First post, by chratuda
Hello
I have a Radeon 9600SE that fits into an AGP PRO slot. Mobo is a P4C800.
My problem is quite "simple":
Computer doesn't start meaning I can't switch the power supply ON.
I used to have a Radeon X1650Pro IceQ but that one is dead showing only vertical lines at some point but now showing nothing. But the
computer was running.
I have a second set of power supply, mobo (same type of board), processor, etc. and that Radeon behaves in the same manner.
Does anybody know if there is a compatibility issue?
Is there anything that can be measured on that board?
Thanks for your help.
Walter
