Doom 3 timedemo shootout with period correct hardware.
Discussion about old graphics cards, monitors and video related things.
Postby Skyscraper » 2014-9-26 @ 17:06
After reading the thread about ridiculous hardware requirements I felt like building a period correct system for playing Doom 3 with hardware available at release.
Perhaps there are others with period correct hardware who wants to contribute results to a toplist? Who has the lo.. fastest period correct Doom 3 system?
When Doom 3 was released the best Intel CPUs were the Northwood, Prescott 5xx, Gallatin and the Dothan. The best AMD CPUs were different flavours of single core K8 (Athlon 64/Opteron).
When it comes to motherboards the latest chipsets for Intel CPUs were i875P, i865, i915 and i925X.
For AMD the latest chipsets at the Doom 3 release were the Nforce3 and the VIA K8T800 PRO.
Update: Note that the period correct hardware cut off has been changed to 2004-12-31 and even some later A64 steppings such as the San Diego are allowed in many cases as they perform the same as the Clawhammer core and many year 2004 A64 models were made using both core revisions. Read the clarification below.
When it comes to Video Cards, PCI-E was the new hot thing and the top cards were the ATI X800 XT PE and the Geforce 6800 Ultra. The ATI X850 series only adds PCI-E interface to the X800 series so we can include those aswell. SLI and Crossfire were not available to the wide public in August 2004 so no dual action in the period correct list. (late Nov for SLI, early 2005 for Crossfire if I remember correctly)
Of course all older hardware is also OK, so is new systems but the idea is to run somewhat period correct hardware. Too new systems will have their own separate toplists. :evil:
If your system is overclocked then write something like this "P4 Northwood 2.8(200)@3200(228), DDR1@456(CL2,2,2,5)" and so on so people quickly can see why just your system perform so well.
Update: it seems the DEMO cant run the timedemo, Im trying to find a fix. The Doom 3 demo can be found here: http://www.fileplanet.com/145822/download/DOOM-3-Demo
Press "Ctrl + Alt + ~" to bring the console down
The command to run the timedemo is "timedemo demo1 1" The last 1 is to buffer the demo, otherwise a second run will always be faster.
Update: The Doom 3 DEMO will not run the timedemo and no fix exists, you need the real game.
Update: Doom 3 version 1.0 is faster than version 1.3 and 1.31. If a system looks a bit too slow in the list this could be the reason, many of my own scores were made using this slower version.
The performance difference varies depending on the system. Less when it comes to period correct systems, more with modern systems. Less with a GPU bottleneck, more with a CPU bottleneck.
If you own a physical copy of Doom 3, install from your discs and do not update to the latest version! If you already own the Steam version and can't find an original disc on Ebay be creative.
Sceeenshots showing results and computer spec posted in the thread is encouraged but not required. More details are better than less but when writing your spec for the entry it's good to look at the length of other entries and what information is included as I will butcher every entery so it "fits". If unsure what to inlcude just include everything and I will shorten it down. Be sure to include motherboard information!
Clarification and changes when it comes to period correct CPUs, chipsets and video cards. Discussion about the rules can be found in the thread.
Intel CPUs: If the CPU was released in 2004 or earlier.
Top CPUs: P4 570, P4 EE 3.4 and P4 EE 3.46. Dothan Pentium M 765.
Intel chipsets. All chipsets released 2004 and earlier. All versions of the i915 chipset are allowed as they are basicly the same thing just targeted at different brackets.
Top chipsets: i875P, i865, i915, i925X, i925XE.
AMD CPUs: ALL single core socket 754/939/940 (but not AM2) CPUs with a default speed of 2.6* GHz or less. (Even San Diego and Venice).
Top CPUs: A64 FX55, Opteron 152/252*, Opteron 250*. Opteron 152 and 252 entries will be called something like "Opteron 152 (FX55)" as they are allowed only because they are the same thing as a San Diego FX55.
AMD chipsets. All chipsets released 2004 and earlier. The nForce4 Pro/32 chipset is allowed even though it's technically a year 2005 chipset as the 18 extra PCI-E lanes bolted on using "CK8-04" isn't used when using a single video card.
Top AMD chipsets. Nvidia nForce3 and nForce4, VIA K8T800, K8T800 Pro and K8T890.
*If the system uses two CPUs then max 2.4 GHz which corresponds to the Opteron 250. A dual 2.6 GHz Opteron system was not available before the date Feb 14 2005.
Nvidia video cards. All Geforce 6 series cards or older.
ATI video cards. All Radeon X8x0 series cards or older.
Simulating a period correct CPU for the non overclocked period correct list using a non period correct CPU is okey as long as it's a perfect simulation like using a FX57 running at 13*200 and calling it a FX55. Using a Geforce 6800 GT clocked at the Geforce 6800 Ultra clocks and calling it a Geforce 6800 Ultra is also fine. Almost all of my own period correct entries, both AGP and PCI-E were made using Geforce 6800 GT video cards clocked at 400/1100.
Edit 2019-03-17
As we have an entry in the period correct list with an 6800 Ultra @425 MHz default GPU clock speed setting the GPU clock to 425 MHz on any 6800 card (use Rivatuner) is of course fine. Stock memory speed for a Geforce 6800 card is still regarded as 1100 MHz (or less) for now but might change in the future if someone posts a score with a card having faster stock memory clocks and I find it likely such a card could be bought in late 2004.
/Edit 2019-03-17
A system can only have a single placement in each list. Additional lower scores using different CPUs and video cards are welcome but will be marked with "X" in the list.
What identifies a unique system is the motherboard and only the motherboard.
If you get a better score with a system you have already posted the list will be updated with your new score and placement.
The overclocked and non overclocked lists are considered different lists, there is only a single "Anything goes toplist" as anything goes.
Settings 1024*768 with UItra Quality and sound enabled. This goes for all lists including the anything goes list.
Period Correct Toplist
- only Chipsets, GPUs and CPUs that were released before Dec 31 - 2004. No SLI in the period correct list but using two CPUs is allowed.
Changed the cut off date from Aug 3 to Dec 31 - 2004, it solves alot of issues.
Stock settings.
1. 113.5 FPS, Skyscraper, A64 FX55 (San Diego), DFI nF4 SLI-DR, 2x512MB DDR475 2-2-2-5 1T, 6800 Ultra+ (425/1100) 66.93, Audigy 2, XP-SP3
2. 109.2 FPS, lost77, FX55 (San Diego), MSI K8N Neo2 Platinum (nF3), 2x512MB DDR400 2,2,2,5 1T, 6800 Ultra+ (425/1100) 66.93, Audigy 2 ZS, XP-SP3
3. 106.0 FPS, Skyscraper, 2x Opteron 248 2.2GHz Sledgehammer, MSI K8T Master2 FAR, 2GB DDR314 CL2-3-3-7, 6800Ultra 92.91, onboard audio, XP-SP3
4. 105.6 FPS, Skyscraper, P4 EE "Gallatin" 3.4. Asus P4C800 Deluxe v2.0. 2x512MB DDR400 CL2,2,2,5, Geforce 6800Ultra 92.91, onboard audio, XP-SP3
5. 105.4 FPS, PhilsComputerlab, A64 San Diego 4000+, Asus A8V VIA K8T800 Pro, 2x1GB DDR400 CL3,3,3,8 1T, GF 6800Ultra 93.71, X-Fi X.Gamer, XP-SP3
6. 102.7 FPS, Munx, A64 San Diego 4000+, Winfast nf4uk8aa (Nforce4 Ultra), 2x1GB DDR400 CL 2.5-3-3-5, Radeon X850XT PE 7.10, Audigy2 zs, XP-SP3
7. 102.1 FPS, Skyscraper, (v1.3) FX55 2.6GHz, A8N32-SLI Deluxe Nforce4. 2x1GB DDR475 CL2.5-3-3-5, Geforce 6800Ultra 92.91, onboard audio, XP-SP3
X. 101.5 FPS, Skyscraper, (v1.3) FX55 2.6GHz, A8N32-SLI Deluxe Nforce4. 2x1GB DDR475 CL2.5-3-3-5, Radeon X850XTPE 7.10, onboard audio, XP-SP3
8. 101.1 FPS, Skyscraper, Pentium 4 570 3.8GHz, Abit Fatal1ty AA8XE i925XE, 2GB DDR2-800 CL4,4,4,12, Geforce 6800 Ultra 92.91, onboard audio, XP-SP3.
9. 100.2 FPS, Vetz, Pentium 4EE 3.2ghz S478, ASUS P4C800-E Deluxe, 2x512MB DDR400 CL2,2,2,5, 6800Ultra AGP 92.91, X-Fi Platinum Fatal1ty, XP SP3
10. 98.5 FPS, Standard Def Steve, A64 3700+ 2.2GHz-0.09um, 6800GT AGP 307.83, 2GB DDR400, Gigabyte K8NSC-s939 NF3 250gb, Onboard audio, XP-SP3
11. 96.3 FPS, PhilsComputerlab, A64 3700+ 2.4GHz 0.13, Gigabyte GA-K8VM800M, 2x1GB DDR400 CL2,3,3,6,T1, 6800 GT 93.71, X-Fi XtremeGamer, XP SP3
X. 91.9 FPS, Vetz, Pentium 4 HT 1M 3.4ghz S478, ASUS P4C800-E Deluxe, 2x512MB DDR400 CL2,2,2,5, 6800Ultra AGP 92.91, X-Fi Platinum Fatal1ty, XP SP3
12. 91.2 FPS, Skyscraper, Gallatin P4 EE 3.4 no HT, Asus P4B533-E i845E, 1x1024MB DDR400 CL2-3-3-6, Geforce 6800Ultra 92.91, onboard audio, XP-SP3.
