Troubleshooting Voodoo1 on a pure DOS Pentium1
Discussion about old graphics cards, monitors and video related things.
Re: Troubleshooting Voodoo1 on a pure DOS Pentium1
Postby konc » 2017-3-09 @ 19:34
Deksor wrote:Did you try to update (or downgrade ?) the BIOS and look if that can fix this problem ?
Yes, it's on the list of the things I tried in the first post. I upgraded to the latest BIOS available for this board.
User avatar
konc
Postby meljor » 2017-3-09 @ 21:08
which board is it precisely?
meljor
Postby konc » 2017-3-10 @ 10:55
meljor wrote:which board is it precisely?
It's the Intel "Orlando" NV430VX
http://www.elhvb.com/mobokive/Archive/P ... 182101.pdf
If I'm not mistaken, it was only made for OEMs with minor defferences, for example mine doesn't have the on-board sound card.
User avatar
konc
Postby Sammy » 2017-3-21 @ 11:28
Can you lower the FSB ?
Voodoo 1 Cards are not stable if FSB is higher than 66 Mhz
Sammy
Postby konc » 2017-3-21 @ 11:35
I could, but it's Pentium 1 anyway (66MHz) and the same card does work on another P1. I'll try it just for the sake of it.
User avatar
konc
Postby appiah4 » 2017-3-21 @ 11:55
Have you tried changing the PCI port of the Voodoo Card or even switching the 2D passthrough and Voodoo card around? Sometimes PCI cards work in some slots and not others - the topmost slot was what I used for Voodoo cards in some builds IIRC because the others could prove problematic. It could be an IRQ conflict of some type; I would try going into BIOS and disabling Automatic PCI IRQ assignations and manually assign IRQs only to ports I actually use and see if that helps..
Also, have you tried to see if it works with one of the EARLIER BIOS versions? It could be a PCIset issue that presented itself in a later BIOS and went undetected as Voodoo cards were not a thing back then..
A500:+512K|ACA500+|C1084S
i386:Am386SX-25|4M|TVGA9000B|ES688
i486:U5S-33|8M|GD5428|CT2290/MUNT-Pi
i586:P133|32M|S3T64+/MX2|V1|CT3980/32M
i686:K6-2/400|64M|V2/SLI|CT4500/32M
S370:P3-1200|384M|GF4Ti4200|MX300
S754:A3700+|2G|X1950PRO|SB0350
User avatar
appiah4
Postby Jo22 » 2017-3-21 @ 14:37
PCI uses "INTs", not IRQs.
https://www.safaribooksonline.com/libra ... 01s01.html
Just nitpicking.. ;)
User avatar
Jo22
Postby appiah4 » 2017-3-21 @ 14:54
Jo22 wrote:PCI uses "INTs", not IRQs.
Sorry, I stand corrected, it might be conflicting INTs :(
User avatar
appiah4
Postby Jo22 » 2017-3-21 @ 16:47
appiah4 wrote:Sorry, I stand corrected, it might be conflicting INTs :(
Nah, that's okay; IRQ is commonly used as an abbreviation for "interrupt" (-request).
Really just wanted to mention that link. It tells about the (physical) differences about ISA/PCI.
On PCI, not all slots are handled equally. On the computer side, INTs are mapped to IRQs.
And since the compatibility issue seems to be more hardware (bus) related, I wanted to point that out. :)
User avatar
Jo22
Postby meljor » 2017-3-22 @ 22:48
These cards do not use an irq adress.
I don't know a solution to this problem, it's just strange that windows works fine. Maybe another bios version but otherwise i don't know what i would try.
Perhaps other memory, psu or harddisk as these things can cause strange behaviour.
meljor
Postby konc » 2017-3-23 @ 08:12
appiah4 wrote:Also, have you tried to see if it works with one of the EARLIER BIOS versions? It could be a PCIset issue that presented itself in a later BIOS and went undetected as Voodoo cards were not a thing back then..
Now that's something I haven't tried. I'm not sure though how I can, there doesn't seem to exist an earlier BIOS available online.
About changing slots and components, unfortunately those are all done and listed in the first post. Maybe another direction would be to start thinking what Windows might be overriding/changing that makes the card work.
User avatar
konc
Postby appiah4 » 2017-3-23 @ 08:18
The first thing that comes to mind is that Windows is a PnP OS and your PCI configuration may be set to PnP (Auto) and DOS can't handle that well; have you tried setting your ISA/PCI slot configurations manually in BIOS?
User avatar
appiah4
Postby konc » 2017-3-23 @ 10:01
appiah4 wrote:The first thing that comes to mind is that Windows is a PnP OS and your PCI configuration may be set to PnP (Auto) and DOS can't handle that well; have you tried setting your ISA/PCI slot configurations manually in BIOS?
Sadly yes, that one was really probable and I was certain that playing with these would fix it.
konc wrote:-Played with BIOS settings by trying the IRQs in auto, manual, reset settings to default.
User avatar
konc
Previous
Return to Video
Who is online
