Reply 20 of 24, by pcwizard7
- Newbie
wrote:wrote:I look around on the net and found a geforce4 Ti4600 AGP x4 and based on the research i found it should be able to run at x2 as […]
wrote:Oh, I see what you mean. I thought you were saying that the board had an AGP 4x slot that would work with 2x cards (which most if not all 4x slots will, IIRC).
GeForce 4 lineup: https://en.wikipedia.org/wiki/GeForce_4_series
I look around on the net and found a geforce4 Ti4600 AGP x4 and based on the research i found it should be able to run at x2 as well and work in x2 3.3V Motherboard.
Research Infor
http://www.playtool.com/pages/agpcompat/agp.html
I also read the FX Series didn't work well with p3s but great with AMD Athlon
the only thing that worry me about the card is brand name i ve never heard of them: CHAINTECH?
also if i get this card to work is it worth putting in the voodo 2 PCI Card i have in P4 in p3?
Also i may need to oil the fan or replace it so do you know the right oil or replacement fan for that card?thanks
For oiling fan bearings, after trying a few different things, including 3-in-1, I have settled on a single drop of full synthetic motor oil for small fans. My brand of choice is Mobile-1, but any synthetic will work fine. I usually have 5w-20 or 10w-30 around and either works fine. You don't have to worry about it drying up like petroleum based oils will do over time.
How many quart would that be?