13. 90.5 FPS, cxm717, A64 3500+, Asus A8V K8T800Pro, 2GB DDR400 CL3,3,3,8 2T, x800pro 16pipe mod omega 3.8.413, onboard audio, XP-SP3
14. 88.7 FPS, NamelessPlayer, P4 EE Gallatin 3.2 GHz, 2GB DDR400 2.5-3-3-6, GF 6800Ultra Extreme 77.77, Auzentech X-Fi Prelude, XP Pro SP3
15. 85.3 FPS, Jax, P4 3.2E, P4P800-SE, DDR 400 2x512MB 3 3 3 8, ASUS V9999 6800Ultra 256Mb (92.91 driver), 250GB SATA, SB Live! 5.1, Windows XP SP3
16. 81.9 FPS, candle_86, A64 San Diego 1.8 (Opteron 144), 1gb OCZ Gold DDR500, BFG 6800GS OC 92.91, Epox 9nda3j 5.10, Soundblaster Audigy, XP-SP3
17. 78.9 FPS, PhilsComputerlab, P4 3.4EE, Aopen MX4SG-4DN i865, 2xCMX1024-3200C2PT DDR400 CL2-3-3-6, GF 6800GT, 93.71, X-Fi XtremeGamer, XP-SP3
X. 79.8 FPS, Skyscraper, (v1.3) P4 3.4 Northwood, Asus P4C800 Deluxe i875P, 2x512MB DDR400 CL2-2-2-5, 6800Ultra AGP 92.91, onboard audio, XP-SP3.
18. 72.9 FPS, Tommaso72, Northwood 3.06, ASUS P4P800 LE, 2x256MB + 2x128MB DDR333 DC, GeForce 6800 128 meg, SB Live 5.1 value, XP-SP2.
19. 67.5 FPS, Skyscraper, (v1.3) P4 530 3.0, Abit AA8 925X optimized defaults, 2GB DDR2@533CL4-4-4-12, 6800GT 256MB 92.91, onboard audio, XP Pro SP3.
20. 66.3 FPS, candle_86, P4 3.0C, 1gb OCZ Gold, Abit IC7-G 875p, ATI All In Wonder x800XT, SoundBlaster Audigy Plantnium, XP SP3
X. 64.1 FPS, candle_86, P4 3.2 Northwood, Abit IC7-G, 2gb DDR400, Geforce 6800GS 92.91, SoundBlaster Audigy Platnium, XP SP3
21. 63.3 FPS, Jax, P4 Prescott 540 3.2Ghz HT, Asus P4P800SE (i865PE), 2GB DDR400 2.5-3-3-5 single ch, Radeon X850XT PE 10.2, onboard audio, XP-SP3
22. 55.9 FPS, Skyscraper, Athlon XP-M 2800+ (16x133), Abit KG7 (AMD 760 chipset released Oct 2000), 1GB DDR266 2225, GF6800Ultra 92.91, Audigy, XP-SP3
23. 54 FPS, Standard Def Steve, P4 2.66GHz (Northwood, 533MHz FSB), 2GB DDR333 CL2.5, GeForce 6800GT AGP (81.98), i845, SB Live, WinXP SP3
24. 53.5 FPS, Elianda, Athlon XP 3200+ (Barton 2.2), 200MHz FSB, GF 6800GT 307.83, 2GB DDR 2.5 3 3 6, Asrock K7NF2-RAID, X-Fi Xtreme Music, XP MCE SP3
25. 52.7 FPS, candle_86, Athlon XP 2800+, ECS K7VTA3 V 8.0, 1gb DDR333 2-2-2-5 1t, ATI X800XT All In Wonder, Soundblaster Audigy Platnium EX, XP-SP3
26. 52.7 FPS, philscomputerlab, P4 3.2 GHz Northwood Socket 478, Asrock P4i65G, 2GB DDR400, AGP Nvidia GeForce 6600 GT 307.83, Audigy 2 ZS, XP SP2.
X. 50.7 FPS, Tommaso72, Northwood 3.06, ASUS P4P800 LE, 2x256MB + 2x128MB DDR333 DC, GeForce FX 5800 Ultra 128 meg, SB Live 5.1 value, XP-SP2.
27. 48.6 FPS, Standard Def Steve, Athlon XP 2400+ (2GHz, 266MHz FSB), 2GB DDR333 CL2.5, nForce2, 6800GT AGP (182.06), onboard audio, XP Pro SP3
28. 47.2 FPS, Standard Def Steve, Celeron D 335 2.8GHz, GeForce 6800GT AGP (81.98), 1GB PC2700/CL2.5, Dell i865 mobo, onboard audio, XP-SP3
29. 44.4 FPS, JayCeeBee64, P4 2.4GHz Northwood, Soyo P4I-845PE, 2GB DDR-333, GF6600 256mb AGP 169.28, Dynex DX-SC51, DirectX 9.0c, XP SP3.
30. 42.4 FPS, cxm717, A64 3500+ 2.2GHz, 512KB, Asus A8V s939 VIA K8T800 Pro, 2x1Gb DDR400 CL3,3,3,3,8, ATI FireGL X1 8.583, onboard audio. XP-SP3
X. 42.2 FPS, Standard Def Steve, P4 2.2GHz (Northwood, 400MHz FSB), 2GB DDR266 CL2.5, GeForce 6800GT AGP (81.98), i845, SB Live, WinXP SP3
31. 40.3 FPS, foey, P4 3.0Ghz Prescott, Intel i865P s478 (Its a Dell!), 1GBDDR400 Dual Channel, FX 5950 Ultra 256MB AGP 8x Graphics Card, Creative Audigy
X. 39.7 FPS, philscomputerlab, P4 3.2 GHz Northwood Socket 478, Asrock P4i65G, 2GB DDR400, GeForce FX5950 Ultra 175.19, Audigy 2 ZS, XP SP2.
32. 38.9 FPS, AlphaWing, XP 2600+ 2.1GHz\256KB\166FSB, MSI-MS7021-VIAKT800 1GB DDR@166-2-2-2-6 ,FX5900U, 8xAGP, 93.71, Yamaha YMF724, XP-SP3.
33. 38.7 FPS, AlphaWing, Amd Xp 3000+ Nf2 1GB DDR 400 DC, Geforce FX 5800 128mb SBLIVE!
X. 35.9 FPS, JayCeeBee64, P4 2.4GHz Northwood, Soyo P4I-845PE, 512mb DDR-333, GF6600 256mb AGP 82.63 (W9x), Turtle Beach Santa Cruz, DX 8.1b, 98SE.
34. 34.4 FPS, Skyscraper, Willamette P4 2.0, Asus P4B533-E i845E, 1x512MB DDR266 CL2-2-2-5, Geforce 6800GT 92.91, onboard audio, XP-SP3
35. 32.3 FPS, candle_86, Athlon XP 2500, Abit NF7-S2G, 1gb DDR 333 2-2-2-6, BFG FX 5900 169.21, Sound Blaster Live, Windows XP
36. 31.7 FPS, soviet conscript, Tualatin PIII @ 1.4ghz X 2, Gefore 6800 OC 128MB, 1GB PC133 SDRAM, Tyan Tiger S2507t
X. 30.2 FPS, Standard Def Steve, P4 1.8GHz, 400MHz FSB, 2GB DDR266 CL2.5, i845, GeForce 6800GT (182.06), SB Live, XP Pro SP3
X 25.2 FPS, Standard Def Steve, Celeron 2.6 GHz (128K L2, 400FSB), 2GB DDR266 CL2.5, GeForce 6800GT AGP (81.98), i845, SB Live, WinXP SP3
37. 25.1 FPS, Munx, Northwood 2.4 GHz, Radeon 9800 XXL (shows up as XT), 512MB DDR-266 2.5-3-3-7, Intel D845GERG2 i845GE, Onboard AD1981B, XP-SP3
38. 21.5 FPS Standard Def Steve, Celeron 1400, 100MHz FSB, 1.5GB SDRAM 2-2-2, GF6800GT AGP (81.98), XP Pro SP3, VIA 694T, X-Fi Extreme Music
39. 19.3 FPS, Skyscraper, Celeron 2600 Northwood 128kb, Asus P4B i845 SDR, 512MB PC133 CL2-2-2-6, Geforce 6800GT 92.21, onboard audio, XP-SP3
40. 17.1 FPS, AlphaWing, 1200MHz Celeron Tualatin- DFI CA64-TC- Via Apollo Pro 133Z - 512BM PC133 - 2-2-2 - GF FX5700U ref AGP 4x 56.64, CT1740, 98SE.
41. 14.1 FPS, Standard Def Steve, PIII-850, 100MHz FSB, i440BX, 768MB SDRAM 3-3-3, Radeon 9800Pro (cat 7.3), SBLive, XP Pro SP3
42. 12.5 FPS, rick6, Pentium III 1000(133), Compaq Deskpro i815, 512MB PC133, Geforce 6200 PCI 84.21, oboard audio?, Windows XP.
