First post, by bergqvistjl
With a Rendition V2200 AGP card in my machine, I was able to simultaneously use a Voodoo2 PCI card in the same machine, with the cable connecting the Renditions' output VGA port to the Voodoo's input port, and my monitor connected to the Voodoo's Output VGA port. I was thinking of upgrading to a Voodoo3 PCI card, but I see that it only has a VGA output port, no input port. Does this mean I won't be able to use the two in the same machine any more?
Reply 2 of 6, by bergqvistjl
leileilol wrote:
Voodoo3 is a primary display device with a BIOS and everything so yes. You can probably switch between the two, motherboard bios permitting
OK, but I can't switch without rebooting & changing the setting in the BIOS (and obviously swapping the monitor cable around from 1 card to the other), like I can now with the voodoo2 card right?
Reply 4 of 6, by jade_angel
Windows (not 95 or NT4, though) will indeed let you use 2 monitors, though some games get odd when you have multiple 3d-capable video cards. However, that combo should work fine.
Main Box: Ryzen-TR 1900X | GTX 1050/Radeon RX 580
98/2000 Box: PIII/766 |Quadro4 380 XGL
Reply 5 of 6, by jheronimus
Alternatively, you can add a second Voodoo 2 in SLI. Might be trickier than just sourcing a V3, but you should get similar performance and still use all cards simultaneously.
My Telegram blog about retro hardware (in Russian)
Pentium 133, 32 MB RAM, S3 Trio64V+, Crystal 4232, Dreamblaster X2 and Roland MT-32
Pentium III 1000, 512 MB RAM, Voodoo 5 5500 AGP, SB Live 5.1, SB32 CT3930, Gravis Ultrasound Max rev2.1
Reply 6 of 6, by bergqvistjl
Deksor wrote:
I thought that in those cases windows would allow you to use two monitors. This isn't the case ?
Unfortunately my only option is to use a single monitor. Looks like a Voodoo2 SLI it is then? I may be selling the Voodoo3 I just bought 😜
