Reply 20 of 50, by Gmlb256
ViRGE/DX (or /GX with EDO RAM) with 4MB is the only other S3 card that you could go, make sure that it comes from a good manufacturer for decent image quality. S3 + 3Dfx Voodoo combo isn't that problematic with most pre-2000 games, the Voodoo card tend to be prioritized often and some of them allows you to choose which card will be used for 3D acceleration.
Reply 21 of 50, by darry
Gmlb256 wrote on 2022-07-13, 14:22:
Why not the VX ?
Reply 22 of 50, by Meatball
haker120 wrote on 2022-07-13, 14:21:
I have to, and maybe risk and to buy that Matrox G450? 😁
If seems you don't want good DOS as much as you say then if you're bent on a G450 😉
Reply 23 of 50, by haker120
Well, I found this one and it is dirt cheap, 75PLN without delivery costs.
Reply 24 of 50, by Gmlb256
darry wrote on 2022-07-13, 14:28:
Why not the VX ?
It is the slowest one in lower resolutions despite having VRAM and 220 MHz RAMDAC. There is also a (small) chance to get a VBE 2.0 implementation onboard with ViRGE/DX and /GX cards, eliminating the need for UniVBE and S3VBE20.
Reply 25 of 50, by Meatball
Gmlb256 wrote on 2022-07-13, 14:34:
Why not the VX ?
GX2 is a good one, also.
Reply 26 of 50, by Meatball
haker120 wrote on 2022-07-13, 14:31:
Well, I found this one and it is dirt cheap, 75PLN without delivery costs. […]
Congratulations and good luck!
Reply 27 of 50, by darry
Why not the VX ?
Thank you, I was not aware that there any significant performance difference between them in DOS VGA and VESA modes (I assume that is what you meant by lower resolutions). I will try to read up on this. I am now intrigued .
Reply 28 of 50, by darry
Cool! Please let us know how you like it .
Reply 29 of 50, by Gmlb256
Meatball wrote on 2022-07-13, 14:39:
Why not the VX ?
Indeed, if only the PCI version wasn't nearly impossible to find.
Reply 30 of 50, by RandomStranger
I'm sort of in the same boots. I have a similar PC currently with a Matrox Mystyque 2MB (4MB cards are too long fro my mainboard). I think I chose to go with a Riva128 4MB. I want to keep it as 1997 as possible. The Mystyque is not a very good 3D accelerator, but neither the S3 cards preceding Savage3D so I skipped the Virge cards.
If you want S3, then Savage3D or Savage 4 PCI.
Reply 31 of 50, by haker120
I bought the one I posted its pic. And overall costs 85,95PLN as is $17,97 as of today. 😁
Reply 33 of 50, by 386SX
The never ending Virge/DX cards are quite good but there's the possibility that the VGA output quality might be a bit soft on details or having bright black levels (low contrast ratio). Also usually at 1024x768 they begin to loose quality, they can't do miracles on their specifications. But are very solid cards indeed. Some later one also had only SMD capacitors and no old style components on the PCB with a better final analog quality imho.
Reply 34 of 50, by darry
Sphere478 wrote on 2022-07-13, 16:08:
A radeon 7500 usually works very well in these systems. It is my go to card
It is a nice card, but there are issues with some DOS software.
See https://gona.mactar.hu/DOS_TESTS/
My personal experience with newer Radeons (9700) has not been great with some demos, like Second Reality .
Reply 35 of 50, by Gmlb256
darry wrote on 2022-07-13, 16:24:
It is a nice card, but there are issues with some DOS software. […]
Sphere478 doesn't care much about DOS compatibility. 😵
Reply 36 of 50, by 386SX
I suppose the Radeon 7500 GPU might need some maybe heavy drivers for such config, isn't it? I usually would consider a Radeon 7200 SDR card for a very fast K6-2/3+ config as last upgradable video card maybe with early drivers but a bit more powerful than that and at least possibly using also 3DNow! optimized drivers. 😉
Reply 37 of 50, by Meatball
Gmlb256 wrote on 2022-07-13, 16:29:
He doesn't care much about DOS compatibility. 😵
Sure, he does. Several posts down from the 1st page OP writes:
"And the most important: for 2D DOS titles, no matter DOS Window or DOS mode to get higher resolutions as well, for 3D games either combo card with good DX compatibility and Glide titles on Voodoo 1 4MB."
It's DOS in a window he doesn't care about.
Reply 38 of 50, by Gmlb256
Meatball wrote on 2022-07-13, 16:32:
Sure, he does. Several posts down from the 1st page OP writes: […]
It's DOS windows he doesn't care about.
I was talking about Sphere478, not the OP. 😉
Reply 39 of 50, by Sphere478
I’ve run some dos stuff from windows it seemed okay. But I’m not a huge dos user.
Sphere's PCB projects.
