Fact review on graphics card purchase for XP
First post, by hwh
I read/considered the large "best card for XP" thread but I don't really want to mix up that with this, so...
My GTX 460 just died (how hilarious, the socket for the fans fell off the card and the card ran without fans until it broke). When I got it, I wasn't impressed by its lack of DOS mode compatibility, but, well, I guess time passes and standards change. I no longer worry about NTVDM as the "official" DOS, it either works or you use you-know-what. But you do lose a little compatibility here and there. Usually without knowing!
Taking this into consideration, my initial reaction of a GTX 960 (the standard "bleeding edge performance" answer) now seems incorrect. If I choose to run a DX7 game, heh, it's not unlikely there will be issues, but I don't want more issues than I already have for performance that I almost never need.
The devil, advocating says I should get another GTX 460, and I hate him because it's an old card and I don't want to go backwards. This isn't some "vintage" system, it's what I use. So that would be a last resort. I could probably get more performance with lower TDP in a newer card. I care more about noise than performance.
I have heard the um, GTX 750 might be the way to go for shader 3.0 (non unified) because that breaks some stuff. I have also heard tell that some games bug out at the sight of tons of video memory. 4GB, to be specific. My GTX 460 has 768MB. Is there some known point (say 2 or 4GB) at which problems occur? Or would a random GTX 750 just be the ticket?
Then there's the matter of ATI (errr...AMD? I haven't bought one of their cards in 17 years). I have nothing against them although there is always a give and take with the drivers, nVidia too. Does it matter? I feel like compatibility is less of an issue with nVidia. But I might just be thinking of 2002, I don't know. So if you have reason to believe that AMD is the way to go and know the best card that isn't worse (compatibility) than a GTX 460, please share that reasoning.
TLDR: Better performance than GTX 460, equal or better compatibility with, pretty much, Windows 98 games to today. Who am I?
Reply 1 of 23, by chrismeyer6
Not sure how much this will help you but I've had great success with older games with my GTX 470 with XP and 7 Ultimate.
Reply 2 of 23, by SScorpio
The GTX 460 didn't have great 98 game compatiblity either. It doesn't support 8-bit palleted textures, and I believe some fog table and shadow buffer stuff doesn't work. A GeForce 4 or FX would be the latest Nvidia cards to support those features and those are very much 98 cards as I also view XP as DX9 which neither of those cards handle well.
The main thing I'd look at is what games are you hoping to run? Many XP games can be played on a modern PC running Windows 10 without issue. dgVoodoo works with older Direct3D/Draw games and may fix the issues you ran into.
A 2GB 750 should be plenty to run any XP game that doesn't work in Windows 10.
Reply 3 of 23, by kolderman
HD5850 or GTX560Ti are my go-toos of choice.
Reply 4 of 23, by Shagittarius
780Ti is what I run in my XP machine.
Reply 5 of 23, by ODwilly
HD6800's and 6900's are super cheap and plentiful. They havent had good drivers for years for windows 10, last release was 2016. Not really an issue for XP tho.
Reply 6 of 23, by Baoran
Basically my thought on this matter is that you can't get everything with a single card. The newer card you get the better the performance is and older card you get better the compatibility is. It was said in this thread before too that you can play especially newer windows xp games on a modern pc too so you might not need as much performance with the older games you play and could concentrate on older cards and better compatibility.
Reply 7 of 23, by agent_x007
Ask yourself this questions :
1) Do you require a GPU that is more powerfull than DX9c GPUs can provide ?
(last NV GPUs with 98 support : 6800 Ultra/7900 GTX [depending on official or non-official driver] and for ATI it's X800/X850 XT).
Keep in mind : There are NO newer GPU that will provide 3D acceleration support in WIndows 98/Me.
Also, ATI cards have worse OpenGL support (they are usually slower in it than NV cards from the same year)
2) Do you want to play games that will not work with XP ?
(or, which are a pain to make work with it [depends on configuration])
If you need better GPU, and still want to play games that don't work well with XP - you either :
1) Need a seperate box for Win98 specific support, OR
2) Make dual GPU configuration inside one box work (cards can be from both ATI and NV, they will be used seperatly, however you will have to swap video outputs depending on OS you want to use).
Reply 8 of 23, by leileilol
Baoran wrote on 2020-11-23, 05:12:
Not always. RadeonHD is worse at legacy compatibility than the GCN series after it, somehow... Yes this implies Win7+GCN > WinXP+RadeonHD for some retro setups.
Reply 9 of 23, by hwh
Hi. Thank you for the replies.
I am dual booting with 7 right now (forgot to...see the relevance), so I can certainly run post XP games with the same system.