X. 10.9 FPS, JayCeeBee64, P4 2.4GHz Northwood, Soyo P4I-845PE 512mb DDR-333, FX5500 256mb AGP 82.63 (W9x), Turtle Beach Santa Cruz, DX 8.1b, 98SE.
X. 8.6 FPS, JayCeeBee64, P4 2.4GHz Northwood, Soyo P4I-845PE, 512mb DDR-333, GF4 Ti 4200 128mb 45.23, Turtle Beach Santa Cruz, DX 8.1b, Win 98SE.
43. 8.0 FPS, Standard Def Steve, Celeron 2.6GHz, 400Mhz FSB, 1GB DDR400, i845, Radeon 9250 PCI 256MB (Cat 5.6), onboard audio, XP Pro SP3
X. 7.5 FPS, Standard Def Steve, PIII 550MHz (Katmai, 100MHz FSB), 768MB SDRAM 2-2-2, Radeon 9800 Pro (cat 7.3), i440BX, SBLive, XP Pro SP3
44. 6.2 FPS, JayCeeBee64, Pentium 3 1000EB, Asus CUSL2-C, 512mb PC133, GF3 Ti 200 64MB 30.82 WHQL, Turtle Beach Santa Cruz, DirectX 9.0c, XP SP3.
X. 6.0 FPS, JayCeeBee64, Pentium III 800EB, Asus CUSL2-C, 512mb PC133, GF3 Ti 200 64MB 30.82 WHQL, Turtle Beach Santa Cruz, DirectX 9.0c, XP SP3.
X. 5.7 FPS, JayCeeBee64, P4 2.4GHz Northwood, Soyo P4I-845PE 512mb DDR-333, GF3 Ti 200 64mb 30.82 (W9x), Turtle Beach Santa Cruz, DX 8.1b, 98SE.
45. 5.3 FPS, Standard Def Steve, Mobile P4 532 3.06GHz w/HT 1MB L2 533 MHz FSB, 1GB DDR333 CL2.5, Radeon 9000 IGP, onboard audio, XP Pro SP3
X. 4.7 FPS, JayCeeBee64, Celeron 600, Asus CUSL2-C, 512mb PC133, GF3 Ti 200 64MB 30.82 WHQL, Turtle Beach Santa Cruz, DirectX 9.0c, XP SP3.
Overclocked.
1. 124.5 FPS, Skyscraper, A64 4000+ San Diego @3060 , DFI nF4 SLI-DR, 2x512MB DDR510 2-3-2-7 1T, GF6800GT (460/1200) 66.93, Audigy 2, XP-SP3
2. 122.6 FPS, lost77, FX55@3135 (San Diego), MSI K8N Neo2 Platinum (nF3), 2x512MB DDR418 2,2,2,5 1T, 6800 Ultra+ (470/1232) 66.93, Audigy 2 ZS, XP-SP3
3. 120.6 FPS, Skyscraper, A64 4000+@3120 San Diego, DFI nForce4 Ultra-D, 2x1GB DDR520 CL3,3,2,7 1T, GF6800GT@425/1100 92.91, onboard audio, XP-SP3
4. 116.2 FPS, havli, Athlon 64 3700+@2.8 GHz San Diego, Asus A8N-E NF4, 2x 512MB DDR466 CL2.5-3-3-5, GF6800GT@425/1100 91.31, Audigy SE, XP-SP3
5. 111.1 FPS, Skyscraper, Pentium 4 570@4.4GHz, Abit Fatal1ty AA8XE i925XE, 2GB DDR2-694 CL3,3,3,8, 6800GT@435/1150 92.91, onboard audio, XP-SP3.
6. 109.5 FPS, Skyscraper, (v1.3) A64 3700+@3GHz San Diego, A8N32-SLI Deluxe Nforce4. 2x512MB DDR429 2-3-3-6, "6800 Ultra" 92.91, onboard audio, XP-SP3
7. 108.7 FPS, Standard Def Steve, A64 3700+@2.8 San Diego, 6800GT AGP 307.83, 2GB DDR400, Gigabyte K8NSC-939 NF3 250gb, Onboard audio, XP SP3:
8. 106.4 FPS, candle_86, A64 San Diego @ 2618mhz 3x290, 1GB DDR500, 6800GS OC Unlocked 16pp6v @ 430/1200 92.91, Epox 9nda3j 5.10, Audigy, XP SP3
9. 106.3 FPS, cxm717, A64 3500+ @2.5, Asus A8V K8T800Pro, 2GB DDR500 CL3,3,3,8 2T, x800pro 16pipe mod 520/560 omega 3.8.413, onboard audio, XP-SP3
11. 104,4 FPS, Vetz, P4 HT 1M 3.4@4.08 S478, ASUS P4C800-E Deluxe, 2x512MB DDR384 CL2,2,2,5, 6800Ultra@423/1140 92.91, X-Fi Platinum Fatal1ty, XP SP3
12. 104.2 FPS, Standard Def Steve, Pentium M 755 2.0@2.66, 533MHz FSB, GF 6800GT 307.83, 2GB DDR2533, MSI Speedster i915, onboard audio, XP Pro SP3
13. 97.4 FPS, Skyscraper, Gallatin P4 EE 3.4@3740 no HT, Asus P4B533-E i845E, 1x1024MB DDR440 CL2.5-3-3-7, Geforce 6800Ultra 92.91, onboard audio, XP-SP3
14. 91.0, FPS, Skyscraper, (v1.3) P4 540 3.2@4266 266 MHz FSB, Abit AA8 925X, 2GB DDR2@533CL3-3-3-8, "6800 Ultra" 92.91, onboard audio, XP Pro SP3
15. 89.3 FPS, Standard Def Steve, P4 520@3.73GHz, 1066 FSB, 2GB DDR2667 CL4, Asus P5ND2-SLI Deluxe NF4 SLI IE, 6800GT 182.06, onboard audio, XP-SP3
16. 87.3 FPS, candle_86, P4 3.0C Northwood @3.75 250FSB, Abit IC7-G, 1gb DDR500, GF6800GS @425/1100 unlocked 16pp/6v 92.91, Audigy Platnium XP-SP3
X. 82.1 FPS, candle_86, P4 3.0C@3.75 250MHz FSB, 1gb DDR PC3600 OCZ Gold, Abit IC7-G 875p, ATI AiW X800XT, Soundblaster Audigy Platnium EX, XP SP3
17. 69.7 FPS, agent_x007, P4 EE 3.46 @ 4GHz, Asus P5WD2 i955X, 4x1GB DDR2-771 CL3-3-3-8, Geforce 6800Ultra @437/1134 309.08, onboard audio, Win7
18. 67.6 FPS, F2bnp, Northwood 3.0GHz@3120MHz, Intel D875PBZ, 2x1GB DDR400, Geforce 6800LE@370/750 all pipes unlocked, Audigy 2 ZS, XP-SP3
19. 56.4 FPS, agent_x007, P4 EE 3,2GHz@3,528GHz, Gigabyte GA-8PENXP 865PE, 4GB DDR-440 CL2.5.3.3.8, 9800XT 256MB 425/770 9.1, Audigy 2 ZS, XP-SP3.
20. 55.9 FPS, candle_86, Athlon XP 2800+ @176x12.5=2200, ECS K7VTA3 V8.0, 1gb DDR352 2-2-2-5 1t, X800XT AIW @540/1120, Audigy Platnium EX, XP-SP3
21. 50.8 FPS, PIII-S @1628MHz 155MHz FSB, 2GB DDR @310MHz 2-2-2-5, QDI Advance 12T Apollo Pro 266T, 6800GT AGP 81.98, X-Fi Platinum, XP MCE 2005 SP3
22. 49.7 FPS, candle_86, AMD Athlon XP 2500 @ 2.2GHz, ABIT NF7-S2G, 1gb DDR400, BFG FX 5900 450/900 93.71, Sound Blaster Live! XP-SP3
23. 47.1 FPS, Skyscraper, Pentium III 1400-S @1680MHz, CUSL2-C i815, 1x512MB PC133@160MHz CL2-2-2-7, Geforce 6800GT 92.91 AGP2X, SB Live, XP-SP3
24. 43.9 FPS, Skyscraper, Willamette P4 2.0@2340, Asus P4B533-E i845E, 1x512MB DDR312 CL2-2-2-5, Geforce 6800GT 92.91, onboard audio, XP-SP3
25. 41.5 FPS, Standard Def Steve, PIII-S 1400@1585, 151MHz FSB, 1.5GB SDRAM 2-2-2, EVGA 6800GT AGP 81.98, XP Pro SP3, VIA 694T, X-Fi Extreme Music
26. 34.6 FPS, Imperious, Athlon XP-M(Barton)@2.244GHz, ATI 9800XT@412-742 Cat 6.11, 512MB PC133/CL2, Abit KT7-Raid, Yamaha YMF-724 Pci, XP-SP3
X. 33.1 FPS, Standard Def Steve, PIII-S 1400@1585, 151MHz FSB, 1.5GB SDRAM, Radeon 9800Pro Catalyst 7.3, WinXP Pro SP3, VIA 694T, X-Fi Extreme Music
27. 32.6 FPS, SPBHM, Pentium 4 512KB 2.4GHz@3GHz, Asus P4PE i845PE, 1GB DDR 333 CL2,2,2,6 Single, FX5900SE 400/700 93.71, Onboard Audio, XP-SP3
28. 31.3 FPS, Skyscraper, P4 Willamette 1900@2375MHz, Asus P4B i845, 512MB PC133@166MHz CL3-3-3-7, Geforce 6800GT 92.91, onboard audio. XP-SP3
X. 28.4 FPS, Standard Def Steve, Celeron 1400 @ 1596MHz, 114MHz FSB, 1.5GB SDRAM 2-2-2, GF6800GT 81.98, XP Pro SP3, VIA 694T, X-Fi Extreme Music
29. 27.1 FPS, SPBHM, Pentium 4 2.4B @ 3GHz, Asus P4PE 845PE, 768MB DDR-333 CL2.5, Radeon 9500PRO 128MB @ 330/610 10.2, onboard AD1980, XP-SP2.
