Radeon 7000 series gfx-Cards (Retro-Build)
Discussion about old graphics cards, monitors and video related things.
Postby dr.zeissler » 2018-4-29 @ 07:06
sorry a bit off-topic.
I have to uncheck fog in Turok1 and Turok2 otherwise I get extreme slowdowns with my R7000-PCI.
Installing the RageTweak 3.9 and checking the "Table Fog" there does not help. Any ideas?
http://www.majorgeeks.com/files/details ... tweak.html
CPU: PII 133-333 MOBO: SNI-D981 RAM: 512- FDD: Dualfloppy 3,5"HD/5,25"HD - 3,5"HD - 5,25"DD ISA-Catweasel HDD: 2x40GB - DVD
ISA(3): Audician32-S2Dreamblaster - GusACE PCI(3): Monster3D- Intel NW AGP(1): 3dfx V3-3000
dr.zeissler
Re: Turok fog Radeon 7000
Postby swaaye » 2018-4-29 @ 23:59
Yeah that was totally off topic. Make your own thread instead when you want to change to an unrelated topic.
swaaye
Moderator
Postby weldum » 2018-4-30 @ 05:37
which driver are you using? maybe using a date-aproppiate driver will solve things
Ohh, the humanity :depressed:
386SX 25-C3 800-P3 900-Atom 1.6-C-D 2.13-P4 2.26-P4HT 3.0-P-DC 1.6-AFX 2.6-FX 3.3
User avatar
weldum
Postby dr.zeissler » 2018-4-30 @ 06:19
The last driver available (6.2). These massive framedrops are also when using a glidewrapper (dgvoodoo) and playing titles like "ignition"
The game is super-smooth and fast but if fog-features are used the framerate drops near zero.
dr.zeissler
Postby weldum » 2018-4-30 @ 06:23
Should try a driver more close to the year the game launched, is common that when newer cards are launched, the drivers are more optimized towars newer hardware
User avatar
weldum
Postby dr.zeissler » 2018-4-30 @ 06:26
Mostly I read that ATI-drivers were bad if the card is new, so I went for the newest supported driver.
I will checkout an early one 4.x instead.
dr.zeissler
Postby weldum » 2018-4-30 @ 06:29
be sure to try it, also which os are you using?
User avatar
weldum
Postby dr.zeissler » 2018-4-30 @ 06:37
Tripple-Boot:
- Dos/Win1x/2x/3x/Gem/Geos (still need to patch the win3x vesa-driver for 256colors)
- Win98se DX8.1
- Win2000 DX9
The R7000 is a card that has all important modes centered on analog vga on the tft. (VGA-Text/EGA-gfx/VGA-gfx).
The card is quiet and has a very clean and sharp output. S3tc does work out-of-the-box on ut436 (with hirestextures).
The R7000-Techdemo works, but freezes after a short while. Regardingless it looks like the card has some sort of
pixelshader (reflections on the floor) but none other game can use them, but I am not shure about this.
I have checked out a lot of cards and this r7000 was the best so far.
dr.zeissler
Postby weldum » 2018-4-30 @ 06:44
everything looks fine, the thing that's suspicious is the techdemo freezing
do you have any way to measure the heat in the card? other than touching it
User avatar
weldum
Postby dr.zeissler » 2018-4-30 @ 06:51
It's a driver issue. With Win98se it freezes even if a big fan is mounted on the cooler so the gfx-card stays cold.
In win2000 it works better but the framerates are low. The res is to high for that gfx.
dr.zeissler
Postby weldum » 2018-4-30 @ 06:56
still, it should not freeze up. to me everything is because of a driver issue, try downloading the first available driver for that card in each OS and see if it's an improvement, if you can't find it, tell me and i help you in the task
User avatar
weldum
Postby derSammler » 2018-4-30 @ 16:30
It's probably because the 7000 can not do that in hardware and rendering those effects in software gives a massive drop in fps. The 7000 was very, very low end.
derSammler
Postby matze79 » 2018-4-30 @ 17:41
Yeah the Radeon 7000 is a cut down Radeon DDR..
hold back by 64bit memory bus..
The Radeon DDR is superior to it.
Can't confirm any slow downs, just a slight fps drop.
Using Radeon DDR.
I also own a 7000 PCI, so i can test it if you like.
I simply would drop in a Rage 128 Card if you like Table Fog.
It looks better on Rage.
https://www.retroianer.de
matze79
Postby dr.zeissler » 2018-4-30 @ 18:21
Please do some testing. I checked out the Cat 4.2 and 6.2 it's the same. Other games perform really good with that card. (Kingpin, UT99, etc.) S3tc looks really good on R7000.
Turok1: D3D
- First massive framedrop is at the end of the Logo Animation.
- Second is after the menu is visable and the statusbar (highlight of the menu) is "pulsing" => look at the background.
- If i disable "fog" the framedrops are gone and the game is ugly.
I discovered only turok1/2 to be problematic. (And of cause glide-emulation with dgvoodoo).
Doc
dr.zeissler
Postby dr.zeissler » 2018-4-30 @ 18:22
dr.zeissler
Postby weldum » 2018-4-30 @ 19:01
that's weird, i thought that the radeon series had table fog emulation, you may be looking for some card that has support for that in order to play it
by the way, nice collection, althrough i can't load the pictures in full detail, my internet is going slow lately.
User avatar
weldum
Postby dr.zeissler » 2018-4-30 @ 19:53
strange things happen...now the radeon ark demo is working. don't know why.
but I had to reinstall the latest driver (6.2 Catalyst)
dr.zeissler
Postby weldum » 2018-4-30 @ 20:01
that's really strange, great but strange
i've found this, it may work, have you tried it?
[HKEY_LOCAL_MACHINE\Software\ATI Technologies\Driver\0000\atidxhal]
"DisableHierarchicalZ"="0"
"EnableWaitUntilIdxTriList2"="1"
"Vsync"="0"
"DitherAlpha"="1"
"AntiAlias"="0"
"AntiAliasRatio"="512"
"ZFormats"="15"
"ExportCompressedTex"="1"
"TableFogEnable"="1"
"WFogEnable"="1"
"ZFogEnable"="1"
"FastZClearEnabled"="1"
"DisableHyperZ"="0"
"TCL"="1"
"TCLEnableVertexBlend2Optimize"="1"
"TCLEnableVertexBlendUseProjMat"="1"
"TCLEnableBackFaceCulling"="1"
"RasterGuardbandEnable"="1"
set to 1 the "TableFogEnable" thing
User avatar
weldum
Postby dr.zeissler » 2018-4-30 @ 21:17
No, but I think these option are exactly what the ragetweaker uses.
dr.zeissler
Postby weldum » 2018-4-30 @ 21:22
is that, or using a nvidia card, also you can use a 3dfx, i think a savage 4 also works, you may need to do testing
i have some cards, but all the games i have doesn't use palletized textures nor table fog, so i can't help you more
User avatar
weldum
Next
Return to Video
Who is online
Users browsing this forum: No registered users and 3 guests
