Voodoo2 corrupt graphics
Discussion about old graphics cards, monitors and video related things.
Postby kixs » 2017-12-18 @ 21:22
Hi,
a few days ago I tested all my Voodoo2 cards and one was a bit flaky. I remember a few years ago one had screen corruption but when I tested them now all seemed to work fine. When I repeated my tests with SLI setup one combo showed some glitches when running for a few minutes. I tested each card separately and one was bad - as I remembered.
Here are some photos from NFS3. What is going on and can it be repaired?
In between there wasn't much corruption but in the end, after ~2min, it was really bad. Otherwise chips don't get too hot.
Photo of the card - Creative Voodoo2 8MB CT6670:
When I got the card it was in a computer in pretty bad shape. It looked like it was in a basement with high moisture for quite some time. I cleaned everything but this card has problems :depressed:
Thanks
My Amibay: SALE | BUY - Updated on 2018-07-17
User avatar
kixs
Re: Voodoo2 corrupt graphics
Postby chrismeyer6 » 2017-12-19 @ 01:31
I would carefully inspect each chip to make sure that none of the legs are touching each other causing a short. It seems to be a common issue with these cards
chrismeyer6
Postby kixs » 2017-12-19 @ 08:31
I have a habit of checking every pin before using any card. It seems all are good.
User avatar
kixs
Postby CkRtech » 2017-12-19 @ 08:45
In my opinion, it looks like a RAM issue.
User avatar
CkRtech
Postby SSTV2 » 2017-12-19 @ 12:38
Disable 2nd TMU via registry, if corruption persists, it's TMU 1 mem-related problem (does NFS3 even support multitexturing?). I'd suggest to test card with tech demos instead of games.
User avatar
SSTV2
Postby Cyrix200+ » 2017-12-19 @ 13:16
Also, if you use the FastVoodoo drivers check the memory frequency. Those drivers overclock that in their standard configuration (95MHz instead of 90MHz)! That caused issues with one of my Voodoo2 cards!
See also: viewtopic.php?f=46&t=39993&p=599096&hilit=fastvoodoo#p599096
Retro workhorse: Asus P2B-LS | Tualatin Celeron 1400MHz | Matrox G400
Image gallery
User avatar
Cyrix200+
Postby kixs » 2017-12-19 @ 14:44
Jep, I use FastVoodoo drivers. Will check all your suggestions later today.
User avatar
kixs
Postby kixs » 2017-12-29 @ 08:03
Tested it again. FastVoodoo sets the frequency at 93MHz. I set it to default but the corruption remained. Then I inspected the card again and there are two SMDs missing at the back: C128 and C89. I guess it might be recoverable if someone know what it goes there and has the means to repair it.
User avatar
kixs
Postby firage » 2017-12-29 @ 10:13
Probably the same capacitors as C118. Google knows at least one example of this board that's also unpopulated there, but the components seem to be present on most of them.
User avatar
firage
Return to Video
Who is online
