First post, by murrayman
Searched around the forums and couldn't find anything quite the same, so:
I have a Voodoo 5 5500 64MB AGP that I've owned since the late 2000s. All stock, no modifications or repairs, still using the original HSFs and working just fine. It's paired up with an AOpen AX63 Pro w/ AGP 2x, PIII 933, 1GB (2x512MB) PC133 SDRAM, and a 40GB WD SATA HDD through a SATA to IDE adapter, running a recent clean install of Win98 SE w/ the unofficial SP3 3.60 using just the core updates, performance improvements, the 524288 MaxFileCache system.ini fix, and DirectX 9.0c, plus the pain ol' 3dfx Reference 1.04 drivers.
This computer has handled pre-2000s Glide and D3D games just fine for all the years I've used it, but recently I decided to benchmark it on 3DMark 99 MAX. Total 3DMarks was 4180.
Years before, the computer originally came with a Voodoo 3 1000 8MB AGP, which I've kept in storage. Pulled it out today, installed it in the machine, reinstalled the drivers, and ran the benchmark. Total 3DMarks was 4299, and there was a noticeable, though marginal, improvement in framerate for the first couple of tests, sans the texture rendering tests which the V5 bested until the 32M test.
I'm confused. I can't blame it on a dirty installation of Win98 or old, mismatched drivers vying for the pole position. Why would my V5 be performing worse than my V3?
Asus P3B-F 1.04, PIII 1.0GHz, 512MB PC133, V5 5500 AGP, SB0160
Asus P3B-F 1.03, PIII 933, 384MB PC133, GeForce DDR 32MB, SB0100
CP 5170, PIII 500, 256MB PC100, DM3DII 12MB, ESS 1868
PB M S610, PMMX 233, 64MB PC100, DM3D 4MB, Sound4
Reply 3 of 38, by murrayman
squiggly wrote:
Did you plug the extra molex power connector in?
Yup.
skv400 wrote:
Is the cooling fan operating properly?
Both fans are working just fine.
Reply 4 of 38, by cyclone3d
Is 3DMARK running the V5-5500 in SLI mode or just single GPU mode?
Do you even have SLI enabled for the V5-5500?
Yamaha YMF7x4 Guide
Epstein didn't kill himself
Reply 5 of 38, by murrayman
I'm not sure. Just did a quick Google search, and there doesn't seem to be any mention of having to enable it -- that the 5500 just works with it by default. How would one go about enabling it?
Reply 6 of 38, by cyclone3d
It is in the 3dfx control panel somewhere. I don't have a system set up with a V5 5500 at the moment so can't tell you exactly where.
See the Anandtech review where they specifically state that they are dissbling one GPU to emulate having a Voodoo 4 4500.
https://www.anandtech.com/show/580
And the 5500 only runs at AGP 1x (PCI66) while the single chip cards can do AGP 2x.
http://helppage.3dfx.sk/
Yamaha YMF7x4 Guide
Reply 7 of 38, by havli
For 3DMark99 make sure you have vsync disabled. Also PIII 933 is not exactly fast CPU for V5... but definitely should be able to do more that 4300 points.
Personally I don't have a good experience with those win98 unofficial patches, always gave me nothing but trouble. So maybe it is worth trying to do a clean install of 98SE on a spare HDD, keep just 512MB RAM and see if the performance improves.
Reply 8 of 38, by murrayman
cyclone3d wrote:
It is in the 3dfx control panel somewhere. I don't have a system set up with a V5 5500 at the moment so can't tell you exactly w […]
Couldn't find SLI, dual GPUs, or mention anything of the sort in the control panel; checked both advanced features and info, to no avail. It does read it as a V5 5500 though, so not an issue there. I do at least have it running at AGP 1x in the BIOS, and 3dfx Info / Everest confirms as much.
Vsync was disabled. And when I built the rig over a decade ago, I did so with keeping it era-appropriate in mind. I don't play any games made after Dec 31, 1999 on it anyway, so no need for anything faster. I do agree though, the CPU shouldn't be the bottleneck here. I'll give a clean, unmodified Win98 install a try if no other input comes around over the weekend, as well as taking some RAM out -- though the MaxFileCache fix should remedy any issues there by default.
Reply 9 of 38, by cyclone3d
I have a PIII-933 setup I can test my V5-5500 in to see if I get different results with 3DMARK 99... yay, now I have something else to do this evening.
I can also test with a V3-1000.
I'm almost 100% sure there is somewhere to enable/disable dual GPU mode for the 5500. Maybe it has to be a specific version of the 3DFX Tools. I'll try to figure that out as well.
Yamaha YMF7x4 Guide
Reply 10 of 38, by F2bnp
It's in the Anti-Aliasing tab which is kind of silly, but essentially you can pick between Single VSA100, Max Performance (2xVSA100, no FSAA), 2xFSAA, 4xFSAA.
