First post, by viper32cm
I'm building a late-DOS/Win 3.x build around a Pentium 100 similar to the Packard Bell system I had in middle school. Much like that old PB system, the computer I'm using as a base has an LPX-motherboard with an integrated 1MB PCI video card.
The PB system had a Cirrus Logic GD-5430, which I recall had some highly annoying incompatibility issues with Fleet Defender and US Navy Fighters.
The system I'm working with now has an ATI Mach64, which works but my research shows that it's not the fastest.
So I'm considering using something other than the Mach64 in this new build. The candidates are the Cirrus Logic GD-5446, Matrox Millenium, and the TSENG ET6000. I know the S3 Trio is an option as well, but I'm leery of the video quality issues some of those cards have.
The TSENG is obviously going to be the most expensive of the candidates but likely, generally , the fastest in most situations. Is it worth it compared to Mach64 or the others?
With the GD-5446, I'm concerned about the same compatibility issues I had with the GD-5430.
Finally, the Matrox seems like a good option, faster than the Mach64, but I'm not sure how it compares to the others.
