First post, by SEGamer
I recently won a Creative 3D Blaster on ebay that came with software and manuals and finally got a rig setup to test it.
Was a bit of a pain as with getting any old system setup and running. I started with Win95 but ditched that after I realized the games needed DOS mode to run and went with DOS only.
Pics can be seen here: https://imgur.com/a/gwleD
The games by Bullfrog were the only ones to give me headaches. Magic Carpet crashes if I run another game before it, and I can't get Hi-Octane to work. The screen will flash as if it's trying to run but goes back to DOS and freezes. Any ideas/help is appreciated.
Edit: forgot to mention the system specs
OS: DOS 7.1 (I think. Made a DOS disk from win98)
CPU: AMD 586@133MHz
RAM: 32MB
HDD: 4GB CF card
Main video card: ATI Mach64 GT Rage I
No sound card installed yet
Autoexec.bat and Config.sys are set to initialize the 3D Blaster, CD Drive, and mouse drivers
NintendoAge | VCFed
Reply 2 of 10, by Gona
Try with soundcard too.
Also try to change the VLB wait state on the motherboard or in bios.
I have tested the card in a Socket 3 system and is was always frozen does not matter changing VLB wait state or any bios settings so if the problem remains try an other Socket 3 motherboard...
Video card compatibility matrix for DOS games | ATI3DCIF compatibility matrix | CGL API compatibility matrix
Reply 5 of 10, by SEGamer
Turns out not having a sound card was the issue. I installed an SB16 and everything appears to be working fine, retested all games and all loaded without any hiccups. Kind of surprised there wasn't a warning about it since Magic Carpet yelled at me when it couldn't find any mouse drivers loaded, but then again I have seen error handling done worse with software of this time (and even today for that matter)
NintendoAge | VCFed
Reply 6 of 10, by Reputator
What what an amazing card to have working! Might be asking a lot, but since you're one of the few that has it, would you be able to record some footage of it in action? Even if it's just shaky cellphone footage.
https://www.youtube.com/c/PixelPipes
Graphics Card Database
Reply 7 of 10, by vetz
I have two videos on Youtube of the card in action. Anything particular you would like to see more of?
Reply 8 of 10, by SEGamer
Unfortunately I'm in the process of getting a capture card so I currently don't have a way to get any good footage yet which I'd rather do than film the monitor with a camera.
As vetz said, he has a video of all the games here: https://youtu.be/c7tTYwNDWlU
NintendoAge | VCFed
Reply 9 of 10, by vetz
Capturing from the 3D Blaster VLB isn't very friendly to capture cards. You need a card that can handle very custom refresh rates and resolutions.The Epiphan cards are the only ones I know about that can do it.
Fatal Racing /Whiplash capture test on the 3D Blaster VLB: https://www.youtube.com/watch?v=HunGvGcpbJ4
Reply 10 of 10, by SEGamer
Thanks for the heads up. I managed to find an epiphan vga2pcie for pretty cheap on ebay.
I've noticed the odd sync with my LCD monitors as well. My old Dell 4:3 monitor would display the image down and to the right. My Dell U2410F will display it fine, but I have to go into the monitor's menu and do the auto adjust every time it goes into a game.
NintendoAge | VCFed