X. 20.1 FPS, Standard Def Steve, P3-1000 @1133MHz, 151MHz FSB, 1.5GB SDRAM 2-2-2, GeForce 6800GT AGP 81.98, VIA 694T, X-Fi Extreme Music, XP-SP3
X. 6.5 FPS, Standard Def Steve, Athlon 64 3700+ @2.64GHz, GF FX5200 128MB/64-bit 81.98, 2GB DDR-400 CL2, Gigabyte K8NSC-939, onboard audio, XP SP3
Less strict somewhat period correct toplist - K8 or Netburst CPU(s), DX9 GPU(s),
Stock settings.
1. 190.1 FPS, Skyscraper, A64 X2 6000+ 3.0, Asus M2N-SLI Deluxe nForce 570, 2x1GB DDR2 750 3-3-3-8, Geforce 7900GTX, 92.91, X-fi XtremeMusic, XP SP3
2. 177.1 FPS, candle_86, AMD Athlon 64 X2 6000+ 3.0, 8gb DDR2 750, ASUS M2N-E SLI, PNY 7900GTX SLI 92.91, onboard Sound, Windows XP Home SP3
3. 130.9 FPS, havli, A64 X2 6000+, MSI K9A2 Platinum (790FX), 2x2 GB DDR2 750 CL5-5-5-15, GF6800GS SLI 309.08, onboard audio, win7-64
4. 130.5 FPS, PhilsComputerlab, A64 FX60 2.6, Asus A8V VIA K8T800 Pro, 2x1GB DDR400 CL3-3-3-8 1T, X1950 PRO 512MB AGP 6.12, X-Fi X.Gamer, XP-SP3
5. 127.7 FPS, Skyscraper, (v1.3) AMD64 FX60 2.6GHz, Asus A8N32-SLI Nforce4, 2GB DDR475 CL2.5-3-3-5, Geforce 7900GTX 92.91, onboard audio, XP-SP3.
6. 117.2 FPS, Skyscraper, (v1.3) Pentium D 965 EE, Gigabyte X48 DS4, 2GB 1066 MHz DDR2 CL4-5-4-13, Geforce 7900GTX 92.91, onboard audio, XP-SP3.
X. 112.8 FPS, Skyscraper, (v1.3) AMD64 "FX57" 2.8GHz, Asus A8N32-SLI Nforce4, 2GB DDR470 CL2.5-3-3-5, Geforce 7900GTX 92.91, onboard audio, XP-SP3.
X. 112.4 FPS, Skyscraper, (v1.3) AMD64 "FX57" 2.8GHz, Asus A8N32-SLI Nforce4, 2GB DDR470 CL2.5-3-3-5, 7800GTX 256mb 92.91, onboard audio, XP-SP3.
7. 105.4, HeavyD8086, Pentium D 945, Dell Optiplex 745 (Q965), 2x2GB DDR2 800 6-6-6-18, Radeon X1800 6.12, onboard audio, XP-SP3
8. 85.1 FPS, sunaiac, Asrock 939 Dual Sata II, Athlon FX-55 SSE (0.09), Radeon X1950pro AGP 10.2, 2GB RAM DDR400, perhaps onboard audio?, Windows 7.
9. 80.5 FPS, kanecvr, Pentium D 940 3.4GHz 4MB cache, i865 Foxconn, 2x512MB DDR400, X1950 PRO 256MB AGP 10.02, X-Fi Xtreme Audio, XP Sp3
10. 76.1 FPS, tincup, P4-3.6 Prescott 800/2mb, BioStar P4M890-M7-TE/socket 775, EVGA 7900GTX 92.91, 2gb DDR2/pc4300, SBLive!, XP Pro SP3
11. 72.5 FPS, havli, P4 3.0 Northwood (HT), Asus P4P800 DLX, 2x512MB DDR400 CL2.5-3-3-5 (PAT), GF7800GS AGP 500/1400 275.33, onboard audio, XP SP3
12. 70.1 FPS, philscomputerlab, S754 AMD Athlon 64 3400+ "Venice", 2 GB DDR 400 CL3,3,3,8 2T, GeForce 7900 GTX 307.83, X-Fi Titanium PCIe, XP-SP3
X. 65.2 FPS, havli, P4 3.0 Northwood (no HT), Asus P4P800 DLX, 2x512MB DDR400 CL2.5-3-3-5 (PAT), GF7800GS AGP 500/1400 275.33, onboard audio, XP SP3
13. 68.8 FPS, AlphaWing, Pentium D 935 3.2, Asus-P5DVC-MX-ViaP4M800, 2GB DDR2 PC5300,266mhz-5-5-5, AGP BFG GF6600 GT 128mb-175.14, SBLIVE! XP-SP3
14. 65.2 FPS, havli, P4 631 HT, Asrock 775i65G R3.0 i865G, 2x512MB DDR400 CL 2.5-3-3-8, Radeon X800 XT PE AGP 10.2, Creative X-Fi XtremeMusic, XP-SP3
15. 56.7 FPS, havli, Athlon XP 2800+ 2083 MHz (Barton 333), Abit NF7 + 2x512MB DDR333 CL2-2-2-5, GF7800GS AGP 500/1400 275.33, onboard audio, XP SP3
X. 52.5 FPS, havli, Athlon XP 2600+ 1917 MHz (Tbred-B 333), Abit NF7 + 2x512MB DDR333 CL2-2-2-5, GF7800GS AGP 500/1400 275.33, onboard audio, XP SP3
16. 52.4 FPS, tgod, AMD Sempron 2800+ 1.6ghz, Geforce 7800gs AGP, 1gb DDR, Biostar K8M800-M7A, XP
X. 43 FPS, havli, Athlon XP 2200+ 1800 MHz (Tbred 266), Abit NF7 + 2x512MB DDR266 CL2-2-2-5, GF7800GS AGP 500/1400 275.33, onboard audio, XP SP3
X. 42 FPS, havli, Athlon XP 2000+ 1667 MHz (Tbred 266), Abit NF7 + 2x512MB DDR266 CL2-2-2-5, GF7800GS AGP 500/1400 275.33, onboard audio, XP SP3
X. 31.5 FPS, havli, Duron 1400 (Applebred 266), Abit NF7 + 2x512MB DDR266 CL2-2-2-5, GF7800GS AGP 500/1400 275.33, onboard audio, XP SP3
Overclocked.
1. 221.4 FPS, Skyscraper, A64 X2 6000+ @3.5 14x250, Asus M2N-SLI Deluxe nForce570, 2x1GB DDR2 1000 4-4-4-12, 7900GTX 720/1800, 92.91, X-Fi, XP SP3
2. 214.5 FPS, agent_x007, Pentium D 965@5,1, Rampage Extreme, 16GB DDR3-1133 CL5.6.5.15 1T, GF7900GX2 @600/1400 92.91, X-Fi Fatal1ty XG, XP-SP3
3. 201.1 FPS, candle_86, Athlon 64 X2 6000 14x230MHZ @ 3220MHZ, 8gb DDR 800 @ 920, GF 7900GTX SLI @ 650/1630, XP Pro SP3, Sound Blaster Audigy
4. 198.0 FPS, agent_x007 Pentium D 965 @ 5,02GHz, ASUS P5K64 WS, 4gb DDR3 1673MHz, GF 7900 GX2 SLI @600/702 307.83, XP Pro SP3, Onboard Audio
X. 154.8 FPS, agent_x007, Pentium D 965@5007 MHz, Asus P5K64 WS P35, 2x2GB DDR3 1624MHz CL 6-8-6, Geforce 7900GTX 92.91, onboard audio, XP-SP3.
X. 153.0 FPS, agent_x007,Pentium XE 840@4,27GHz, ASUS P5K64 WS, 8GB 1069MHz DDR3 5-5-4-12 1T, 7800GTX 512MB 307.83, SB X-Fi Elite Pro, XP-SP3
5. 151.3 FPS, Skyscraper, (v1.3) Pentium D 965@4600, Gigabyte X48 DS4, 2GB DDR2 1152MHz CL4-5-4-14, Geforce 7900GTX 92.91, onboard audio, XP-SP3.
