Something for lovers of bad video cards (youtube)
Reply 40 of 95, by clueless1
Reputator wrote:
Sounds really good with the new narration! You really did a fantastic job F2bnp!
And brilliant work as always vlask. I'm definitely subbing to this!
Just an FYI, gouraud is pronounced like "gorrow", with emphasis on the second syllable. Here's a spoken example.
While on the topic of pronunciation, I've always pronounced Matrox "May-trocks", not "May-tricks". I don't know what the official way is.
Reply 41 of 95, by Reputator
Same here, which is why I didn't say anything about it. For all I know I could be wrong on that one.
https://www.youtube.com/c/PixelPipes
Graphics Card Database
Reply 42 of 95, by F2bnp
I'm not saying "May-tricks" in the video. 🤣
Reply 43 of 95, by leileilol
It's a Quebec company so maybe it''s May-tro.......
You should really sort out that sound issue, I don't think just the specific video card is at fault here and may affect with others. I can see a Geforce giving the same trouble
Reply 44 of 95, by gdjacobs
Well, it's not spelled Matreaux.
Reply 45 of 95, by vlask
Same setup, Voodoo 1, Riva 128, S3 ViRGE - no problems with sound. Same errors had Alliance AT3D. Tried to change sound card for Soundblaster 128 - same results. Don't know reason for this. Did 2 years ago benchmark of these 1st gen cards, but without sound. So don't know how many others will have same issues.
Not only mine graphics cards collection at http://www.vgamuseum.info
Reply 46 of 95, by spiroyster
Branco Matic and Lorne Trottier ... eXcellence
Reply 47 of 95, by leileilol
Try this with mystique on GLQuake with the techland driver. Paste this as opengl32.ini in the quake folder
[Techland OpenGL]
; alpha treshold for texture conversion for colorkeying on Mystique
nAlphaTreshold=80
; dither texture, may improve visual quality
bDitherTexture=0
; use single precision math, pretty important to set it correctly on voodoo
; should speed up things a little anyway
bSinglePrecisionMath=0
; emulate permedia2 in GL_RENDERER for s3 virge driver
; so quake will use mono lightmaps
bEmuPermedia=1
; for virge, force square textures
; textures are resized inside opengl
; default is 1
; you may try to set it to 0 if you have Virge DX or GX2
bForceSquare=0
; for virge, force squaring to smaller dimension
; saves memory but quality is worse
; default is 0
bSquareDown=0
;use s3 virge 24bpp mode for rendering
;works only in fullscreen mode
bVirge24BPP=0
Reply 48 of 95, by WildW
So I've been wrong saying Mat-rocks all this time??? This is like the Hauppauge thing all over again.
Reply 49 of 95, by darry
I personally know several people who used to work for Matrox and I can tell you that all of them pronounce it as "Mat-rocks" .
Reply 50 of 95, by vlask
leileilol wrote:
Try this with mystique on GLQuake with the techland driver. Paste this as opengl32.ini in the quake folder […]
[Techland OpenGL]
nAlphaTreshold=80
bDitherTexture=0
bEmuPermedia=1
; default is 1
bForceSquare=0
; default is 0
bSquareDown=0
bVirge24BPP=0
Tried, no effect. Still without textures....
Reply 51 of 95, by vlask
Someone ever wanted card from Trident? Hope not. Next episode out featuring Trident 3DImàge 9750.
https://youtu.be/P_tEA3VCIBY
Reply 52 of 95, by Reputator
Ha my first experience with 3D acceleration was with my family's Compaq and its integrated Trident Blade 3D. Actually didn't do too badly in Star Wars Episode 1 Racer, which was pretty much the only 3D game on PC I played back then.
Reply 53 of 95, by vlask
Another episode, this time also start of new playlist. Had to do some recording with borrowed cards....might not see them many years, chances that i got them to collection are low.
So something about PCX2
https://youtu.be/M7dxTmI1SyI
Reply 54 of 95, by Reputator
Great video! Technically this isn't a bad video card! Haha
Reply 55 of 95, by elianda
Hmm why don't you see reflections with the PCX2 in Unreal?
In my capture of Unreal with the PCX2 you ca see it at the beginning as well as at e.g. 5:58
https://www.youtube.com/watch?v=GT0OILijFfo
Youtube Channel
Reply 57 of 95, by The Serpent Rider
Looks like Riva TNT level of performance in 2001.
Reply 58 of 95, by Baoran
I have a laptop that has that trident blade xp and it goes through 3dmark01 and I get similar results as I would get using voodoo3, so I wouldn't really call it a bad chip. Also it seems very compatible with dos. I have gotten no visual glitches in any dos game I have tried.
I am sure it was probably slow considering when it was launched, but slow doesn't mean necessarily same as bad from my perspective.
Reply 59 of 95, by dr_st
leileilol wrote:
Geforce FX5200 64-bit
ATI Rage (non-Pro)
I think I owned both of these at one point. 🤣