A little fun - the card does work (with various shadow/light horizontal line artifacts) as long as it's completely off; if the device is disabled it will work and it works in safe mode. Just looks like crap and drawing is obviously very slow.
I decided to put in the next best card I have - well, technically I have a 9800 PRO that would be just the thing, but this is an 1156 system, no AGP. Next best card is...a Trio 64V+ 🤣
And it's surprisingly better than a cruddy 1280x1024 image. With that, I could watch Youtube videos in the small player, but framerate couldn't keep up in full screen. Plus the image was messed up. With the Trio, it tops out at 1024x768x16 which I don't mind (it's just not native) but, uh, I can watch high resolution video in full screen. And it looks pretty good. And I can scroll pages decently. I could actually use this thing as long as I keep it 2D. Pretty funny.
Hwinfo reports it's got 2MB EDO at 60Mhz and the chip is 135Mhz, really cooking now. Say whatever the hell you want about S3, they built some top quality adapters, just bulletproof, and they just work. As long as you stay in 2D. :p
I've reviewed the replies and the data, and I think I want the GTX 750 Ti. It's got an incredible 60W TDP (the 460 is 160W). Synthetic benchmarks say it's almost 100% faster in 3D and 25% faster in 2D. That's what I'm talking about.
Due to the low TDP, it's known for being a quiet card. There are several amazing (to me) options for this card - almost all used. First there is the Palit KalmX. There's no fan. Just like the old days. This probably can do - and I am so impressed, with nVidia and with Palit for having the courage to do it - but reviewers mentioned it may need "airflow" such as a case fan. I sort of understand, you can't suffocate it, but I don't want the card to overheat while I'm playing a game, break, and so on. Probably wouldn't happen but reviewers were nervous. So this 70C or whatever, full load could get worse over time. Thermal compound isn't invincible.
There are several third party choices that either feature large, low speed fans, or special editions where the fans can be made even less noisy. Believe it or not I looked at this data when I bought my large GTX460. Technology got better even if the world hasn't...
The other one which was pointed out to me is the Asus Strix edition. It's basically an OC'd card (which I care nothing about or for) but, of course, it's the one with the feature that turns the fans off when the temperature is below I think 55C. Why is the one that generates the most heat (I think it's 75W) the one with the silent fan feature? Damned if I know. Why do economy cars not have sound insulation, but the quiet cars all have gas guzzling motors? Because fuck me, that's why. Anyway. This Strix. Not entirely clear if it's software based as seems likely. One user mentioned a PCB switch (oh god yes). Also hard to get.
One on Amazon is going for $210 with shipping. It was only $160 new! And that was a couple of years ago. One went in Australia for not too much, maybe only $110US, postage uncertain. Does not ship here. I offered that he invoice me the $62AUD shipping if I bought it and he ignored me. Then I found this misclassified one (as a non Strix) going for $100. I also saw a couple of Palits.
I prefer not to deal with background services applying settings at startup. So I tried and more or less failed, reading the so called Strix manual to discover how the silent feature works other than that the Asus program has a profile for it, which obviously works. In some operating system or other. I verified the non Strix card had XP support. Then I bought the card. Then I found the Strix page (I was concerned someone else would buy the card - happened to me with a Palit I wasn't sure about) which hilariously starts at Vista up. Even for drivers. So, I don't know. The utility exists for XP too (a somewhat older version). I don't know if it's Strix specific. Would be just damn perfect if the Strix version isn't able to go in silent mode for XP, what a pain in the ass. I even had to double check driver support - yeah, even though they don't list the utility (or any driver) for XP under Strix, definitely has nVidia driver support.
So I'll see how it goes. I tried installing the Vista utility here and it worked. It won't load - I don't know what this world's coming to when a Trio64V+ without DirectX makes the Asus overclocking utility complain about ...dlls? (that sounds like a Vista/XP issue). Won't go further until I have the card. Then I shall see. And maybe report here about it. Can't be worse than the GTX460!
Reply 10 of 23, by ODwilly
The EVGA SC 750ti is really nice. It doesnt have the 6pin power connector and the two decent sized fans dont really make any noise because the card never gets hot.
Reply 11 of 23, by SScorpio
The fans on a 750ti are very quiet, you shouldn't need to worry about having them stop completely. They aren't like blower-style coolers that force a lot of air movement.
If you absolutely need to have custom fan curves you can modify them directly in the card's BIOS. The tools that change settings on launch just do a temporary override, while the BIOS is what the card has when it is given power. But first, try using the card without messing with it.
