HD4670 AGP & Win98se, anyone got it working?
Discussion about old graphics cards, monitors and video related things.
Postby t3f4l » 2017-3-14 @ 19:18
Hi All
Has anyone managed to get an ATI HD4670 AGP card working under windows 98 se? If so which drivers are used?
Many Thanks
t3f4l
Re: HD4670 AGP & Win98se, anyone got it working?
Postby emosun » 2017-3-14 @ 19:28
I believe even Ati never got it working.
I can't imagine a senario where you would use windows 98 and a 4670 As any game that will still run on windows 98 won't utilize the 4670. The 9000 series was the last amd gpu to support 98
User avatar
emosun
Postby havli » 2017-3-14 @ 21:09
X800 is also working in win98, X850 is pretty much the same GPU, so it should be ok as well. I'm not sure about the X1000 series... but anything newer that that definitely won't work.
User avatar
havli
Postby MrMateczko » 2017-3-15 @ 15:45
Radeon X850 XT PE is the best/latest GPU from ATI that works under 98SE. Anything newer - no.
User avatar
MrMateczko
Postby candle_86 » 2017-3-22 @ 14:58
Why would you want to make it work, its overkill for any games that support Windows 98 unless your trying to do Windows 98 at 2560x1600 or 4k
Ryzen 5 1600 - Gigabyte B350 Gaming - 16gb DDR4 3200 - 240GB M.2 - Windows 10 Pro
Core i3 3470 - Dell B75 Mobo - 4gb DDR3 1333 - 500gb HDD - Windows XP
Opteron 180 - Epox EP-9NPA+SL - 2gb DDR500 - 320GB HDD - Windows XP
User avatar
candle_86
Return to Video
Who is online
Users browsing this forum: No registered users and 2 guests