6. 143.4 FPS, Skyscraper, (v1.3) AMD64 FX60@3.0GHz, Asus A8N32-SLI Nforce4, 2GB DDR500 CL2.5-3-3-5, Geforce 7900GTX 92.91, onboard audio, XP-SP3.
X. 142.2 FPS, Skyscraper, (v1.3) Pentium D 950 @4533, Gigabyte X48 DS4, 2GB 1066 MHz DDR2 CL4-4-4-13, Geforce 7900GTX 92.91, onboard audio, XP-SP3.
7. 130.9 FPS, Imperious, Pentium M@2735MHz, Nvidia 7800GS@526-1591 93.71, 2048MB DDR456@2,3,2,5 Asus P4P800dlx, Onboard Audio, XP-SP3
X. 127.5 FPS Skyscraper, (v1.3) Pentium D 950 @4533, Gigabyte X48 DS4, 2GB 1066 MHz DDR2 CL4-4-4-13, Geforce 7900GTX 307.83, onboard audio, XP-SP3.
8. 121.5 FPS, Standard Def Steve, A64 3700+@ 2.75GHz, X1950 Pro AGP Cat 10.4, 2GB@500/CL2.5, Gigabyte K8NSC-939 NF3 250Gb, onboard audio, W7 x86
9. 121.1 FPS, agent_x007, Pentium D 965EE @4.9, Asus P5K 64 WS (P35), 2x2GB DDR3 817 CL6-7-6-18 1T, GF 7800 GTX 512 92.91, onboard audio?, XP-SP3
X. 120.7 FPS, Skyscraper, (v1.3) AMD64 FX55@3.0, Asus A8N32-SLI Nforce4, 2GB DDR500 CL2.5-3-3-5, Geforce 7900GTX 92.91, onboard audio, XP-sp3
10. 108.9 FPS, kanecvr, Pentium D 945 @3.74, Zotac nForce 780i SLi, 2GB DDR2 1066MHz CL5, 2x Geforce 7950 512Mb SLI 175.16, onboard audio, XP-SP3
X. 103.5 FPS, Standard Def Steve, A64 3700+@ 2.75GHz, X1950 Pro AGP Cat 10.4, 2GB@500/CL2.5, Gigabyte K8NSC-939 NF3 250Gb, onboard audio, W7 x86
11. 60.8 FPS, Nahkri, Socekt 939 Athlon 64 3200+@2,3 ghz,2g ram,7600gs 512mb ram,Windows XP-SP3.
12. 39.3 FPS, havli, P4 Willamette 1.6 @ 1.92 GHz + Asus P4P800 Delux. + 2x 512 MB DDR 320 CL2-2-2-5 + Geforce 7800GS @500/1400 275.33, XP-SP3
Anything goes toplist.
1. 651.7 FPS, Standard Def Steve, Core i7 4930K@4.6GHz, Asus GTX 680 340.52, 32GB DDR3-2400 CL10, Asus Rampage IV Gene x79, onboard audio, XP-SP3
2. 644.5 FPS, Skyscraper, i7 2600K@5.2 GHz, Gigabyte G1 Sniper 2 Z68, 8GB DDR3 2133 CL9-10-10-27, Geforce GTX 580 OC 296.10, onboard audio, XP-SP3.
3. 611.8 FPS, agent_x007, i7 3820@5,03, ASUS Sabertooth X79 - 8GB 2012MHz DDR3 8-9-8-24-1T,GTX780Ti @1020 365.19, ASUS Essence ST Deluxe, XP-SP3
X. 568.5 FPS, Standard Def Steve,i7-4930K@4.5, 32GB DDR3-2133 9-11-11-1T, Asus Rampage IV Gene, 8800GTS 640MB SLI 341.44, onboard audio, Win7-64
4. 503.3 FPS, Elianda, i7 3930K@4.3 GHz, Gainward GTX 780 GLH Phantom OC, 32GB DDR3 1600-10-10-10-30, Gigabyte X79-UD5, Realtek HDA, 7 Pro SP1
5. 499.9 FPS, tincup, i5 8400, Asrock H370 Pro4 mATX, 16gb DDR4 2400, 6gb GTX 1060 SC (little guy with 1 fan), Onboard audio, Win10 x64
6. 486.1 FPS, Shagittarius, i7 4770K@4.4Ghz, EVGA GTX 690, 16GB DDR3 2133-10-11-11-31, ASUS Z87 Deluxe, Soundblaster Z, Win 8.1
7. 452.7 FPS, Standard Def Steves friend, i7-6700 @ 4.0GHz Turbo, HP Z170 motherboard, GTX 980Ti 368.22, 16GB DDR4-2133, onboard audio, Win10 x64
8. 452.1 FPS, Skyscraper, Core 2 Duo E8600@4800, Asus P5E3 X38, 2x2 GB DDR3 1536 CL7-7-7-16, GTX 580 @900 296.10, Onboard audio, XP-SP3
9. 443.0 FPS, Skyscraper, Core 2 Duo E8400@4700, Gigabyte EP35C-DS3R, 2x2GB DDR3 1568 CL7-8-7-20, GTX 580 296.10, Onboard audio, XP-SP3
10. 429.1 FPS, candle_86, AMd Ryzen 1600 @3.925, Gigabyte B350 Gaming, 16gb DDR4 3200, GTX 1060 6gb Driver 397.64, Onboard Audio, Win10 x64
11. 395.4 FPS, DosFreak, i7 930@4011MHz, Gigabyte X58A-UD3R, 16GB DDR3 1531 CL8-8-8-21, EVGA GTX 980ti 355.60, Sound Blaster ZxR, 10 Pro x64
X. 370.1 FPS, Skyscraper, Dumpsterfind Q6700@4050, Asus P5E3 X38, 2x2GB DDR3 1440 CL6-7-6-15, GTX580 296.10, Onboard audio, XP-SP3
X. 359,1 FPS, agent_x007, i7 3820@5,03, ASUS Sabertooth X79, 8GB 2012MHz DDR3 8-9-8-24-1T,7950 GX2 600/1404 307.83 , ASUS Essence ST DL, XP-SP3
12. 358.9 FPS, Standard Def Steve, Core 2 Quad Q6700 @ 4GHz/1600FSB, GTX 680 (331.65), 8GB DDR3-1600 CL9, Asus P5Q3 (iP45), onboard audio, XP-SP3
13. 351.6 FPS, Standard Def Steve, Phenom II X6 1090T @4070MHz, GTX680, 16GB DDR3-1760 CL9, Asus Crosshair IV Formula 890FX, onboard audio, W7-64
14. 344.4 FPS, candle_86, Core i7 4770, MSI PC-Mate H97, 16GB Samsung DDR3 1600 9-9-9-24, EVGA GTX 960 SC 358.91, Onboard Audio, Windows 10 Pro
15. 340.3 FPS, Skyscraper, Core2Duo X6800 @4.0, Asus P5B Deluxe P965, 2GB DDR2-1000 CL4,4,4,12 2T, 8800 GTX 675/1107 197.45, X-Fi XtremeMusic XP-SP3
16. 304.8 FPS, agent_x007, QX9770 3,2GHz @ 3.84GHz, 4CoreDual-SATA2 R2.0, 4GB DDR2-682 CL5.5.4.12,GTX580 850/4400 368.81,Audigy 2 ZS, XP-SP3
X. 301.0 FPS, Skyscraper, Core2Duo X6800 @3.6, Asus P5B Deluxe P965, 2GB DDR2-1000 CL4,4,4,12 2T, 7950 GX2 600/800 197.45, X-Fi XtremeMusic XP-SP3
X*. 294.6 FPS, philscomputerlab, Core i7 3770, 8 GB DDR3, GTX660, Sound Blaster Z and Windows 8.1. *Missing motherboard information.
17. 292.4 FPs, MrEWhite, i7 7700k @ 4.5 GHz, Asus ROG Maximus IX, 2x8GB DDR4 Corsair Dominator @ 3000 MHz, GTX 1080, Win10 x64.
18. 281.3 FPS, Skyscraper, s771 Xeon X5460 3166@4400, XFX nForce 780i, 2GB DDR2 926 CL4,4,4,12, Geforce GTX 580 1.5GB 296.10, Onboard audio, XP Pro SP3
19. 278.3 FPS, DosFreak, i7 5700HQ@3.5GHz, MSI GT72 1666, 32GB DDR3-1600 CL8-8-8-24, Nvidia 980m 355.60, Realtek, 10x64
20. 277.4 FPS, Skyscraper, Q9650 3000@4200 MHz, Asus Commando P965, 2GB DDR2 934 CL4-4-4-12, Geforce 8800 GTX 186.18, Onboard audio, XP Pro SP3
X. 275.6 FPS, Skyscraper, s771 Xeon X5460 3166@4400, XFX nForce 780i, 2GB DDR2 926 CL4,4,4,12, Geforce GTX 285 186.18, Onboard audio, XP Pro SP3
21. 269.4 FPS, tincup, AMD FX-8350 @ 4.8ghz, ASUS Crosshair V Formula, ASUS HD 7870 2gb @ 1100/1450mhz, 8gb DDR3 2133 CL9, Onboard audio, Win 7
22. 268.5 FPS, Standard Def Steve, Phenom II X6 1055T@3.1GHz, GF GTX760 361.43, 8GB DDR3-1600 CL9, Asus Crosshair IV Formula 890FX, X-Fi Ti, Win7-64
23. 265.4 FPS, Standard Def Steve, Core 2 Quad Q6700 @3.33GHz/1333, GTX 560 341.44, 8GB DDR2-667 4,4,4,12, Asus P5N-E SLI nForce 650i, X-Fi Ti, 7-64.
