First post, by Darkman
So my Voodoo2 card (Techworks branded, 12mb) seems to have suddenly stopped working properly, whenever Im running a game, all of the textures develop odd patterns. This happens with every game running on the Voodoo2 (running them on the host VGA card doesn't cause issues, and the 2D picture on the desktop is also ok)
Here is an example from Quake 2 (you will have to excuse the text box, but I think its good enough to get an idea)
Ive tried different PCI slots and even computers, and its the same. The odd thing is, it was working a few hours earlier.
anyone know what the problem is , or what can be done to fix it?
thank you.
Reply 1 of 13, by spiroyster
Whoa.. cool MOD! Which pin do I have to poke with a screw driver to get that effect 😀
On a more serious note, I have no idea 🙁 my monies would be on some memory being slightly defective? Does it happen to all textures? In which case maybe a more fundamental problem with some sort of processing going on there. I have no idea how the Voodoo organises it memory under the hood but that might give you an indication if its an isolated issue or not.
Reply 2 of 13, by Darkman
it happens to just about all of the textures, and even text as you can see in the picture.
It doesn't crash or freeze so I don't think its a heat issue (even more so since the cases are open)
Reply 3 of 13, by Emu10k1
if you are not getting weird polygons and shapes out of nowhere and its only not loading textures properly, its probably faulty memory. I had a Riva tnt with the same problems and it was solved replacing the memory chips (Not the same card, but still...).
Try with other display resolutions to see if the pattern changes.
Reply 4 of 13, by Darkman
different resolutions seem to make no impact from what Ive tried
Reply 5 of 13, by spiroyster
Yes everything you see with dots/corrupted patterns in your screenshot is a texture (including the text). Does it develop over time or is there from the start? If over time, maybe a heat issue, but if it's there from the start its more likely a persistent issue with some memory. Bad chippy!
It certainly has all the hall marks of corrupted memory, although never seen it manifest itself in some sort of Saturday night fever tribute. 😀
Reply 6 of 13, by konc
spiroyster wrote:
I have 😀
Does this look like a faulty Voodoo2, or something else is going on?
Reply 7 of 13, by spiroyster
konc wrote:
spiroyster wrote:
I have 😀
Cool 🤣
Reminds of this thread http://ompf2.com/viewtopic.php?f=5&t=25.
From another forum.
Reply 8 of 13, by FFXIhealer
I had texture thrashing like that. Turns out, it was a few bent pins on one of the texture mapping cpu chips that were touching each other. I used a sharp knife and separated them. Problem solved.
Reply 10 of 13, by meljor
That's the fix i usually come up with first with v1 and v2 as it is a common problem. But he states it worked fine before so assumed it was in a case all this time and could not get physically damaged.
But still worth a check: maybe some pins JUST didn't touch and now they do? When they do it creates the same problem and/or system lockups when trying to run 3D.
Reply 12 of 13, by meljor
Could be. It can also be a bad connection anywhere on the card.
