Reply 641 of 865, by SPBHM
- Oldbie
it was using dual channel at over 750MHz, but I don't think it changed much from SC, it's bottleneck by Hyper Transport I think.
Reply 642 of 865, by Tiger433
- Member
One is with Celeron 1.7 on Willamette Core and another on Pentium IV 1.7 also on Willamette core, tested on Gigabyte GA-8IDX mainboard and GF4MX440 with 128 mbit memory bus.
W7 "retro" PC: ASUS P8H77-V, Intel i3 3240, 8 GB DDR3 1333, HD6850, 2 x 500 GB HDD
Retro 98SE PC: MSI MS-6511, AMD Athlon XP 2000+, 512 MB RAM, ATI Rage 128, 80GB HDD
My Youtube channel
Reply 643 of 865, by tomoa
Asus CUBX-E (Intel BX 440), Pentium III-S 1400@1472, Gainward Geforce FX 5900XT@5950 Ultra AGP x2, (2x256) 512 MB RAM PC133 CL2,
3DMark2001 SE, score 10253
Poland , http://komputery-retro.ddns.net/ http://komputery-retro.ddns.net/blog/ , I like old games and old computers 😀
Reply 644 of 865, by KCompRoom2000
Here are the results of my current XP rig.
Specs: Asus A8V, 2.0 GHz AMD Athlon 64 3200+, (2x1GB) 2GB PC-3200 DDR SDRAM, BFG nVidia Geforce 7800GS OC 256MB AGP 8x
Score: 19958
I have a few more systems to benchmark soon.
Reply 645 of 865, by agent_x007
Reply 646 of 865, by Standard Def Steve
Core i5-3470 @ 3391 MHz
Intel HD 2500
"A little sign-in here, a touch of WiFi there..."
Reply 647 of 865, by agent_x007
Reply 648 of 865, by Standard Def Steve
That is indeed an insane score, considering that Win98 seems to be as slow as NT6+ when it comes to 3DMark01. You should try benching that system with XP and 7 just to see where Win98 ranks in terms of 3D01 efficiency. You know, if you have the time. 😀
Reply 649 of 865, by Standard Def Steve
Another 4.8GHz suicide run, this time on XP. I had to pull the GTX 970 and use a 680, because NV doesn't support the 970 under XP. Even though they support the newer 960. 🙄
Reply 650 of 865, by gandhig
- Member
Reply 651 of 865, by Carlos S. M.
wrote:Another 4.8GHz suicide run, this time on XP. I had to pull the GTX 970 and use a 680, because NV doesn't support the 970 under XP. Even though they support the newer 960. 🙄
There are modded XP drivers for the 970/980/980Ti/Titan X Maxwell if you want to try ouy
Reply 652 of 865, by agent_x007
Reply 653 of 865, by Imperious
A rather ridiculous combination of hardware, but fun seeing what it can do. This is the limit of what I could get out of this cpu as it wouldn't
boot with over 1.600v selected in bios. Years ago I did a vdroop mod to this motherboard, so setting 1.6v gives up to 1.712v actual.
Reply 654 of 865, by Imperious
Managed to squeeze a bit more out of it.
Reply 655 of 865, by Srandista
- Oldbie
This was just test runs, will do complete runs, once I finish installation and configuration of whole build.
Intel Q6600, 2GB RAM, ATi Radeon 9500 (stock, Catalyst 7.11)
...and same build, just with softmodded 9500@9700
Reply 656 of 865, by Shagittarius
- Oldbie
wrote:Here's my current XP machine : C2D 7200, GTX 280 […]
Update to the XP Machine : C2D 8600, GTX 580
Reply 657 of 865, by Imperious
Celeron D@3.7GHZ 185*20 (1.033ghz overclock) on my Asus P4P800dlx with HD3850.
Gives a P4 800fsb northwood a good run for it's money. Couldn't get more than this out of it.
Reply 658 of 865, by MrMateczko
- Member
ASUS X553MA laptop (2014!) - absolutely terrible! What is this comparable to?
Reply 659 of 865, by rod
System: Intel Desktop Board VC820
OS: Windows XP x86 SP3
CPU: Intel Pentium III-S 1400Mhz
Memory: 512MB (2 X 256MB) PC-800-40 RDRAM
GPU: NVIDIA GeForce 6200 512MB 64-Bit GDDR2
GPU: NVIDIA GeForce 7600 GS 512MB 128-Bit GDDR2
