Reply 820 of 1217, by darry
cvgl wrote on 2020-07-07, 20:44:The menu looks the same with me.
But as I wrote, changing these options does nothing. The image is still cut off. The "SIZE" setting has nothing to do with it, because it is only an adjustment of something like aspect ratio/image aspect ratio. "OUTPUT" is only a digital output image resolution that does not control the input image. Therefore, no matter what is set here, the image is still cut off because 720x400 resolution is not recognized correctly. Unfortunately. Nothing will be done here.
The difference in behaviour of maybe due to different firmware .
