First post, by Aglenoth
Hello , i know this might be a dumb question but i just can't decide which one of those (i want them for mid and late dos games) :
s3 trio64v+
s3 trio3D/2X
Ati Mach64
Any response is highly apriciated 😀
Pentium II 266 MHz
Diamond Voodoo Monster II 12 Mb
S3 trio 64v+ 2Mb
ESS AudioDrive 1868f
10Gb fireball HDD
256 Mb Ram
Reply 2 of 7, by Aglenoth
Thank you for your responce 😀
Pentium II 266 MHz
S3 trio 64v+ 2Mb
10Gb fireball HDD
256 Mb Ram
Reply 4 of 7, by chinny22
I have the Mach64 onboard my 486.
Its Ok, but more for high res Win3x then fast dos gaming, either of the S3 cards are probably a better choice
Reply 5 of 7, by Aglenoth
All this help is highly appriciated 😀 Thank ya'll for your time 😀
Pentium II 266 MHz
S3 trio 64v+ 2Mb
10Gb fireball HDD
256 Mb Ram
Reply 6 of 7, by appiah4
Either Trio would be fine depending on whether you have agp or not.
Mach64 is ancient.. I would steer clear.
Reply 7 of 7, by kanecvr
ElectroMan wrote:
Based on my research, I would pick up S3 Virge/DX 4mb. Though you don't have it in your list, it is easily obtainable and cheap. You don't need much power for DOS, but from compatibility prospective it seems to be one of the best, if you don't want to have occasional texture glitches etc. Voodoo will do the heavy-lifting quite nicely when required. Someone more knowledgeable might correct me.
Some tests in you're interested:
download/file.php?id=19379&mode=view
^this
