The story of the QuForce FX 5800 Ultra...
Reply 100 of 110, by slivercr
mockingbird wrote on 2020-06-25, 15:34:
slivercr wrote on 2018-04-06, 09:32:
Thanks for the compliment! I am working on a Quadro FX 4000 and turning it into a GF 6800 Ultra right now. Besides modifying the straps for the identity, I also have to unlock an extra quad of pipelines 😉 Other cards that should be interesting are the Quadro4 980XGL and maybe the Quadro FX 1100.
Hey, did you have any luck with this? I have a 6800GS and I want to modify the straps to unlock the extra pixel pipelines and vertex shader pipelines through this method instead of using Rivatuner.
Thanks
Never finished.
Most of my cards were sold before I moved across the world and I haven't found any cheap Quadros around where I am now. If I ever get more, I'll play with this again.
As a sidenote, Rivatuner will yield the exact same result when in Windows. It may be less convenient if you plan to swap cards around and have to set nvstrap everytime, but the result is the same.
Outrigger: an ongoing adventure with the OR840
QuForce FX 5800: turn your Quadro into a GeForce
Reply 101 of 110, by mockingbird
slivercr wrote on 2020-06-25, 16:33:
Never finished. Most of my cards were sold before I moved across the world and I haven't found any cheap Quadros around where I […]
Thanks
Never finished.
By the way, I bought a Quadro 3000 AGP recently -- it's defective... Corruption on the Windows loading screen and then a system freeze after a few seconds in Windows. OTOH I have three Quadro 1000 cards that work perfectly fine. I think the 5800's clock and memory were pushed beyond spec, despite what the official spec claimed (in other words, they were factory overclocked cards). If you can find a fresh Quadro 3000, I suggest running it at Quadro 1000 speeds for longevity. The 2000 and 3000 layout are also preferable because they offer a much wider variety of cooling solutions. I may try memory IC swaps on it in the future to see if that's what's wrong with it. The NV3x chips should not fail, but I wouldn't be surprised if the Samsung memory has.
As for the 6800GS.. Besides the 6800GS, I've also got 3 6800GT cards... Theoretically, the only thing that would be different in the BIOS is the device ID strap and the pixel pipes and vertex shader pipes straps. Maybe I ought to dump both cards and examine the differences... Any idea on where to look?
Reply 102 of 110, by slivercr
mockingbird wrote on 2020-06-25, 20:15:
bits 12, 13, 20, 21 of strap0 for device ID. No idea for the pipes.
You could compare the bits corresponding to the strap and rule out similarities/differences using the documentation to figure it out.
Reply 103 of 110, by havli
As for the 6800GS..
Depending on the GPU, some 6800 GS may not unlock at all... those using NV41 and NV42 for instance. Only if you have NV40 or NV45, there is a chance of unlocking.
Reply 104 of 110, by mockingbird
slivercr wrote on 2020-06-25, 23:53:
RivaTuner takes the guesswork out with a patch script called "NV40BIOSHwUnitsMaskEliminator.rts" which you apply to your BIOS dump. It also tells you what needs to be modified in the program if you want to do it by hand:
before:
14.55 KiB
after:
14.44 KiB
havli wrote on 2020-06-26, 17:08:
All 6800GS AGP are NV40. Unfortunately, mine experiences graphical glitching and is not suitable for the mod. So not all 6800GS AGP will unlock. I think the score was around 10900 in 3DMark vs. the 6800GT.
Reply 105 of 110, by havli
Most of them perhaps, but not all. 😀 There is at least one NV41 based - http://hw-museum.cz/vga/311/gainward-geforce- … 0-gs-agp--nv41-
Reply 106 of 110, by mockingbird
havli wrote on 2020-07-01, 15:06:
Wikipedia's labelling is a bit confusing, but it could be extrapolated that all PCIe chips (which includes cards that use a bridge chip) are on TSMC 110nm, while the AGP parts are IBM 130nm.