Reply 12 of 23, by hwh
Got it - it's a little banged up but only the plastic bits on the fan shroud. (Standard recycler practice, throw shit around to get it all scratched up before deciding if you're going to resell it). Amazing packaging - not OEM, but they made the tightest, biggest bubble wrap football around this card and shipped it with FedEx. 2 day air. I didn't even pay separately for shipping. I am a little bewildered.
Anyway, where to begin. The fan control is firmware. The fans spun up when I booted and then promptly shut off. The driver didn't find the card, haw haw, so I had to download a driver again for some reason from nVidia and then it worked. Then Asus's Vista overclocking tool worked. I can control fan speed manually there, but I see no reason at all to. The fan never comes on. Apparently this card struggles to get over 130 degrees. Idle's around blood temperature. I did not remove the heatsink to check the thermal compound.
This card also, in spite of being a factory OC, does not accept supplementary power.
Card characteristics are otherwise identical...it works just like the GTX 460 except the fans never turn on (!) and performance is higher in the few places where I could previously define low performance. That was one thing I sort of figured made this card better than a Palit KalmX: they are both theoretically silent, but this one could turn a fan on if it needed to. The Palit just has a much larger heatsink, which, in theory, won't help if the heat can't escape. Haven't tried it in more demanding settings, but the day will come. I wonder if this helps with video encoding. Probably not. I have bottlenecks in the system but the GTX 460 wasn't one of them.
One unresolved matter is I can't scale or sharpen 4:3. It just gets stretched to 5:4. My poor understanding of the subject is that the card/driver refuse to do it (the option sheet does not appear) and this monitor has no scaler. Odd, IIRC I could turn off stretching (but not scale with aspect ratio), not that I want to play a 1024x768 square in the center of this screen. I guess I need a monitor next. Wouldn't surprise me if it still didn't work for some damn reason.
All in all, this is a wonderful card. Only thing I would change are the scratches and lack of packaging, would love it new but that's unavailable/far out of my budget.
For anyone else in a similar boat, I affirm that the GTX 750 Ti is seemingly a compatible drop in for the Geforce 400 series.
Reply 13 of 23, by SScorpio
hwh wrote on 2020-12-04, 13:42:
The 750 ti includes the 2nd generation of NVENC, while the 460 didn't have NVENC support. With the correct tool this should provide a massive encoding performance increase.
Reply 14 of 23, by hwh
SScorpio wrote on 2020-12-04, 13:51:
Important qualification there. Something tells me I don't have the correct tool or that it won't run on this platform.
*look up*
So, it seems (in spite of the Wikipedia page saying it's supported in many recording programs) that there is a brief list of programs there which do. For instance, OBS (never used it) "relies on DX10 functions" and therefore is only for Vista and above. It could help in Windows 7. Bandicam (which I also know nothing about) seemingly concurrently supported NVENC (1st generation I take it) and XP but I don't know if that will help me. I'm looking into it.
Reply 15 of 23, by pentiumspeed
GTX 750 Ti is rated under 70W and falls in around mid range performance of video cards back in the day that would need 800W PSU. Small problem is driver version might break old games that runs on XP.
Cheers,
Great Northern aka Canada.
Reply 16 of 23, by ODwilly
Got it - it's a little banged up but only the plastic bits on the fan shroud. (Standard recycler practice, throw shit around to […]
I had a GTX 465m with a 1st gen i7 in a laptop for awhile. Used a 750ti in a Q6600 Oc'd to 3.0ghz with the tape mod, can confirm the desktop beat the snot out of the highend gaming laptop and was way quiter and more power efficient
Reply 17 of 23, by SScorpio
hwh wrote on 2020-12-05, 00:13:
It looks like Bandicam requires Win 7+ for nvenc support. A support article is saying the tab won't appear in XP or Vista. Looking at FFmpeg, the last Nvidia driver is 368.81, while the nv_codec_header module requires 456.71 or newer.
I probably was misremembering CUDA powered encoding versus nvenc. It might be necessary to start treating XP like an old console and use external recording solutions. With HDMI you can at least get a digital source signal.
Reply 18 of 23, by hwh
SScorpio wrote on 2020-12-05, 15:11:
I'm looking at it right here. Haven't tested it though, and I'm about to leave for a couple of weeks, so I'll just have to check it when I get some time to.
How would you record externally? Does this mean you have a separate computer with a capture card running which is there solely to record the output of the first computer?
Reply 19 of 23, by schmatzler
My GPU of choice for Windows XP is the MSI N570GTX Twin Frozr III Power Edition/OC.
Comes with a switch on the card for silent mode or power mode - the latter one is extremely loud, but for XP games I don't even need the extra power - so I always run it in Silent Mode and enjoy the games. Crysis runs very well on 1080p.
