Best Drivers for GeForce4 MX-440
Reply 60 of 93, by The Serpent Rider
Nice purple PCB on it too.
Say hello to Palit Dayrona.
Reply 61 of 93, by biohazardx9
Aha that's what it is! Palit isn't a bad brand, still going I think?
Reply 62 of 93, by The Serpent Rider
At that time, quality of their products was questionable.
Reply 63 of 93, by biohazardx9
It's doing a job for me though so that's something. Thanks for helping me identify it though I appreciate it.
Reply 64 of 93, by varrol
I recently got GF4 MX440 by Gainward and all benchmarks fail to run with newest drivers + directx 8.1 - I had to go back to ~40 version. Anyone got similar experience? Weird as my GF2 MX (as I remember) works fine with latest drivers and it is older.
AOpen AX6B+ | P3 1G | 1GB ECC REG | FX5200 | CT4500
AOpen AX59pro | K6-2 450M | 256MB | Rage 128
Asus CUBX-E | P3 1G | 512MB | GF4 TI4200 | YMF719E-S
Asus P3B-F | P3 933M | 384MB | Radeon 9200 | CT4520
Asus P5A | P55C 200M | 256MB | Riva TNT | CT3600
Reply 65 of 93, by dr.zeissler
I have a GF4-MX-4000 low-profile PCI card. It has a surprisingly good image quality but I have some compatibility issues in some older games. I currently use "NVIDIA Display Driver for Windows 9x version 4.14.10.5664, 03/03/2004". Is there a better driver for that card?
Reply 66 of 93, by atom1kk
Maybe not a big help, but on my GF3 I found out that the 23.11 driver works best at the moment. I think the older drivers work much better than the newer version. Try to find out which is the oldest version suppporting your GPU and start with that , if this does not help try one version higher. It helped me with my issues.
Reply 67 of 93, by The Serpent Rider
Read thread maybe?
Reply 68 of 93, by dr.zeissler
I thought it's MX440 is nearly the same as MX4000
Reply 69 of 93, by SPBHM
it's very similar to the AGP8x MX440, but it was launched a while after so driver compatibility (with old versions) is a little worse I think
Reply 70 of 93, by The Serpent Rider
They are not similar. They are identical.
Reply 71 of 93, by VirtuaIceMan
So I got an Inno3D GeForce MX440 8X card now (third candidate for 2D side alongside Matrox M3D). However I'm not sure all is well with it, as Direct3D seems not to be working properly.
For some reason on my Win98SE setup, DirectX 9.0a seems to have got installed. If I try the Display > Direct3D tests on that (they worked on the Radeon) it just crashes NVDD32.DLL and reduces Windows to 640x480 res. This is using the "preferred" 45.23 drivers from VogonsDrivers (with either the "nVidia Detonator/FW Driver v45.23 Win9X (Gf FX)" or the "nVidia Detonator/FW Driver v45.23 Win9X setup" versions). Any ideas? Maybe some newer drivers for Dx9? Which should I try?
My PC spec: Win10 64bit, i7-4970K (not overclocked), KFA2 GeForce RTX 2070 SUPER, Creative Soundblaster ZXr, 16GB RAM, Asus Z97-A motherboard, NZXT 410 case, ROG Swift GSYNC monitor
Reply 72 of 93, by mockingbird
The Serpent Rider wrote on 2022-01-28, 15:34:
Incorrect.
I have both. The oldest driver (28.32 - the earliest GeForce4 driver) cannot talk to the MX440-8X. There are significant enough changes in the silicon (NV17 vs NV18, NV25 vs NV28).
If you have an "8x" version of the TI4xxx or the MX4xx then the earliest driver you can use is 43.45.
I don't know that there are games that work with 28.32 that don't work with 43.45, but I personally use a GeForce 3 Ti500 modded with Rivatuner NVSTRAP to be a GeForce3, and it works with drivers 12.41, which is necessary for a DirectX 6 or 7 Win9x build. So unlike the GeForce4, all GeForce3 silicon is in fact the same, but just differ in the quality of the IC used, the higher binned ones being used on higher end models.
(Decommissioned:)
Reply 73 of 93, by VirtuaIceMan
mockingbird wrote on 2022-03-01, 00:53:
I know you weren't replying to me, but that sounds like a good pointer for me too, as 43.25 wasn't working.
Reply 74 of 93, by Joseph_Joestar
I have the AGP8x versions of both cards (made by MSI) and mine work with 40.72 WHQL drivers without any modifications. Been using those for over two years now, so it's not some fluke.
Perhaps the minimum required driver version varies for different brands or by production date.
My retro builds
Reply 75 of 93, by The Serpent Rider
28.32 works with any GF4MX on Win9x, just feed it generic GeForce 4 MX 440 from device list and it will work.
Reply 76 of 93, by mockingbird
Joseph_Joestar wrote on 2022-03-01, 01:28:
I stand corrected, the earliest version for support for NV18 and NV28 is 40.71. But the point still stands, if you try anything earlier it won't work.
The Serpent Rider wrote on 2022-03-01, 01:41:
Again, incorrect. And that's why the "8x" versions of GeForce4 are not a good choice for older builds.
Stick to vanilla MX440.
(Decommissioned:)
Reply 77 of 93, by VirtuaIceMan
Any idea why Direct3D on my Ino3D GeForce MX450 8X is crashing DxDiag? What's the latest driver this card supports? I wondered if 43.25 is too early for DirectX9a (that I think might have been installed with soundcard drivers or some other drivers I tried from a previous graphics card, as the games I ran pre-date DX9)
Reply 78 of 93, by mockingbird
VirtuaIceMan wrote on 2022-03-01, 07:55:
I see three large 16V 470uF capacitors at the top left portion of this model card... Replace them, and consider testing the three small ones at the bottom right.
(Decommissioned:)
Reply 79 of 93, by VirtuaIceMan
I'm not really an electronics kinda person. Is it highly likely to be capacitors?
I think we've got a soldiering iron but don't think I have any testing gear, what would be needed? Multimeter or something? I'm more tempted to get a refund as seller said it's working (but they also said no returns)
