Reply 20 of 27, by elfuego
Malik wrote:
Some interesting information there! Thanks! […]
Coming to SLI, :
Ok, let's say we do have 2 Voodoo2s already in our possession. Like most of here, I suppose. If that's the case, is there anything stopping the use of Voodoo2 SLIs in a socket 7 based system? Are there any detrimental effects, or will the smoothness be the same with a Voodoo1 in these systems?
And for the Voodoo2 12MB in SLI (Total 24MB), will the stuttering be an issue here? Or will the coupled memory compensate that?
No worries - V2 will work flawlessly with K6-based machine, or P1 MMX. The only game I noticed stuttering was Halflife 1 - it happens whenever a new area is entered. Otherwise no stuttering at all.
Reply 21 of 27, by Putas
I would say there is no point in 6MB Voodoo Graphics until 1999. Voodoo 2 8 MB should be fine until 2000 and 12 MB is a similar overkill.
Once upon a time I upgraded my Winchip 200 system from 2d to Voodoo3 3000 PCI and it was great improvement even on that Pentium 100-like CPU.
Reply 22 of 27, by swaaye
I say always avoid 8MB V2. It has the same amount of texture memory as Voodoo1 4MB.
Here are some details for Quake2 on why 4MB texture memory is a plus:
http://www.team5150.com/~andrew/carmack/johnc … .html#d19980216
Reply 23 of 27, by Malik
Just got my Soyo motherboard. I have put in a S3 Virge and 2 Voodoo2 12MB SLI. CPU is Pentium 200 MMX. RAM - 384MB PC100 SDRAM. Will do some benchmarks soon. What games do you guys suggest for testing (so that we can compare with available data)? Currently installed MS-DOS 6.22. Will install Win95c in it soon.
Reply 25 of 27, by Putas
You are right Swaaye, I forgot they have it divided per tmu. If it has to duplicate everything then Voodoo2 is not very forward looking.
leileilol wrote:
Doesn't the Voodoo2 be capable of more buffering the Voodoo1 can't do?
At 800x600 yes.
Reply 26 of 27, by sgt76
Quake 2 and Turok. MDK2 has a nice benchmark but not sure if your system can pull it off.
Reply 27 of 27, by bushwack
Back when I was running a Pentium MMX @ 200, playing Unreal with a Voodoo2 12mb was very choppy, while running a pair of V2's in SLI made the game very playable. It wasn't your typical 2x speed boost, more like 4x boost if running Unreal with a low end CPU. May have been a driver or DirectX issue at the time.