Bumpgate and underfill problems used to be a hot topic with nVidia back in the day, but I now wonder if the IBM 130nm chips were in fact much more reliable than TSMC 110nm parts. I trash picked a 6600GT yesterday. Cleaned her up, oiled the fan, it works great and it's a factory overclocked model (and it's AGP with the bridge chip). So it might be interesting to compare this card's longevity with the 6800 cards here. It's not an apples to apples comparison though, because the chip is different. A good test would be to get a native PCIe 6800 card and compare that, because it's much more similar.
To be fair, all previous chipsets were TSMC, but then the problems did in fact all start with the 90nm TSMC chipsets (as in the motherboard chipsets, which had an enormous failure rate - but it's also worth noting that HP overvolted them from the factory).
EDIT: Several hours into a 3dMark 2003 loop, the 6600GT crashed the system. So this lends credence to my theory that IBM's 130nm 6th generation GeForce parts were more reliable than TSMC fabbed ICs.
Reply 107 of 110, by 0xCats
Another addition for those wanting to mod GeForce 4 Ti 4200 cards into Ti 4800.
GeForce 4 Ti 4200 to Ti 4800 Mod
Original straps read out with
nvflash --display 112
E9 8F 71 00 43 10 8F 80 FF FF FF FF 00 00 00 00
FF FF FF FF 00 00 00 00 00 00 00 08 E9 35 14 E9
Mask we are interested in
Device ID's
GF4 Ti 4200 = 0281
GF4 Ti 4800 = 0280
What we need to modify:
HW Strap
ID-Bit:				  4 3210
0280 = 0000 0010 1000 0000
0281 = 0000 0010 1000 0001
Change = xxxx xxxx xxxx xxx0
So we want to flip bit 0 off.
Old Mask
ID Bit:	   4        32        10
Mask: -xxX xxxx xx32 xxxx xx10 xxxx xxxx xxxx
AND-0: FF FF FF FF
1111 1111 1111 1111 1111 1111 1111 1111
OR-0: 00 00 00 00
0000 0000 0000 0000 0000 0000 0000 0000
AND-1: FF FF FF FF
OR-1: 00 00 00 00
Now we reference the bits under ID Bit colums 3,2,1,0 for each mask.
Original Strap Math:
HW-Strap	:	0001
Strap0-AND : 1111
Results in : 0001
Strap0-OR : 0000
Results in : 0001
So to turn off bit 0 we can disable the last bit of the Strap0-AND mask.
That gives us 1110 which we must fit into our new Mask.
New Mask
ID Bit:	   4        32        10
AND-0: FF FF EF FF
1111 1111 1111 1111 1110 1111 1111 1111
OR-0: 00 00 00 00
AND-1: FF FF FF FF
OR-1: 00 00 00 00
Masked Strap Math
HW-Strap	:	0001
Strap0-AND : 1110
Results in : 0000
Strap0-OR : 0000
Results in : 0000
Strap code
nvflash --straps 0xFFFFEFFF 0x00000000 0xFFFFFFFF 0x00000000
But alas we cannot use this command on GF4 cards since nvflash is dumb and cannot handle straps that don't start with 7F (All of GF4 uses straps that start with FF)
nvflash --straps command will not work and you will manually have to edit your bios straps.
So hop into your fav hex editor (I used RVB Edit / X-BIOS Editor) and wrote the new mask down using endian notation.
 FF EF FF FF 00 00 00 00 FF FF FF FF 00 00 00 00
Then save and flash your new hacked BIOS onto the card.
And since I didn't do this on my own card, but rather helped someone else do it, i'll leave it up to them to show the results 😀
Here's a quick proof
20200822_163523.jpg?width=1214&height=683
Reply 108 of 110, by SPBHM
slivercr wrote on 2018-05-02, 12:29:
On the weekend a new cooler arrived and I've been trying it on. I decided to "downgrade" the card to a GeForce FX 5800 (still an upgrade from the Quadro FX 1000) in order to keep it as a single slot card and avoid heat issues with the VRAM and the RDRAM so close to each other.
