First post, by kaputnik
- Oldbie
Picked up a Quadro4 750 XGL a while ago, and finally got time to try it out.
Seems to be something wrong with it. The font is garbled, even during POST, see attached image. Not a good sign. The Windows driver will work in 640x480, 16 colors, with some artifacts. If I try to raise the resolution or color depth, I will only get a black screen with some green spots here and there.
Might also be worth mentioning that the distortion of the letters is exactly the same, even after removing and reseating the card.
Tried reflashing the BIOS in case of data rot, probably the card has beeen lying around for some time before I got my hands on it. No difference.
Any ideas of how to go about this from here?
