First post, by Predator99
I think this nice card I got recently deserves its own topic 😉 Its a TSENG EVA/480 ET-2000 EGA card:
1.06 MiB
It has the same PCB as the NEC GB-1 COLOR GRAPHICS BOARD:
https://arvutimuuseum.ee/th99/v/M-O/52507.htm
Ad taken from here:
http://www.thecomputerarchive.com/Displays/Vi … Card%20BG-I.PDF
NEC MultiSync Graphics Card BG-I.PDF
852.94 KiB
109 downloads
There a two add-on boards.
One connected to the feature connector providing TV-out. Dont know why the cable is soldered to the connector. As far as I remember it can also be connected via the feature connector without extra cable. Maybe to improve quality.
719.82 KiB
The other one...dont know yet, its not a memory expansion.
There is a Z80 and a HM6116 CMOS RAM on it.
https://pdf1.alldatasheet.com/datasheet-pdf/v … CHI/HM6116.html
The card seems to work without it.
1.18 MiB
And without boards:
1.38 MiB
Pictures in operation later...
Reply 1 of 5, by Predator99
Newer revision of the card here:
Composite out looks really nice on 320x200:
372.6 KiB
But is unusable with 640x350:
285.04 KiB
And all is in black and white. Dont know if this is caused by my LCD or if the circuit doesnt support color.
Digital out works as expected.
Reply 2 of 5, by Predator99
NSSI BIOS dump
[This is not a product of IBM (IBM is a trademark of International Business Machines Corp.)
* Copyright(c)1986 Tseng Laboratories, Inc. 07/28/86 V1.xx*
EGA ET2000.zip
11.7 KiB
83 downloads
Reply 3 of 5, by root42
The black and white is probably because of PAL vs NTSC?
YouTube and Bonus
Reply 4 of 5, by VileR
Predator99 wrote on 2020-08-23, 12:32:
The other one...dont know yet, its not a memory expansion. There is a Z80 and a HM6116 CMOS RAM on it. https://pdf1.alldatasheet […]
Oi. Came across this by accident, but that Z80 add-on is probably for register compatibility with CGA / Hercules / MDA:
"A $50 optional daughterboard provides emulation of the CGA, HGC, and monochrome adapter." - https://archive.org/details/PC_Tech_Journal_v … de/2up?q=ET2000
And from someone's ebay listing: "the Z80 CMII module ... (Compatibility Module) manages CGA and Hercules compatibility. " - https://www.ebay.com/itm/Vintage-1986-NEC-MUL … U-/133185245469
That's for the non-"480" version of the EVA ET2000, although it still seems to have some pretty interesting features. Any chance you have any of the software or documentation for this thing?
Reply 5 of 5, by Predator99
Yes, also found that info:
https://books.google.de/books?id=gC-DsOtl2MgC … A%2F480&f=false
No software or doc, card comes from a scrap lot 😉
171.42 KiB
