MDA/CGA/EGA to VGA Converter Released!
Reply 100 of 341, by keropi
mateusz.viste MDA is fine on dreamblaster's boards, see this shot I made:
I also think colors will be correct with more precise resistor networks, there is no reason for them not to be
Reply 101 of 341, by mateusz.viste
Yes, I did see it - I was just saying that if he'd happen to have a 'failed' unit that still works with MDA, instead of throwing it out I'd happily buy it since I'm not interested in EGA/CGA anyway. I need it only for debugging programs - a dual screen VGA/MDA setup would be extremely helpful when working on etherdfs (tsr), dosmid (full screen app) and many other of my projects.
http://mateusz.viste.fr | gopher://gopher.viste.fr
Reply 102 of 341, by keropi
ah OK yes this is a nice idea actually having dual monitors... I think a couple of games also supported that as well!
Reply 103 of 341, by retrocanada76
dreamblaster wrote:
The 2.0 project is already on his site. I am working on a version that can be factory assembled. Lessons learned so far : for ne […]
mateusz.viste wrote:
@retrocanada76 - from your website I understand that you are working on a new, improved v2.0, so I will probably wait for that before assembling anything. One humble suggestion I would have: is there any chance that the v2.0 could come in a "MDA only" variant? This would be nice for people (like me) that do not care about EGA/CGA, but are very interested in monochrome MDA/herc, while not being very handy with a soldering iron at the same time... I assume here that a MDA/herc-only version would need less elements (even if only a few resistors and dip switch).
Lessons learned so far : for next prototypes, I will use better tolerance resistor networks, as the colors seem to differ a bit.
A prototype is on its way to retrocanada, for evaluation.
If it all works well, I'll have a small batch machine assembled.
Hey, I use 5% resistors on mine. I don't think this was the problem. Have you noticed that one of the resistor arrays is isolated and the other bussed ?
Can you tell me which resistor networks did you use for the project ?
Reply 104 of 341, by retrocanada76
isolated: https://www.digikey.ca/products/en?keywords=4608X-2-102LF-ND
bussed: https://www.digikey.ca/products/en?keywords=4606X-1-102LF-ND
ok, my tolerance is 2% but the version 1.0 I used regular 5% 1/4w
Reply 105 of 341, by dreamblaster
I use all isolated resistor networks (all the same part).
The first prototypes had 5% tolerance. (also in the packet I sent you).
Now I ordered parts with 1% tolerance.
We'll see if this solves the issue
Thanks for your support !
Reply 107 of 341, by dreamblaster
retrocanada76 wrote:
can you send me the schematics ?
yeah of course, see attachment
RN1 to RN6 are the 1k resistor packs.
I initially used 5% packs. Now I ordered 1% replacements.
(the 1k resistors R1,R2, R3 are already 1%)
Reply 108 of 341, by retrocanada76
can you measure the resistance from each color pin ? From keropi pictures the problem seems to be on B3,G3,B3 they seem to be too bright. These pins should be 500 Ohms each.
B3,R3,G3: 500 ohms
B2,R2,G2: 1K
B1,R1,G1: 2K
B0,R0,G0: 4K
Reply 109 of 341, by dreamblaster
on mine it all seems close enough
86.08 KiB
Reply 111 of 341, by retrocanada76
Dreamblaster, did you try another monitor / tv ? just for the sake. If the voltages are correct there is nothing wrong with the unit.
Use the last FW, and show the colorbars using a different monitor/TV.
Reply 113 of 341, by keropi
can you measure the resistance from each color pin ? From keropi pictures the problem seems to be on B3,G3,B3 they seem to be to […]
B3,R3,G3: 500 ohms
B2,R2,G2: 1K
B1,R1,G1: 2K
B0,R0,G0: 4K
All these check out on my board as well.
Tried latest fw and also a completely different lcd screen, did not help. I will try again once I have installed the 1% resistor networks.
Reply 114 of 341, by retrocanada76
Sorry, It can't be the resistors. It makes no sense! If your values are correct, them there is no need to replace them. Just do a sanity check and make sure they are not shorted. Specially cross-color, like Bx is not shorting any of the Rx, Gx and remaining Bx's.
It would be wise to take a look on the shift level 74LVC245 as well as the voltages sent from your board. What is the EGA card are you using ?
Do you have another EGA card ? What if you jumper it to CGA display ? Does the text color color bar change ?
Reply 116 of 341, by keropi
Yes reds are too bright, almost hot red.
I have tested with 4x EGA cards (at least I have a healthy stock now 🤣 )
I did see quality differences but the color balance was constant in all 4 cards. I will wait for those 1% networks and solder them again that way I will also eliminate the possibility of a short.
Not sure how I can check the 74LVC245 though soldering looks great on it.
Reply 118 of 341, by ibmapc
arteq wrote:
do you know where I can by the PCB or complete board for MDA/CGA/EGA to VGA ?
Hello arteq and others here at Vogons. This is my first time posting here. Some of you might recognize my handle from Vintage Computer Forums. I've been a member there since 2010. I've been selling assembled MDA/CGA/EGA TO VGA V2.0 units to VCF members and am currently working on a new batch to sell. They sell for $110 shipped in the US lower 48. If interested, please email me at gregsaling@comcast.net from your PayPal email and I can send you an invoice to get your order rolling.
Greg
PS
I can ship to other countries as well. It just costs a little more.
Reply 119 of 341, by ibmapc
@keropi;
I see you have and ATI EGA Wonder. Would you consider trading for an assembled V2.0 MDA/CGA/EGA to VGA converter?! We each pay our own shipping? What do ya think? Counter Offer?
Greg
