First post, by aaronkatrini
I have a partially broken v3 and wanted to check if any broken capacitor were broken under the Heatsink, and with this easy trick I could get it off in less than 10 seconds. You just need dental floss and place it between the chip and heatsink.
https://youtu.be/W7oL3sfztUU
No glue / thermal compound was found under at the chip, it was all in the heatsink. Now I need to find a way to clean it without scratching.
Reply 1 of 8, by aaronkatrini
I removed successfully the "glue" from the heatsink itself. I just scratched it with my nail on one corner and then it off in one piece. I need to test the card again, there is a slight change that the thermal compound was acting maybe not like a heat transfer compound but like a heat blocking barrier. And if this was the case than maybe those artifacts are fixed. Doubt, but I'm hoping so.
edit: added photos
Reply 3 of 8, by aaronkatrini
buying a heatgun just to remove a heatsink seems eccessive, I managed to get it out in no more than 10 seconds and without damage (visible, since the card was already half broken). Plus dental floss costs like 1-2 dollars
Reply 7 of 8, by ph4nt0m
Logistics wrote:
Has anyone tried sanding the silicon down until they reach the core?
That's not silicon. EMC = epoxy mold compound. It contains some silicon dioxide or another kind of filler in order to improve thermal conductivity. You have to sand off about 75% of the epoxy by height in order to reach the core.
My Active Sales on CPU-World
Reply 8 of 8, by Con 2 botones
edit: added photos
Did you manage to fix your "artifacting" problem?. I´ve got the same model and I`m experiencing the same issue. Thanks!