X. 261.7 FPS, Standard Def Steve, Core 2 Duo E6600 @ 3GHz/1333FSB, GTX 560 (353.06), 8GB DDR3-1333 CL7, Asus P5Q3 (P45), onboard audio, Win7 x64
X. 257.4 FPS, Skyscraper, QX6850 3000@4000 MHz, Asus Commando P965, 2GB DDR2 1000 CL4-4-4-12, Geforce 8800 GTX 186.18, Onboard audio, XP Pro SP3
24. 256.2 FPS, JayCeeBee64, Core i5-3350p 3.1GHz, MSI Z77A-G43, 8gb DDR3-1600, GF GT640 2gb 310.90, ASUS Xonar DG, DX 11, Win 7 Ultimate SP1 64-bit
25. 245.9 FPS, Standard Def Steve, Mobile C2D T5600 ES @2.93, 4GB DDR2-887 4-4-4-12, GTX560 353.06, AOpen i975xa-YDG i975x, onboard audio, Win7 x64
26. 242.4 FPS, boxpressed, AMD Phenom II x4 940 3.0, a motherboard, probably DDR2 800 5,5,5,15, Geforce 9800GT 512MB 332.21, onboard audio?, XP-SP3
27. 241.2 FPS, candle_86, FX6300 @ 4.5ghz, some motherboard, 8gb DDR3 1866, Geforce GTX660 SuperClocked, Perhaps onboard sound?, Windows 8.1 Pro
X. 238.4 FPS, agent_x007, QX9770 3,2GHz @ 3,84GHz, 4CoreDual-SATA2 R2.0, 4GB DDR2-682 CL5.5.4.12, HD3850 AGP @715/1818 10.2, Audigy 2 ZS, XP-SP3.
28. 233.6 FPS, SPBHM, i5 2310 ( Sandy Bridge dual core HT 2.9-3.2 GHz), Pegatron IPMSB-H61, 8GB DDR3 1333, HD 5850 11.12, onboard ALC662, Win XP sp3
X. 232.5 FPS, agent_x007, QX9770 3840/1024MHz, 4CoreDual-SATA2 R2.0 VIA PT880 Pro, GTS450 1GB 368.81, 4GB DDR2-682 5-5-4-12, Audigy 2 ZS, XP SP3
X. 228.5 FPS, Standard Def Steve, C2D E6600 @ 3.0GHz/1333FSB, GeForce GTX 560 (275.33), 8GB DDR2-800 5-5-5, Asus P5N-E SLI (nForce 650i), X-Fi Ti, XP
29. 228.1 FPS, agent_x007, Pentium D 965 @ 5,02GHz - ASUS P5K64 WS - 4gb DDR3 1673MHz - GTX780 TI @1097/7300, 365.19, Onboard Audio, XP Pro SP3
X. 225.4 FPS, Standard Def Steve, "Yonah" T2600@3.08GHz 948FSB, 4GB DDR2-800 4-4-4-12, GF GTX 560 340.52, AOpen i975xa-YDG, onboard audio, XP-SP3
30. 221.6 FPS, Standard Def Steve, HP Envy 17, i7-720QM 1.6+GHZ w/Turbo, 8GB DDR3-1333 9-9-9-24-1T, Mobility Radeon HD5850, onboard audio, Win7 x64
31. 220.4 FPS, agent_x007, Pentium D 915@5,15GHz, Rampage Extreme, 16GB DDR3-1177 CL5.6.5.15 1T, GTX780 Ti 368.81, X-Fi Fatal1ty XGamer, XP Pro SP3
32. 220.4 FPS, agent_x007, Core i7 980X @ 4297MHz, Asus Rampage II Extreme, 7900GTX 650/1700, 12GB DDR3-1953 CL9-10-9-24, Aureal Vortex 2, Win 98SE.
33. 213.7 FPS, Standard Def Steve, C2D E7600 3.06/1066, 4CoreDual-SATA2 PT880Pro, 8800GTS 640MB 275.33, 2GB DDR2-533 3-3-3-9, onboard audio, XP-SP3
34. 212.4 FPS, clueless1, Xeon 3070@2664 MHz, Intel D946GZIS, 4GB DDR2 400 @333 CL5-5-5-15 1T, Geforce 8800GTX 340.52, Turtle Beach Santa Cruz, XP-SP3
X. 206.7 FPS, agent_x007, Core 2 Extreme X6800@3,2, ASRock 4CoreDual-SATA2 R2, 4GB 533MHz DDR2 4-4-3-9 2T, 7900GX2 307.83, SB X-Fi Elite Pro, XP-SP3
35. 201.0 FPS, Skyscraper, The 2006 build, QX6700@3.46 GHz, Asus Striker Nforce 680i SLI, 4GB DDR2 800 5,5,5,15, 8800GTX 331.82, Onboard audio, Vista x86
X. 199.6 FPs, Standard Def Steve, C2D E6600 2.4GHz/1066, 4CoreDual-SATA2 (VIA PT880 Pro) 2GB DDR2-533 3-3-3-9, 9800GT 275.33, onboard audio, XP SP3
36. 192.4 FPS, Standard Def Steve, 939 Opteron 185 2.6@3.13GHz, 4GB DDR400 CL2, GTX260 rev-B OC 182.06, Asus A8N32-SLI Deluxe, X-Fi Ti Fatality, XP-SP3
37. 176.0 FPS, tincup, C2D E6700 2.66, BioStar P4M890-M7-TE socket 775, EVGA 7900GTX 92.91, 2gb DDR2 533 CL4-3-4-12 single-channel, SBLive!, XP Pro SP3
38. 175.2 FPS, Imperious, Intel I5-750 4017mhz, Asus P7P55D-E Pro, 12Gig DDR3@1912 CL9-11-10-28,Quadro FX3500@502-1404 162.65, Onboard audio, XP-SP3.
X. 174.3 FPS, Standard Def Steve, Opteron 185 2.6GHz@3.0GHz, Geforce 8800GTS 640MB SLI, 4GB DDR400, Asus A8N32-SLI, X-Fi Titanium Fatality, XP Pro SP3
X. 172.7 FPS, Standard Def Steve, Pentium E2220 @ 3.2GHz/1066FSB 1MB L2, GTX 560 275.33, 8GB DDR2-800 5-5-5, Asus P5N-E SLI nForce 650i, X-Fi Ti, XP-SP3
X. 172.1 FPS, Standard Def Steve, Opteron 185@3.13GHz, GeForce GTX 560 341.44, 4GB DDR400 CL2, Asus A8N32-SLI Deluxe, X-Fi Titanium Fatality, Win7 x64
39. 168.6 FPS, tincup, ECS P4M890T-M V2, C2D/E6700, 2gb PC4300/533 [single channel], 7900GTX/v92.91, XPpro/SP3
X. 165.1 FPS, agent_x007, Pentium XE 840 @ 4,27GHz - ASUS P5K64 WS - 8GB 1069MHz DDR3 5-5-4-12 CR1T - GTX 780 Ti - 365.19, SB X-Fi Elite Pro, XP-SP3
40. 162.4 FPS, Skyscraper, Athlon X2 6000+@3450, Asus M2N-SLI Deluxe Nforce 570, 2Gb DDR2 862 4-4-4-12, GF GTX 285. 186.18, onboard audio, XP SP3.
41. 161.7 FPS, Skyscraper, 2006 FSC Scaleo E Media Center, E6700 2.66Ghz, FIC PTGB965EFN-LF, 4GB DDR2, G92 600/800 186.18, low profile Audigy, XP-SP3
42. 160.0 FPS, kanecvr, Wolfdale 2M E6600 3.06, Zotac nForce 780i SLi, 2GB DDR2 1066MHz CL5, 2x Geforce 7950 512Mb SLI 175.16, onboard audio, XP-SP3
43. 157.9 FPS, Skyscraper, Pentium D 950 @ 4800 MHz, Gigabyte X48 DS4, 2GB 1200 MHz DDR2 CL4-5-4-14, Geforce GTX285 186.18, onboard audio, XP-SP3.
X. 156.7 FPS, Standard Def Steve, Opteron 185@3.0GHz, GeForce GTX 560 341.44, 4GB DDR400 CL2, Asus A8N32-SLI Deluxe, X-Fi Titanium Fatality, Win7 x64
44. 156.6 FPS, Standard Def Steve, C2D E6600 2.4GHz, Radeon X1950 Pro AGP (Cat 10.4), 2GB PC3200 @356/CL2, Asrock 775i65G i865, onboard audio, XP-SP3
45. 149.9 FPS, rick6, i5 5200U, 8GB of ram, 256 GB SSD + 500GB HDD, Geforce 940m probably newest drivers, onboard audio, Win-10.
