Best video cards with DOS / Win 3.x / Win 9x support
Reply 160 of 173, by thenix
kolderman wrote on 2020-05-14, 03:16:
thenix wrote on 2020-05-14, 03:05:
kolderman wrote on 2020-05-14, 01:54:
> According to that document the integrated video is the ATI Rage Pro AGP 2X
https://www.dell.com/community/Desktops-Gener … are/m-p/1135058
I guess that's the answer...
I figured it was something like that. However I have my monitor plugged into my card. I feel like even though I have both drivers it isn't using the correct one. For example playing half life I still can't use OpenGL and if i set the display resolution higher it is as laggy as before. Maybe the video card isn't that great? But it seemed to be a highly recommended card. hmmm
Have you disabled onboard vga in bios?
OK so I just had a facepalm moment. I realized I never unplugged my vga cable. So windows was using the vga instead of my dvi. However I'm having a heck of a time telling windows that the DVI is my main screen. I'm working on that now, if you have any quick tips (i'm going to try to disable on board vga) let me know otherwise I'll let you know how it's going.
Reply 161 of 173, by kolderman
1) in windows, remove all the existing monitors and video adapters (and dont reinstall them)
2) reboot and disable onboard vga in bios
3) when windows starts, it should pick everything up as normal
Reply 162 of 173, by thenix
thenix wrote on 2020-05-14, 03:35:
OK so the Bios controls all that. Interesting. I got it set up now. Sorry for the dumb questions but talking it out with you helped me solve it.
Reply 163 of 173, by appiah4
T-Squared wrote on 2020-05-13, 19:06:
appiah4 wrote on 2020-05-05, 22:44:
PCI Riva 128, PCI Riva TNT or PCI Intel i740 are what you want. PCI Matrox Millennium I and II also have working feature connectors, but they may not fulfill all your criteria (Millennium I is better in terms of DOS compatibility IME). If you can find them for <$40 a PCI Voodoo Banshee or a PCI Voodoo 3 will also work.
So a Riva TNT2 won't work?
I would not be sure that all Feature Connectors on TNT2 family cards, particularly later cards like the M64 or Ultra would work, but they are woth a try..
Reply 164 of 173, by T-Squared
appiah4 wrote on 2020-05-14, 06:58:
Argh, I got an M64/64, even though it says TNT2 Series...
I've decided to expand my criteria to AGP too. Will the AGP versions of these cards work, as well?
Reply 165 of 173, by zapbuzz
jaqie wrote on 2012-03-12, 21:30:
You could always go for a radeon 7000 pci, since you only have pci slots - I have one here I keep to test things with, it has DV […]
You could always go for a radeon 7000 pci, since you only have pci slots - I have one here I keep to test things with, it has DVI and VGA out and is PCI is why it works so well for a tester card.
They can be had dirt cheap all day long on ebay.
http://compare.ebay.com/like/310385591118?var … &_lwgsi=y&cbt=y
I have absolutely no clue if it is 3.x compatible, though.
what the hell? I can't find one for under $120 au
Reply 166 of 173, by foil_fresh
so i've been trying to play some build games using the VESA modes but i get the error saying it's not going to work and that i can try univbe. i tried univbe but it says chipset unsupported. blood and duke3d atomic showing the same thing in dos or windows.
my system: nvidia riva 128 agp 4mb (ASUS AGP-V3000), 440bx chipset. win98se.
i assumed the vesa extensions were built into the card's bios. am i missing something fundamental? do i need a special tsr? different windows drivers? agp isnt compatible? i tried with both the default win98se drivers and the drivers from the asus driver cd for the card.
Pentium MMX 166MHz / Shuttle HOT591-p / S3 Virge DX / SB 16
Pentium II 266MHz / Lucky-Star 6ABX2V / Riva128 / AWE64 / AW744L
Pentium III 950 MHz / SY-7VBA / Voodoo 3000 / Aureal Vortex 2
Pentium IV 3.4GHz/ GA-8S655FX / Geforce 6800 GT / Audigy
Reply 167 of 173, by OMORES
For Windows DOS - 3.x-95-98-Me-2k - my first pick would be (and actually is) VooDoo 3 PCI.
DOS - on par with other good cards but you have also DOS GLide option
Windows 3.11 one of the newest cards with available drivers. On my Ryzen 3900x PC - 3dfx Velocity driver is the only Windows driver I can actually install
Windows 95/98/Me - works great driver wise, including Win95A*
Windows 2000 - will recognize Voodoo 3 with default drivers*
*My VooDoo 3 3000 PCI - requires some annoying tuning with Power Strip 2.78 to cover the entire screen @1920x1080. If you know another fix, please tell me.
Reply 169 of 173, by dr.zeissler
Voodoo works, but it's SLOWWWW...against Matrox in Win3x.
Retro-Gamer
PowerMac 6100/66 - Houdini 486/66 PC-Card MacOS7/Dos622
PowerMac G4- Cube 450/Rage128pro
Macintosh LC - Apple IIe Card
Acorn A4000 Archimedes
Reply 170 of 173, by darry
dr.zeissler wrote on 2020-06-20, 22:43:
Are there any Windows 3.1 applications/games that both require graphical speed and cannot be run properly under Windows 9x ?
I do not currently have a Windows 3.1 setup and I wonder if I am missing out on something .
EDIT: I hardly used Windows 3.1, except to run word processorsand a few other office type applications. For all the rest, I stayed in DOS and eventually switched to Windows 95.
Reply 171 of 173, by Grumgi
The card I'm about to suggest is kind of a piece of junk, but if you don't want to spend any more than 10 or so dollars, a Cirrus Logic 5465 should work just fine. It's still available on Amazon, in fact. It's a PCI card with only I think a single mb of VRAM. It's not incredibly powerful by any stretch and OpenGL will probably kill it (poor thing), but it supports 1024x768 and 32 bit color. The drivers should be floating around, but if you can't find it, know that it's on any Windows 98SE CD. Don't try any resolutions higher than 400x300 on something like Quake, or 640x480 on anything else.
https://www.ebay.com/itm/3Dlabs-Permedia-2V-P … 4AAAOSwh-Je-5lf
This thing might fit the bill too, but I'm rather unfamiliar with this card.
Reply 173 of 173, by appiah4
Schyz wrote on 2020-08-01, 21:05:
I think the best for a DOS + Win3.1 + early Win9X setup is a Cirrus Logic SVGA + 3Dfx 4Mb.
Early CL SVGAs with good DOS compatibility tend to have pretty poor Windows acceleration in Win9x IME.
