Are GeForce 256 DDR cards that rare?
Reply 60 of 318, by deleted_Rc
swaaye wrote:
What resolution and settings do you usually use? What games do you play?
depending on the game I play them at either 800*600 or 1024*768 what ever the highest settings allow.
my current gamelist for my Gf 256 rig (combined with a V2 SLI) on a PII:
- NFS porsche & High stakes
- Dungeon Siege & Legends of Aranna
- Rogue Squadron
- Half life & expansions
- C&C Tiberian sun & Firestorm
- Dune 2k
- Stronghold & Crusader
- AOE 1 & 2
- Quake 3
- Heretic 2
- Blood 2
- Carmageddon TDR 2000
- Diablo II
- KKND 2
- M.A.X. II
- Street Wars
- Dark Forces
- Warzone 2100
(got a big HD 😎 )
Reply 61 of 318, by Chaniyth
PhilsComputerLab wrote:
The GF 2 Ti came out quite late. I think even when the GF3 was already out. Basically as a budget alternative?
Ah, thanks Phil for clearing that up. Sort of a silent release budget card I'd imagine because Nvidia would want gamers to buy a shiny new GeForce 3 series card.
I wonder if the GeForce 2 Ti were binned Ultra cards because they have the same core clock speeds as the GeForce 2 Ultra but the memory clock was 30/60Mhz (DDR) slower than the GeForce 2 Ultra.
All the world will be your enemy, Prince with a Thousand Enemies, and when they catch you, they will kill you... but first they must catch you. 😁
Reply 62 of 318, by Scali
I suppose they tried to reduce the cost of the total card by installing slower memory on it, while using the same GPU.
Back then, memory was a major factor in cost of the video card (I had a GF2GTS with 32 MB, which was basically half the price of the 64 MB model. Fast VRAM was really expensive).
Reply 63 of 318, by PhilsComputerLab
AFAIK the GF2 Ti chip is made with a smaller manufacturing process. So they usually clock higher and run cooler 😀
YouTube, Facebook, Website
Reply 64 of 318, by meljor
Correct. From Anandtech:
In addition to gaining 50MHz on the core speed compared to its GeForce2 Pro predecessor, the GeForce2 Ti 200 also got a die shrink. The GeForce2 Ti 200 is essentially a GeForce2 GTS series chip that is manufactured on a 0.15 micron process instead of the older 0.18 micron process used in GeForce2 GTS, GeForce2 Pro, and GeForce2 Ultra chips. This allowed NVIDIA to reach higher clock speeds with better yields on the GeForce2 Ti 200 cores.
Reply 65 of 318, by The Serpent Rider
Quite a lot of brandname GeForce 2 Ti had 4ns memory.
They don't actually. Most of Ultra cards can hit +/- 300mhz GPU (with decent cooling) and Ti usually can hit only 270-280. GPU voltage difference probably.
Reply 66 of 318, by Scali
Yea, that's the other side of the story 😀
I have an Asus GF2GTS that can easily run at Pro speeds as well, because they just put much faster memory on there than the official 'GTS' specs require.
They probably did the same with "Ti" models. Partly to offer users great overclockability, and perhaps also partly because then they could just buy the faster memory in bulk, rather than buying smaller batches of different speed grades of memory.
Reply 67 of 318, by The Serpent Rider
Most likely this. Same memory was used on GeForce 3 Ti 200/500 models.
Reply 68 of 318, by PhilsComputerLab
True I found the same with the Quadro2 Pro. At least the card I have is an overclocking beast.
Reply 69 of 318, by devius
I actually bought a GeForce 256 DDR with 64MB about 1 year ago for 3,60€, together with a few other cards. I used the local ads website where you can still find some decent deals, although the really good ones require the skills to identify cards and other hardware parts in blurry/shaky photos. That's how I got the GeForce 256 since it wasn't properly announced in the description.
BTW, I had a GeForce 2 Ti 64MB back in the day when it was new, and I can confirm that it was a sort of budget card for people that still cared about performance. Not as fast as a GeForce3, but way better than the much more common TNT2 M64's, and faster than the GeForce 2 MX's while not costing all that much more.
Retro Coisas no YouTube
Reply 70 of 318, by The Serpent Rider
M64s were already history at that time and replaced by MX200 a year before.
Reply 71 of 318, by devius
Here's the website of a local computer store from June 2002 (that's 8 months after the GeForce 2 Ti was released) where you can see that the TNT2 M64's were still being sold and positioned as the cheapest cards available: https://web.archive.org/web/20020623111009/ht … at=23&subcat=59 So, definitely not "history", although they didn't suck any less than when they were released.
Reply 72 of 318, by Tetrium
I tend to agree about the TNT2 M64 having had a very long shelf life. The newer ones were mostly OEM stuff though.
Should be visible on the PCB manufacturing dates.
My retro rigs (old topic)
Report spammers here!
Reply 73 of 318, by AzzKickr
I actually scored an Annihilator Pro card yesterday on Ebay 😁
32mb DDR NV10. Can't wait until it arrives !
It no longer has its stock fan/heatsink though but a passive one, V3 style. Have to look for a good matching solution so if anyone has any links ?
Card works ok according to ad and screenshots.
Heresy grows from idleness ...
Reply 74 of 318, by deleted_Rc
AzzKickr wrote:
I actually scored an Annihilator Pro card yesterday on Ebay :D 32mb DDR NV10. Can't wait until it arrives ! […]
Iirc a north bridge (athlon xp mobos)heatsink + 30 mm fan are quite good if you have space.
Otherwise aliexpress sells those v3 style heatsink + fan dirt cheap.
Reply 75 of 318, by appiah4
Well, something strange and wonderful happened. A friend of mine who works at our IT dept. called me up and asked me to come over to this desk so I obliged. He had a box full of addon cards that he thought could be useful to me, knowing I'me into retro hardware (read: junk). Well, there were a couple of nice cards in there, but the jewel of this loot was a Creative 3D Annihilator Pro CT6970:
The fan needs some oiling or replacing but otherwise it looks perfectly fine. Amazing!
Reply 76 of 318, by AzzKickr
(image will be here momentarily 😀 )
Hey ! Same card like I scored ! Cheers 'n beers !! 🤣
PS: Do tell us about the others in there too !
Reply 77 of 318, by appiah4
Heres the rest.. Two 9550GEs, a 9250, a 9200SE, an MX4000, a Cisco 802.11b wlan PCI and a D-Link 802.11g wlan PCI
Reply 78 of 318, by AzzKickr
Niiice
Reply 79 of 318, by devius
Yeah, you can never have too many graphics cards 😉