46. 145.3 FPS, Standard Def Steve, Pentium M 755 2.0@2.72GHz, 544MHz FSB, 2GB DDR2-544 CL3, GeForce GTX 560 (275.33), i915, X-Fi Titanium, WinXP SP3
X. 144.2 FPS, Standard Def Steve, Pentium M 755@2.70 540FSB, 2GB DDR2 533 CL3, GTX260 rev-B OC 182.06, MSI Speedster FA4 i915, onboard audio, XP SP3
47. 139.1, HeavyD8086, E6700 (Conroe 4M 2.66), Dell Optiplex 745 (Q965), 2x2GB DDR2 800 6-6-6-18, Radeon X1800 6.12, onboard audio, XP-SP3
X. 135.9 FPS, Standard Def Steve, Pentium D 935 @3.2 GHz 800FSB 4MB L2, GTX 560 275.33, 8GB DDR2-800 5-5-5, Asus P5N-E SLI nForce 650i, X-Fi Ti, XP SP3
X. 132.1 FPS, Standard Def Steve, C2D E6600 2.4GHz/1066, 4CoreDual-SATA2 (VIA PT880 Pro) 2GB DDR2-533 3-3-3-9, X1950 Pro 10.2, onboard audio, XP SP3
X. 127.3 FPS Standard Def Steve, Mobile C2D T5600 ES @1.83GHz, 4GB DDR2-667 3-3-3-8, 9800GT 341.44, AOpen i975xa-YDG i975x, onboard audio, Win7 x64
48. 127.1 FPS, Standard Def Steve, i7-4790, Lenovo Q87 motherboard, HD4600 graphics, 16GB dual-channel DDR3-1600 11-11-11-28, onboard audio, Win7 x64
X. 126.7 FPS, agent_x007, P4 651 @5,25GHz, Rampage Extreme, 16GB DDR3-1226 CL6.7.6.18 1T, GTX 780 Ti 368.81, X-Fi Fatal1ty XtremeGamer, XP Pro SP3
X. 124.9 FPS, Standard Def Steve, S939 Athlon X2 3800 2.0GHz, GeForce GTX 560 331.65, 4GB DDR400 CL2, Asus A8N32-SLI Deluxe, X-Fi Ti Fatality, XP Pro SP3
X. 122.4 FPS, Standard Def Steve, C2D E6600@3.0, Asus P5N-E SLI nForce 650i, 2x2GB DDR2 667CL4 ,Geforce 8600GT 512MB GDDR3, onboard audio, Win7 x86
X. 120.4 FPS, agent_x007, QX9770 @3,84GHz, 4CoreDual-SATA2 R2.0, 4GB DDR2-682 CL5.5.4.12, GF 6800 Ultra 256MB 440/1150 93.71, Audigy 2 ZS, XP-SP3
X. 120.4 FPS, Standard Def Steve, Pentium D 830 @ 3GHz/800FSB, GeForce GTX 560 (341.44), 8GB DDR2-800 5-5-5, Asus P5N-E SLI nForce 650i, X-Fi Ti, XP SP3
X. 114.4 FPS, Imperious, Intel I5-750 4017mhz, Asus P7P55D-E Pro, 12Gig DDR3@1912 CL9-11-10-28,Quadro FX3450@450-1053 81.98, Onboard audio, XP SP3.
49. 110.7 FPS, SPBHM, Xeon E5420@2.8GHz Quad Core 12MB, Asrock G31M-VS2, 2GB DDR2@750 c5, HD4670 DDR2 8.970.100.9001, onboard VT1705, Win10 x86
50. 104.6 FPS, buckeye, E8400 3GHz, Foxconn Q45M (Q45), 2x1GB DDR2 800 5-5-5-18 2T, Geforce 7950GT 295.73, onboard audio?, XP-SP3.
X. 104.6 FPS, Standard Def Steve, Q6700@3.33GHz/1333FSB, 6800GS PCI-E 309.08, 8GB DDR2-667 4-4-4-12-1T, Asus P5N-E SLI (nForce 650i), X-Fi Ti, Win7 64
51. 104.5 FPS, AlphaWing, S939 A64 X2 3800+@240FSB 2.4GHZ, Abit KN8 ULTRA NF4, 4gb DDR400-3-2-2-1T-DC, GF GTX 550TI-1GB 337.88, Audigy PCI, XP-SP3
X. 104.5 FPS, tincup, Core2Duo 2.2, BioStar P4M890-M7-TE/socket 775, EVGA 7900GTX [92.91], 2gb DDR2/pc4300, SBLive!, XP Pro SP3
X. 101.4 FPS, Standard Def Steve, C2D E6600 2.4GHz/1066, 4CoreDual-SATA2 (VIA PT880 Pro) 2GB DDR2-533 3-3-3-9, 6800GT 275.33. onboard audio, XP SP3
52. 96.3 FPS, Standard Def Steve, P4 520@3.73GHz, 1066 FSB, 2GB DDR2667 CL4, Asus P5ND2-SLI Deluxe NF4 SLI IE, GTX260 182.06, onboard audio, XP-SP3
53. 89.1fps, lazibayer, A10-7860k @ 3.6GHz, ASRock FM2A78M-ITX+, 2x8GB DDR3-2400 @ 10-12-12-31, integrated GPU, integrated audio, Server 2012 R2.
54. 83.5 FPS, NamelessPlayer, Core i5-3320M, Fujitsu T902 (laptop), 2x8GB DDR3 1600 CL9, Intel HD 4000, onboard audio, Windows 10.
55. 65.0 FPS, rick6, Athlon 64 3200+ S754. A motherboard with SiS 755 or 760, 2x512MB DDR400, Radeon HD3850 AGP 14.4, probably onboard sound, XP SP3.
56. 61.4 FPS, havli, Sempron 2650 1450 MHz (Jaguar, Kabini), Asus AM1I-A +, 2GB DDR3 1600 CL9-9-9-24, Radeon R3 series 128 shader cores 400 MHz.
57. 54.9 FPS, SPBHM, Broadwell i3-5005U 2GHz, single channel DDR3 1600, Intel® HD Graphics 5500 driver 10.18.14.4062 WHQL, onboard audio, Win 8.1 -64
58. 43.5 FPS, Skyscraper, P4 550 3.4 GHz. 2GB DDR2-533 CL4. "Asus" (HP) PTGD-LA i915. HD2600Pro 512MB DDR2 13.9. onboard audio, Vista Ultimate x86 32bit.
59. 41.8 FPS, SPBHM, Core2Quad Q9500\Q9550, A motherboard, Unknown amount of unknown memory, Geforce 8400GS G98 PCI, Probably onboard audio, Win-7
60. 40.7 FPS, Standard Def Steve,Atom X7 Z8700 "Cherry Trail" 1.6GHz (2.4 Turbo), Intel HD IGP, 4GB dual channel DDR3-1600, onboard audio, Win10 64
61. 36.5 FPS, SPBHM, Pentium 4 2.4B @ 3GHz, Asus P4PE 845PE, 768MB DDR333 CL2.5, Geforce 8400GS G98 512MB PCI Forceware 257, onboard AD1980, XP-SP2.
62. 35.7 FPS, (High Quality), NamelessPlayer, Fujitsu T901's, Core i5-2520M, 6GB DDR3 1333 MHz, Intel HD 3000, Windows 7 SP1 64-bit
63. 26.0 FPS, Standard Def Steve, Core 2 Duo e7500 2.93GHz, 1066FSB, 3MB L2, Intel GMA X4500HD, 4GB DDR3-1066 CL7, onboard audio, XP SP3
64. 25.0 FPS, Standard Def Steve, iMac T2500 @ 2GHz/667FSB, Mobile Radeon X1600 128MB 128bit GDDR3 10.2, 2GB DDR2-667 CL5, onboard audio, Win7 x86
X. 24.2 FPS, Standard Def Steve, Core 2 Duo e7500 2.93GHz, 1066FSB, 3MB L2, Intel GMA X4500HD, 4GB DDR3-1066 CL7, onboard audio, Windows 7 x64 SP1
65. 19,9 FPS, SPBHM, Pentium 3 650@866, Asus CUBX-E, 512MB PC133 C3, Geforce 8400GS G98 340.52, AWE64, Win XP-SP3
66. 14.5 FPS, SPBHM, Sempron 145 @3.50, Asrock AliveNF6G-DVI, 4GB DDR2 836 CL6,6,6,15 2T, 6100/6150SE @ 593MHz 304.79, onboard audio?, XP SP3
67. 8.3 FPS, SPBHM, Core2Duo E7600 @3.06, Gigabyte 945GCM-S2C, 4GB DDR2 667 CL5,5,5,15 2T, GMA 950, onboard audio, XP SP3
68. 3.7 FPS, Standard Def Steve, Atom N470 (1.83GHz/512K L2), Intel GMA3150 (800*600), 2GB DDR2-667, onboard audio, Win7 SP1
Main PC: Dual Xeon X5690@4.6ghz, Evga - SR-2, 48gb memory, Intel X25-M g2 SSD and a Nvidia GTX 980 ti.
Retro PC #3: K6-2 450@500mhz, PC-Chips m577, 256mb sdram, AWE64 and a Voodoo Banshee.
Skyscraper
Re: Doom 3 timedemo FX5800
Postby AlphaWing » 2014-9-26 @ 17:47
Doom 3 - Amd Xp 3000+ Nf2 1GB DDR 400 DC, Geforce FX 5800 128mb SBLIVE! sound enabled timedemo demo1 1
Default Medium Quality Settings.
