First post, by Stojke
HI guys. Because Toshiba Tecra 8200, and lower models, use an XGA screen (1024x768) the full screen DOS graphics are distorted. This makes out ugly graphics and it is pretty annoying to play on the default 640x480 small rectangle in the center of the screen.
By my calculations the SXGA resolution (1280x960) is exactly two times the smaller DOS resolution on this laptop and because of that it should display DOS resolution in full screen. Right?
So my question is, is there a screen compatible with this laptop that is in SXGA resolution? Or if not available what is the next best thing?
