First post, by buckeye
Getting ready to fire these up for my first Voodoo experience ever but I'm confused on what drivers - so many ideas out there: fast voodoo, latest voodoo or latest
in my particular case Creative Voodoo Blaster2. Can anyone advise on this please?
Intel SE440BX P3 450 256MB 80GB SSD Radeon 7200 64mb SB 32pnp 350W 98SE
Reply 3 of 19, by leileilol
I stick with the last official 3dfx drivers and drop in the MesaFX GL dlls when I need them.
I don't trust third-party drivers. Most of them just flip a few existing variables, sometimes unsolicited overclocking, and go "ya we are fast grafik !!! go to our web site". They also inexplicably disable the filter. *grumble*
long live PCem
Reply 8 of 19, by derSammler
Scubs wrote:
I see, ill take that as a no.
What an idiotic statement, sorry.
Why do you think the FastVoodo drivers are "fast"? They overclock the 3dfx chipset and disable features that would make the 3D output slower. In other words: these are hacked drivers and you use then at your own risk. This is a fact and you can prove yourself by looking at the inf-files to see what the drivers do.
Reply 11 of 19, by buckeye
Since I paid a lot of coin don't want to run the V2's into the ground plus my case is crap as far as cooling so I'll start with the latest official drivers and go from there.
Thank you all for the input tho.
Reply 15 of 19, by appiah4
I've had more bugs and glitches with the FastVoodoo drivers than with the latest official 3dfx ones, but I use a mismatched SLI config so I am stuck with them. That said, they are nowhere near what you would call bad. Just remember to disable the default 3Mhz overclock they come with (for whatever reason).
Reply 16 of 19, by titsmcgee
kixs wrote:
I see it clocks it at 93 not 95MHz.
My voodoo 2 stock speed is 100mhz, seen 110mhz cards too. earlier cards 90mhz.
source code for drivers open, can compile drivers for more speed.
Reply 18 of 19, by titsmcgee
latter voodoo 2 cards ran at higher clock. older first second gen ran at 90mhz.
most voodoo2 cards ran at 90mhz stock with older rev a/b firmware.
Read tech specks on cards TMU and Pixel processor chip.
Pixel processor 500-0009-01 build to run up to 95mhz wile most TMUs were 100mhz. ram on most cards 100mhz. 93mhz not over clocking
Some cards came with clocks speed unto 110mhz like gainward dragon.
Reply 19 of 19, by matze79
My V2 8Mb SLI runs unstable at 93Mhz.. it took me some time to figure out why the Fuck it was unstable.
Then i figured out that one of the Cards didnt like the FastVoodoo Overclock.
Not that i did know it overclocked them...
