in almost every test I did on it, so I didn't saw the need of changing them for older/newer.
The only test that was having stability problems was 3DMark 05 (but even that was on 4GHz PDC only, since both QX9770 OC and Pentium 4 EE OC worked with 3DMark 05 on Cat 10.2 flawlessly).
Other than that, I had to BIOS mod Fan curve for few of the cards, because they simply ran too hot for my liking on OC'ed PDC and "C2Q" systems (out of BOX settings).
Cards moded were :
Sapphire x1950 Pro 512MB (single slot), Sapphire HD 2600 XT 512MB, HD 3850 512MB (IceQ3).
Reply 19 of 35, by biessea
I have an Asrock AM2NF3-VSTA motherboard with installed an AMD Phenom II 955 @4,0ghz!
Do you need results even if it's passed about 8 years? 😉
Computer lover since 1992.
Love retro-computing, retro-gaming, high-end systems and all about computer-tech.
Love beer, too.
