AGP graphics card not detected by games after drivers installed
Discussion about old graphics cards, monitors and video related things.
Re: AGP graphics card not detected by games after drivers installed
Postby dondiego » 2017-11-29 @ 10:17
Don't you think the problem is pretty obvious by now? Reinstall windows from scratch and then the right nusb33 driver for your OS language (english?). And finally install DX 8.0a.
User avatar
dondiego
Postby Elia1995 » 2017-11-30 @ 18:01
Nothing changes at all.
As soon as I install the VIA 4-in-1 AGP driver and then the nVidia Forceware 81.98 (or 56.64) driver and restart, I still cannot install DX 8.0a or 9.0c.
Games with a settings window such Tomb Raider III don't even list the graphics card even if it's fully working and recognized by the OS (I can set 32-bit true color and 1920x1080 resolution on the system just fine...)
Currently assembled vintage computers I own: 11
Most important ones:
A "modded" Olivetti M4 434 S (currently broken).
An Epson El Plus 386DX running MS-DOS 6.22 (currently broken).
Celeron Coppermine 1.10GHz on an M754LMRTP motherboard
User avatar
Elia1995
Postby meljor » 2017-11-30 @ 20:38
Try installing dx8.1 first (make SURE it is win98se compatible version). Then agp driver and then Nvidia Driver.
Try a DIFFERENT downloaded version of dx8.1, agp driver and for example Nvidia 40 series driver. One of the things are giving you trouble, so change them all.
If the problem persists perhaps your motherboard is damaged but it could also be your memory, harddisk or psu.
meljor
Postby Elia1995 » 2017-12-01 @ 10:59
I just formatted and reinstalled a fresh copy of Windows 98SE to start from scratch again (what is this, the 8th format and reinstall in this week ???).
I haven't installed any driver AT ALL yet.
In the system properties, in the "Computer" section of the General tab, I read:
"Computer:
GenuineIntel
x86 Family 6 Model 11 Stepping 1
512,0 MB RAM"
ALTHOUGH I used to see:
"Computer:
GenuineIntel
Intel Pentium III(TM) Processor
511,0 MB RAM"
BEFORE formatting !!!
Why is that ? I noticed that this also happened after I installed the drivers on the latest installation before this one, I didn't see "Pentium III Processor" but "x86 Family 6 Model 11 Stepping 1" instead, so it MUST BE a driver issue for sure !!!
User avatar
Elia1995
Postby clueless1 » 2017-12-01 @ 12:41
Chipset drivers not installed?
User avatar
clueless1
Postby Elia1995 » 2017-12-01 @ 17:46
Yes, the latest I tried were the VIA 4-in-1 4.56
User avatar
Elia1995
Postby Elia1995 » 2017-12-04 @ 22:07
Guys, I gave up for now, I'm moving the project on another PC with the ASUS A7A266 motherboard, slight slower CPU (1000 MHz instead of 1333), but the drivers work just fine, exact same GPU and different chipset (ALi instead of VIA).
I'm getting that PC cleaned up because it was dusty AF, and the cooler fan changed with another one (same fit, so it should stay on that nice heatsink) because it was too damn noisy (I hate loud and noisy computers, despite I grew up with computers that sounded like a Ferrari engine the whole time... I wish I could watercool all my retro computers)
User avatar
Elia1995
Postby Elia1995 » 2017-12-22 @ 08:36
EDIT: I tried the exact same card on the A7A266 PC, different chipset and thus different AGP drivers, but same results: with either the 56.x or the 81.98 drivers, I get 32-bit, gradients on titlebars, nView, fully working dual monitor, but it remains stuck at DirectX 6.1 and I can't upgrade it to DirectX 9.0c (which I swear was working on this card), no 3D game like Planet of Death, Star Wars POD Racer or Sim Theme Park work at all, pod racer gives me "no 3D hardware found" error!!!
So I can move back to the Pentium 3 which is better, but I haven't tracked down the problem yet.
I tried a Matrix G4500 and it works perfectly, but I can't still upgrade to DX 8.1 or 9.0c, that card has only 32MB of, memory... WELL I want the FX5500 to work as it used to, it's a driver issue, we must track that bug down once and for all.
User avatar
Elia1995
Postby KCompRoom2000 » 2017-12-23 @ 00:05
This may be a shot in the dark, but is it possible that the reason why newer DirectX versions refuse to install is because you're trying to install the English version of DirectX on an Italian version of Windows 98? I remembered that most Windows components (such as Internet Explorer and Windows Media Player) can vary by language and may refuse to install on a Windows version that doesn't match the language that the update's designed for.
This was the closest I could find regarding an Italian version of DirectX 9.0c that still works on Windows 9x, maybe it'd be worth a shot to try it:
https://www.3dfxzone.it/programs/?objid=655
Do you have access to an English copy of Windows 98? If so, can you install it on the PC that's having these issues to see if it's language related?
1988-96:SL-54U5|P233MMX|64MB|Virge325|YMF719-S
1995-98:P2B-VE|C433|192MB|Rage Pro|Voodoo2|CT4500/32M
1998-01:GX150MT|PIII-S 1400|512MB|GF4Ti4200|SB0350
2000-05:A8V|A64 3700+|2GB|RadeonX800
User avatar
KCompRoom2000
Postby Elia1995 » 2017-12-23 @ 08:31
I had these issues even with an English version of 98SE.
I think it's more driver related than anything else, I tried every single Forceware driver compatible with the FX5500 so far, I only need to try that DX version you linked and the 4x custom drivers someone mentioned earlier in the thread.
EDIT: As it turned out, not even your DirectX version worked, I can't install with neither the FX5500 card and its drivers (ON WHICH PREVIOUSLY I HAD FULLY WORKING DIRECTX 9.0c), nor with the Matrox G4500.
User avatar
Elia1995
Previous
Return to Video
Who is online
Users browsing this forum: Baoran and 1 guest