You can configure this both for D3D and OpenGL separately, but it might also be on the general tweaking tab in which you can pick individual options for D3D and OpenGL, I can't remember at the moment as it has been a while since I tweaked these settings on my V5 powered PC.
Reply 11 of 38, by murrayman
That would definitely be appreciated if you get around to doing it, or if someone else chimes in with previous results of their own! And you were right:
Just confirmed that it was set correctly by default both under D3D and OpenGL/Glide: it is using both chips / fastest performance with no anti-aliasing. So no impact on results there.
Reply 12 of 38, by cyclone3d
I seem to remember that even if SLI is enabled, some games and programs still only utilize one GPU.
Now I am super curious to test stuff with my V5 again.
It's Friday so I can stay up all night if I want. 😈
What motherboard are you using and what chipset does it have?
Yamaha YMF7x4 Guide
Reply 13 of 38, by murrayman
cyclone3d wrote:
I seem to remember that even if SLI is enabled, some games and programs still only utilize one GPU. […]
Sounds good! I'm using an AOpen AX63 Pro with a VIA chipset. Full specs can be found here.
Reply 14 of 38, by cyclone3d
Ok, I'll be using a TYAN S1854 motherboard and S370 PIII-933 for testing as I don't have any Slot-1 CPUs near that speed.
Yamaha YMF7x4 Guide
Reply 15 of 38, by meljor
found some old scores from my systems. The closest i could find was 4400 3dmarks for a v3 3000 agp and 7408 3dmarks for a v5 5500 PCI. This was 3dmark99 1024x768 on a Celeron Tualatin 1000mhz (100fsb, 256kb cache) on an Asus Tusl2-c with 256mb ram.
The same Celeron cpu at 66mhz fsb and 667mhz did 3300 3dmarks for the voodoo3 (already maxxed out here at this resolution) and 5524 3dmarks for the Voodoo5 5500 PCI.
What i would do: Clean install normal 98se, some good late 3rth party drivers for the V5. Make sure the voodoo is working with 2 gpu's (try upping resolution and try FSAA modes) and make sure your cpu is running full speed. Also check agp settings or test the V5 in another system.
Good luck!
Reply 16 of 38, by cyclone3d
So I did a couple different runs at the default 800x600 on my system.
Tyan S1854 motherboard
Pentium III 933 - Socket 370
256MB PC133 RAM
Windows 98SE
Voodoo 5 5500 AGP
Driver - Raziel 64's Evolution Driver v1.01.16
DirectX 9.0b
Updates - Feb 2004 Microsoft Update CD - The unofficial service packs, especially the newer ones, cause all sorts of trouble with Win98SE.
Default settings in the 3DFX control panel:
5597 3DMarks
13450 CPU 3DMarks
Tweaked settings in 3DFX control panel - not necessarily the fastest possible:
Changed:
AGP - 2x
Geometry Assist - Enable
Maximum Buffered Frames - 2
Trilinear Texture Filtering - Enable
Triple Buffering - Enable
Vertical Sync - Disable
6549 3DMarks
13433 CPU 3DMarks
Yamaha YMF7x4 Guide
Reply 17 of 38, by murrayman
meljor wrote:
found some old scores from my systems. The closest i could find was 4400 3dmarks for a v3 3000 agp and 7408 3dmarks for a v5 550 […]
Good luck!
cyclone3d wrote:
So I did a couple different runs at the default 800x600 on my system. […]
256MB PC133 RAM
Windows 98SE
Voodoo 5 5500 AGP
DirectX 9.0b
5597 3DMarks
13450 CPU 3DMarks
Changed:
AGP - 2x
6549 3DMarks
13433 CPU 3DMarks
Thanks everyone for the input, and cyclone3d for running those tests! 😀
I'll start by downgrading the RAM to 512mb -- that will be just one stick of SDRAM, so I'll have to see how the system likes dealing with that -- then give it another clean install of Win98SE without any updates (I don't have any official Microsoft updates for the OS, just the unofficial SP3), and begin again with the Reference drivers and see what happens. I'll play around with a third-party driver set or two afterward to see if I can tweak the performance any if I don't get a sufficient score back, and perhaps get out the V3 again to compare. Should be able to do this over the week, and if anyone comes up with any further input, I'll definitely take that into consideration.
Reply 18 of 38, by cyclone3d
You can download the Feb 2004 Microsoft update CD image from vogonsdrivers.
http://www.vogonsdrivers.com/getfile.php?file … =873&menustate=
Yamaha YMF7x4 Guide
Reply 19 of 38, by murrayman
I don't know why I didn't think to check there since that's where I've got some of my stuff. 😅 Thanks!