The cooler does a great job and is very silent. I suspect my success with such small coolers has to do with the CPU used in my machine, with a more powerful CPU the card would be able to stretch its legs a bit more and it would get way hotter (I see this effect now when benchmarking a Coppermine 1000 vs a Tualatin 1400)
this cooler, I think I have the exact same one somewhere, it came originally in one 8600GT DDR2 from ECS in my case, I remember it being competent at cooling that card even with OC (think it was to 610Mhz),
I'm thinking, if it can cool a "FX 5800" surely it can cool my FX5900SE? (400MHz) because that thing (from EVGA) also has a noisy fan, and the worst part is that it doesn't offer any temp readings, the fan on startup runs really loud (100%), then it goes down during the boot process and with some driver/OS it also only boosts the speed when running 3d but unfortunately on 98 with 45.23 it's stuck at 100% all the time (and aida reports 100% fan speed and something like 4500 RPM), I don't think that it's something that can be software controlled.
I wonder if you are still running this combination (quadro + cooler)?
actually a little OT but this also reminds me, around 2004 I had another 5900SE from evga (exact same model of the current one), and at some point I downloaded some 5950U modded bios for it from a forum (guru3d I think), and I remember it worked well at 475MHz (the bios bumped the vcore), and the memory I think I could run at 900 due to looser timings (impossible with the stock bios), this thread reminds me of that, but there is another detail that I find interesting but my memory is not 100% on this, with the stock bios it didn't display a temp sensor, but with the modded 5950u bios it actually worked...
edit> riva tuner can control the fan speed just fine! might be the same with the quadro, it's just that in my case, without a temp sensor it seems risky to be playing with it.
Reply 109 of 110, by agent_x007
Here's a rundown of what's up.
Card in question is this one :
662.68 KiB
GPL-2.0-or-later
658.32 KiB
GPL-2.0-or-later
It's (apparently) a OC'ed 4200 Ti. Default clocks : 275MHz Core, 600MHz memory.
Because it looks like 4800 Ti PCB, I figured it should be possible to mod it.
Using previously mentioned method, we succesfully exchanged IDs of this card 😀
Here's how it was recognised (before restart after flashing) :
852.74 KiB
GPL-2.0-or-later
Performance wise, it doesn't matter if you got OC 4200 Ti "8x" to 4600 Ti speed or have actual 4800 Ti.
434.28 KiB
GPL-2.0-or-later
vs.
452.35 KiB
GPL-2.0-or-later
The only difference between those is DeviceID (can be seen in GPU-z).
Other than that, it matters for Futuremark Systeminfo 😁
Here's comparison of 3DMark 03 two scores (4200 Ti Agp 8x OC vs. 4800 Ti):
https://www.3dmark.com/compare/3dm03/6546811/3dm03/6546816
I would like to thank 0xCats for his help on this - couldn't have done it without him 😀
Reply 110 of 110, by 0xCats
Modding GeForce FX5800 to FX5800 Ultra (this really is only meant for those of you that want to test you golden chip 5800's)
I like to fully document the process for archival/long term reference.
original straps on FX5800
FF FF FF 7F 00 00 00 00 FF FF FF 7F 00 00 00 80
FX5800 to FX5800 Ultra Strap modding
Device ID's
GF FX 5800  = 0302
GF FX 5800U = 0301
HW Strap
ID-Bit: 4 3210
0301 = 0000 0011 0000 0001
0302 = 0000 0011 0000 0010
Change = xxxx xxxx xxxx xx01
So we want to flip bit 0 on and bit 1 off.
Bit Mask
ID Bit:	   4        32        10
AND-0: 7F FF DF FF
0111 1111 1111 1111 1101 1111 1111 1111
OR-0: 00 00 10 00
0000 0000 0000 0000 0001 0000 0000 0000
AND-1: 7F FF FF FF
0111 1111 1111 1111 1111 1111 1111 1111
OR-1: 00 00 00 00
Strap Math:
HW-Strap	:	0010
Strap0-AND : 1101
Results in : 0000
Strap0-OR : 0001
Results in : 0001
Straps for converting FX5800 to FX5800 Ultra
nvflash --straps 0x7FFFDFFF 0x00001000 0x7FFFFFFF 0x00000000
