First post, by JLPedro
Need help identifing missing component on a Asus V8460 Ultra GFx card.
Missing component is D615 on back of card low left corner.
Thanks
    124.28 KiB
Reply 1 of 3, by SSTV2
Just by looking at given photo, you can tell that it's a silicon diode, probably with a part number of D5, which is a center tapped diode. You can substitute that SMD part with any silicon diode of the same or greater current rating.
Reply 3 of 3, by JLPedro
Thanks to both, will this component alone prevent the card from even post? When I got the card I tested it in varius motherboards and it didn't post in any, so I started looking at the card closer and its the only component missing.
