First post, by Elia1995
- Oldbie
Hello, I posted in the VGA Capture thread some days ago but didn't receive any reply yet, so I'm making a new entire thread about it.
I bought the AVerMedia Live Gamer HD Lite PCI-E capture card for my streaming and recording needings, it works perfectly when I record my PS3 footage, but... I got a huge problem for anything non-HDMI.
As some of you might know, that capture card has an HDMI IN and an HDMI OUT port in its I/O, one for input signal and one for video passthru.
I bought an active converter that can convert component and VGA to HDMI, it works perfectly when I connect it to my HDMI monitor or when I use the capture card's video passthru plugging in the monitor in the HDMI OUT of the card, but I get a completely black screen in every software where there should be the capture card's preview.
I get a black screen in RECentral, a black screen in OBS, XSplit and even on Skype (I can use the capture card as a webcam and show my friends it in real time, works much better than ManyCam or Skype's desktop sharing).
The converter itself actually works, as I can see it just fine when I use the video passthru on the capture card plugging the monitor in the HDMI OUT port, or plugging the converter directly to my HDMI monitor, but I can't record anything because the preview just shows a black screen... the software even detects the signal and automatically adjusts the resolution !!!
Here are some screenshots and some photos:
This is the converter itself, front view with the power led, red/green led (green = 1080p, red = 720p), menù button, resolution switch buttons and input selector button.
This is the rear of the converter, where you can see the HDMI output, VGA, 3.5mm audio and component inputs and 5v DC.
Here's where the other end of the VGA cable is: straight into my currently best DOS PC (What model and manufacturer is this motherboard ??)
Here's where I plugged the HDMI cable into my new capture card.
And as you can see, while the preview is pure black anywhere, when I connect my main monitor in the HDMI OUT of the capture card, I can see everything just fine... but how am I supposed to record if the preview is blank ?
When I hit the record button it only makes a 1 KB .ts video file... it's like the converter skips the capture card completely, but nonetheless it gives her all the signal information (check the second screenshot) !!!
Please help, I bought this capture card to increase my video and twitch quality, but I must solve this issue first !!! I member you that the card works fine, as I can record my PS3 perfectly.
Currently assembled vintage computers I own: 11
Most important ones:
A "modded" Olivetti M4 434 S (currently broken).
An Epson El Plus 386DX running MS-DOS 6.22 (currently broken).
Celeron Coppermine 1.10GHz on an M754LMRTP motherboard
