First post, by ProfessorProfessorson
Same deal as with the Kyro II testing I did, doing 800x600 testing. All games set maxed out with 32-bit color when available.
Geforce 4 MX 420 64mb AGP
Pentium III 1ghz 100fsb
256mb Pc100
Intel 440BX2
Vortex 2 soundcard
Windows 98 SE
Driver 45.23 was used.
2017-08-08 17:34:29 - LEMANS 24
Frames: 2917 - Time: 100860ms - Avg: 28.921 - Min: 29 - Max: 30
maxed out 800x600 32-bit
2017-08-08 17:44:28 - LITHTECH (No One Lives Forever)
Frames: 7990 - Time: 179903ms - Avg: 44.412 - Min: 22 - Max: 83
2017-08-08 18:13:43 - UNREAL TOURNAMENT
Frames: 28905 - Time: 417907ms - Avg: 69.166 - Min: 31 - Max: 154
2017-08-08 18:25:38 - DETHKARZ
Frames: 7214 - Time: 142897ms - Avg: 50.483 - Min: 18 - Max: 131
2017-08-08 19:24:12 - SEGA RALLY 2
Frames: 4173 - Time: 69955ms - Avg: 59.652 - Min: 44 - Max: 61
maxed out 800x600 (no color option)
2017-08-08 19:27:48 - QUAKE 2
Frames: 14485 - Time: 66402ms - Avg: 218.141 - Min: 102 - Max: 366
maxed out 800x600 16-bit color
3D Mark 99
800x600 16-bit
7000 3D marks right on the dot
race 82.7fps
first person 60.7fps
3D Mark 2000
800x600 32-bit Hardware T&L
5299 3D marks
Game 1 - Helicopter - Low Detail: 109.3 FPS
Game 1 - Helicopter - Medium Detail: 79.4 FPS
Game 1 - Helicopter - High Detail: 39.1 FPS
Game 2 - Adventure - Low Detail: 103.5 FPS
Game 2 - Adventure - Medium Detail: 67.6 FPS
Game 2 - Adventure - High Detail: 42.6 FPS
Reply 1 of 5, by Tetrium
Since this thread is getting less attention then your Kyro benchmark thread, may I suggest that you also put these results into your Kyro benchmark thread? In such a case the results may also be compared. And I like both Kyro and GF MX 😁 (even though admittedly I never ended up trying out my own Kyros, I still wanted them as I found these interesting).
Kyro thread Kyro II 32mb AGP 800x600 testing
My retro rigs (old topic)
Report spammers here!
Reply 2 of 5, by ProfessorProfessorson
The threads probably just getting less attention because no one in their right mind would choose to use a MX 420. 😜 I actually just wanted to test it on a whim since I had not used one since like 2002. It's honestly a bottom of the barrel kind of card. I dont recommend anyone pick one up over a Geforce 2 or 3, or Radeon 7500 or anything.
Reply 3 of 5, by The Serpent Rider
Why not? That's GeForce 2 MX400 OC level. It's not practical to use GeForce 1/2/3 anyway, because GeForce 4 Ti is better in every aspect.
Reply 4 of 5, by ProfessorProfessorson
I wouldn't use a GF 2 MX 400 either. Its one of those things, a lot of these cards fall in a general price range, so if you dont have any of them and want to buy something, there is much better options. A GF 4 MX 440 or Radeon 7500 can be had on ebay for under $10. If you're going to go on the lower end, those two are at least much better cards.
Reply 5 of 5, by Tetrium
You're correct. I got most of them either as hand-me-downs or these happened to be in more-or-less complete systems I gotten one way or the other. I wouldn't toss any of them either and having side-by-side benchmark results is always nice to have available 😀
