First post, by Morc
- Newbie
Hi, as i am new here i have request for you.
As i was born in 21 century, i have less knowledge of older Socket 7 computers(and 486, 386 etc.) but I found some parts at home and built a Pentium PC.
It has LuckyStar 5I-TX1(was in attic for ~10 years, had original bios but i flashed to patched bios downloaded from rom.by), Pentium /w MMX 133MHz, 32MB SIMM(??SIMM??) RAM(i haven't found any SDRAM), S3 Trio64V+(AliCat, Ali M3147V) 2GB IDE WD Drive, BenQ CD drive, generic floppy drive and small AT computer case with turbo switch, broken power button and Pentium III sticker.
I installed Windows 95(tried Win3.1) on it, but i have problems getting the S3 Trio64V+ GPU to work(i even tried Parallel printer, which works flawlessly).
When you put any PCI card into the first PCI slot of motherboard: IRQ is NA(tested Realtek Network card RTL8139D shows NA too but, i don't have driver for W95)
Other PCI slots show number in IRQ(GPU was showing 11).
Assign IRQ to VGA is enabled.
I even tried to download GPU drivers and install them but with no success(They install, but after rebooting shows error with adapter driver).
Is there any way to get the GPU working?
And i think that the first PCI slot is broken(due to PCI cards showing IRQ as NA).
