First post, by emosun
You know I'm genuinely surprised at how much knowledge people have on voodoo cards and glide , or obscure branded cards , but hardly anyone has a very good knowledge of old school crossfire. maybe someone here does and is waiting in the shadows to emerge. 🤣
I'm playing with a crossfire 2600 xt system I have and am running into some old school problems.
firstly , several games that are supposed to support crossfire from this era and even have official crossfire profiles don't work as they should. With a single card they work fine and the single card has 100% usage during the game , when activating crossfire rather then adding the second cards power it simply splits the difference between them. so both cards will run at 50% usage , which is pretty pointless as it yields the exact same frame rate as a single card. I can force different crossfire settings for these games but they usually end up in artifacts or worse performance. That being said , some games DO work fine and scale great. Borderlands for example literally doubles it frame rate in crossfire which is amazing to see. gta 4 run less crappy then it already runs simply due to it being a terrible port , but it is less crappy in crossfire. GRID runs much faster in crossfire. the thing I can see in these games is both gpu's being used 100% during the game.
I also tried the crysis demo which doesn't seem to like crossfire but that might be due to the fact that it's the demo.
Next , it seems these cards run slower in dx9 in crossfire. I'm wondering if this is down to these older cards using too new of driver on too new of windows (windows 7). should i be using windows Vista with these cards instead? I'd use xp which would be more period correct but it doesn't have dx 10 support.
I should also say I can recreate these problems using my 3870x2 as well. it's the same era and uses the same drivers and crossfire 2.0 system.
Reply 1 of 4, by cyclone3d
What framerates are you seeing in the games that aren't running both GPUs at 100%?
Is vsync disabled? If not and it is not fast enough to run at the refresh rate of the monitor then the fps is going to be cut in half of the refresh rate.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 4, by SPBHM
what kind of CPU and motherboard are you running? I don't remember GTA4 ever being a good game for multi GPU, it was a very CPU limited game
also looking at this 3870 X2 review, lots of games don't scale well, including Crysis,
something like FEAR scaled really well perhaps a good game to start?
https://www.techpowerup.com/reviews/HIS/HD_3870_X2/10.html
Reply 3 of 4, by emosun
that , same as a single card. i never use vsync
Reply 4 of 4, by swaaye
Early Crossfire is interesting because it looked like ATI hacked it together quickly to compete with NVidia SLI. They used FPGAs and some other chips, and funky external cables. I have a X1950XTX Crossfire Edition that I use as a solo card.