640x480 = 54.2fps
800x600 = 52.1fps
1024x768= 43.0fps
1152x864= 37.3
1280x1024= 29.9fps
Ultra Quality
640x480=51.3
800x600=47.9
1024x768=38.7
1152x864=33.2
1280x1024=26.5
This is what I got with retail copy\last patch in a different thread with this particular machine.
I'll test it later on my socket 939 amd and socket 775 P4. Geforce 550 ti, Geforce 6600GT
User avatar
AlphaWing
Re: Doom 3 timedemo shootout with period correct hardware.
Postby Skyscraper » 2014-9-26 @ 17:52
Great, lets use the 1024*768 Ultra Quality settings for the list in case someone uses a CRT that cant handle greater resolution.
I have a i875p system that is period correct but I think I will build something with an i915 or i925X board and a PCI-E Geforce 6800GT.
edit fixed typo
Skyscraper
Postby Mau1wurf1977 » 2014-9-26 @ 23:38
Sounds like fun :)
Fir Nvidia cards, what driver would you recommend? Are there any issues with newer drivers? Also what Sound card? X-Fi too new? Audigy 2?
User avatar
Mau1wurf1977
Postby Standard Def Steve » 2014-9-27 @ 00:53
My Tualatin beast didn't do half bad. :lol:
PIII-S 1400@1585, 151MHz FSB, 1.5GB SDRAM, Radeon 9800Pro (Catalyst 7.3), WinXP Pro SP3, VIA 694T, X-Fi Extreme Music
1024x768, Ultra: 33.1 fps
1024x768, High: 38.4 fps
640x480, Medium: 41.0 fps
Standard Def Steve
Dualcore P4 3200mhz-775 Geforce 6600GT
Postby AlphaWing » 2014-9-27 @ 02:03
Pentium D 935 3.2ghz-775, Asus-P5DVC-MX-ViaP4M800, 2GB DDR2 PC5300,266mhz-5-5-5, AGP BFG Geforce 6600 GT 128mb-175.14 forceware, SBLIVE! XP-SP3
Medium Quality
640x480 =76.3
1024x768=74.8
Ultra Quality
640x480=71.6
1024x768=68.8
User avatar
AlphaWing
Postby JayCeeBee64 » 2014-9-27 @ 02:34
Looks like I'll be bringing up the rear. I like that :lol:
Pentium 4 2.4GHz Northwood, Soyo P4I-845PE (Socket 478), 512mb DDR-333, NVIDIA GeForce 4 Ti 4200 128mb AGP (45.23 Win9x drivers), Turtle Beach Santa Cruz, DirectX 8.1b, Windows 98SE.
Medium Quality:
640x480=29.4
800x600=22.5
1024x768=15.1
Ultra Quality:
640x480=16.3
800x600=12.5
1024x768=8.6
I also have an Nvidia FX5500 and 6600 (both 256mb AGP cards). Will test both as soon as I have the time.
Ooohh, the pain......
User avatar
JayCeeBee64
Postby Standard Def Steve » 2014-9-27 @ 06:00
Pentium M (Dothan) 755 2.0GHz @ 2.66GHz, 533MHz FSB, GeForce 6800GT (Forceware 307.83), 2GB DDR2-533, MSI Speedster i915, onboard audio, XP Pro SP3
640x480, Medium: 133.6 fps
1024x768, Ultra: 104.2 fps
1280x1024, Ultra: 80.4 fps
Standard Def Steve
Postby Mau1wurf1977 » 2014-9-27 @ 06:08
Just installing XP SP2 on my Socket 478 reference platform with a 3.2 GHz Northwood, 6600GT AGP and Sound Blaster Audigy 2 ZS.
User avatar
Mau1wurf1977
Postby Mau1wurf1977 » 2014-9-27 @ 07:35
This doesn't work for me :depressed:
Are you sure this works in the demo? Demos often do not have the timedemo demos included.
Following the instructions nothing happens and in the console is this error:
WARNING: Couldn't load gui: 'guis/map/loading.gui'
couldn't open demos/demo1.demo
Game Map shutdown
User avatar
Mau1wurf1977
Postby Skyscraper » 2014-9-27 @ 08:25
Mau1wurf1977 wrote:This doesn't work for me :depressed:
Game Map shutdown
I will look into this later today when I have built my Doom 3 system.
If the timedemo is missing perhaps someone can upload it.
Skyscraper
Postby Mau1wurf1977 » 2014-9-27 @ 08:34
Skyscraper wrote:I will look into this later today when I have built my Doom 3 system.
LOL Have you actually tested this before starting this thread?
User avatar
Mau1wurf1977
Postby Skyscraper » 2014-9-27 @ 08:42
I have not even loaded up Doom 3 since I bought it a long time ago. I was a bit buisy with World of Warcraft at the time so I did not play through it.
But it seems a bit retarded to me if the demo do not include the timedemo as it is the best way for people to see if their hardware can run the game before buying it.
But its good to see the scores of some already finished systems so I know what to build ;). Standard Def Steves Dothan is a killer, too bad I do not own a s479 board or an adapter.
Skyscraper
Postby Mau1wurf1977 » 2014-9-27 @ 08:46
Just know that you wasted a lot of my time mucking around with this :angry:
If you start a thread inviting people to benchmark, linking a demo, then PLEASE test it beforehand.
User avatar
Mau1wurf1977
Postby Skyscraper » 2014-9-27 @ 08:52
Mau1wurf1977 wrote:Just know that you wasted a lot of my time mucking around with this :angry:
You shoud try to see the positive side of things.
Now you have a perfect Doom 3 system, perhaps worth buying Doom 3.
But yea perhaps I was a bit too sure that it would work as I saw the demo link posted in another Doom3 timedemo thread posted on another forum.
I will try to see if I can get the timedemo running in the demo later today.
EDIT reading around a bit on the net I can at least see that you are not the only one with this problem.
In many threads some do not get it to run, I do not even know if its possible, perhaps all the others have the full version although the demo link is almost always included.
I will update the first post to reflect this until I find a fix.
Skyscraper
Postby DosFreak » 2014-9-27 @ 09:14
I know the alpha had it...but I guess not the demo.
http://www.murc.ws/showthread.php?37369 ... n-the-G400
Doesn't everyone have the full game anyway?
Need to see if putting the timedemo in the demo works.
User avatar
DosFreak
Postby Skyscraper » 2014-9-27 @ 11:11
I am having a bad morning.
I found my Abit AA8 925X motherboard and a period correct Prescott 530 but when i removed the CPU already mounted in the board the CPU got pulled up with the mounting mechanism and then fell back down in the socket :angry: . The result was two damaged pins and of course the damn board would not post. Lucky enough i managed to get the pins a little less bent and now the board posts fine but my intention was to try diffrent Prescott 5xx until I found a nice one that could run at >4GHz at default voltage. Now I do not really know if I dare to switch CPU again.
Skyscraper
Postby NamelessPlayer » 2014-9-27 @ 12:58
This oughtta be fun, considering my main retrogaming build's based around top-of-the-line-for-2004 hardware, mostly by coincidence.
-Pentium 4 Extreme Edition 3.2 GHz (Gallatin core, let's see if that extra L3 cache pays off!)
-2 GB DDR-400, dual-channel
-GeForce 6800 Ultra AGP
-Auzentech X-Fi Prelude (relevant because Doom 3 uses OpenAL and EAX, so maybe the X-Fi hardware acceleration might offer a boost, and while the Prelude's NOT a period-appropriate variant, the X-Fi CA20K1 DSP itself most certainly is)
I've also got another box in storage that's not too far behind and could be representative of a high-end system just the year before. Needs better RAM, though.
-Athlon XP 3200+
-1 GB DDR-333, dual-channel (I tried overclocking it to DDR-400, but it just won't stay stable!)
-GeForce FX 5950 Ultra (Since it's Doom 3 and not Half-Life 2, it might not totally suck at this!)
-integrated NVIDIA SoundStorm chipset (Let's see if NVIDIA has a decent OpenAL implementation...)
Time for a little Gallant Gallatin vs. nVidiXPerience benchmark showdown!...once the latter has a hard drive to call its own again, anyway.
Will it matter all that much if I use the Steam release of Doom 3 for benchmarking?
User avatar
NamelessPlayer
Postby Mau1wurf1977 » 2014-9-27 @ 13:07
NamelessPlayer wrote:Will it matter all that much if I use the Steam release of Doom 3 for benchmarking?
I don't think so.
I hear that Steam doesn't work on old machines anymore. Anyone tried that / knows more?
Doom 3 isn't on GOG.com so I'm stuck.
User avatar
Mau1wurf1977
Postby DosFreak » 2014-9-27 @ 13:10
Steam dropped Windows 2000 support awhile back.
I believe it may still work with the API wrappers but I just make sure that the games I buy from there I have cracks for.
So as long as you are running XP on your 2004 machine then you should be good. SP2 even came out in Aug 2004 which is when us 2000 holdouts finally felt like we could "upgrade" to XP.
As far as SSE2 I don't know if Steam requires that nowadays (I know it didn't before) if so then the Athlon XP has no support for that.
User avatar
DosFreak
Next
Return to Video
Who is online
